[GRASS-SVN] r73340 - grass/trunk/lib/python/ctypes/ctypesgencore/parser
svn_grass at osgeo.org
Sat Sep 15 20:19:01 PDT 2018
Author: annakrat
Date: 2018-09-15 20:19:01 -0700 (Sat, 15 Sep 2018)
New Revision: 73340
grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py
grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
ctypes: fix compilation on Mac, not sure why it was there, we might need to revisit this if it causes problems
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py 2018-09-16 03:16:58 UTC (rev 73339)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/lex.py 2018-09-16 03:19:01 UTC (rev 73340)
@@ -44,7 +44,6 @@
import types
import collections
import functools
-from grass.script.utils import decode
if PY3:
_meth_func = "__func__"
@@ -256,10 +255,7 @@
# input() - Push a new string into the lexer
def input(self, s):
- s = decode(s)
- if not (isinstance(s, bytes) or
- isinstance(s, str) or
- isinstance(s, unicode)):
+ if not (isinstance(s, bytes) or isinstance(s, str)):
raise ValueError("Expected a string")
self.lexdata = s
self.lexpos = 0
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py 2018-09-16 03:16:58 UTC (rev 73339)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/pplexer.py 2018-09-16 03:19:01 UTC (rev 73340)
@@ -21,7 +21,6 @@
from . import lex
from . import yacc
from .lex import TOKEN
-from grass.script.utils import encode, decode
PY2 = True
@@ -77,7 +76,6 @@
class StringLiteral(str):
def __new__(cls, value):
- value = decode(value)
# Unescaping probably not perfect but close enough.
try:
value = re.sub(r'\\x([0-9a-fA-F])(?![0-9a-fA-F])',
@@ -283,7 +281,7 @@
@TOKEN(STRING_LITERAL)
def t_ANY_string_literal(t):
t.type = 'STRING_LITERAL'
- t.value = StringLiteral(encode(t.value))
+ t.value = StringLiteral(t.value)
return t
