[GRASS-SVN] r73341 - in grass/trunk/gui/wxpython: gui_core nviz
Sat Sep 15 20:21:46 PDT 2018
Author: annakrat
Date: 2018-09-15 20:21:45 -0700 (Sat, 15 Sep 2018)
New Revision: 73341
   grass/trunk/gui/wxpython/gui_core/prompt.py
   grass/trunk/gui/wxpython/nviz/main.py
   grass/trunk/gui/wxpython/nviz/mapwindow.py
   grass/trunk/gui/wxpython/nviz/tools.py
   grass/trunk/gui/wxpython/nviz/wxnviz.py
wxGUI: fixes for Python 3 - 3D view and running commands from command console
Modified: grass/trunk/gui/wxpython/gui_core/prompt.py
--- grass/trunk/gui/wxpython/gui_core/prompt.py	2018-09-16 03:19:01 UTC (rev 73340)
+++ grass/trunk/gui/wxpython/gui_core/prompt.py	2018-09-16 03:21:45 UTC (rev 73341)
@@ -118,7 +118,7 @@
             cmd = utils.split(str(cmdString))
         except UnicodeError:
             cmd = utils.split(EncodeString((cmdString)))
-        cmd = map(DecodeString, cmd)
+        cmd = list(map(DecodeString, cmd))
         self.promptRunCmd.emit(cmd=cmd)
Modified: grass/trunk/gui/wxpython/nviz/main.py
--- grass/trunk/gui/wxpython/nviz/main.py	2018-09-16 03:19:01 UTC (rev 73340)
+++ grass/trunk/gui/wxpython/nviz/main.py	2018-09-16 03:21:45 UTC (rev 73341)
@@ -24,7 +24,7 @@
     from nviz import mapwindow
     from nviz import tools
     from nviz import workspace
-    import wxnviz
+    from nviz import wxnviz
     haveNviz = True
 except (ImportError, NameError) as err:
     haveNviz = False
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py	2018-09-16 03:19:01 UTC (rev 73340)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py	2018-09-16 03:21:45 UTC (rev 73341)
@@ -24,7 +24,6 @@
 import time
 import copy
 import math
-import types
 from threading import Thread
@@ -238,7 +237,7 @@
             wx.CallLater(3000, self._warningDepthBuffer)
         # cplanes cannot be initialized now
-        wx.CallAfter(self.InitCPlanes)
+        wx.CallLater(1000, self.InitCPlanes)
     def _warningDepthBuffer(self):
         if not self.initView:
@@ -1485,11 +1484,11 @@
                     if sec1 == 'position':
                         data[sec][sec1]['update'] = None
                         continue
-                    if isinstance(data[sec][sec1], types.DictType):
+                    if isinstance(data[sec][sec1], dict):
                         for sec2 in data[sec][sec1].keys():
                             if sec2 not in ('all', 'init', 'id'):
                                 data[sec][sec1][sec2]['update'] = None
-                    elif isinstance(data[sec][sec1], types.ListType):
+                    elif isinstance(data[sec][sec1], list):
                         for i in range(len(data[sec][sec1])):
                             for sec2 in data[sec][sec1][i].keys():
                                 data[sec][sec1][i][sec2]['update'] = None
@@ -1932,7 +1931,7 @@
                 elif attrb == 'transp':
                     self._display.UnsetSurfaceTransp(id)
             else:
-                if isinstance(value, types.StringType):
+                if isinstance(value, str):
                     if len(value) == 0:  # ignore empty values (TODO: warning)
                         continue
                     if map and not grass.find_file(value, element='cell')[
@@ -2048,7 +2047,7 @@
                         self._display.UnsetIsosurfaceTransp(id, isosurfId)
                 else:
                             continue
                         if map and not grass.find_file(value, element='grid3')[
Modified: grass/trunk/gui/wxpython/nviz/tools.py
--- grass/trunk/gui/wxpython/nviz/tools.py	2018-09-16 03:19:01 UTC (rev 73340)
+++ grass/trunk/gui/wxpython/nviz/tools.py	2018-09-16 03:21:45 UTC (rev 73341)
@@ -22,7 +22,6 @@
 import os
 import sys
 import copy
-import types
 import six
 import wx
@@ -3504,22 +3503,22 @@
         for key, item in six.iteritems(self.win[name]):
             if key in ('map', 'surface', 'new', 'planes'):
                 continue
-            if isinstance(item, types.DictType):
+            if isinstance(item, dict):
                 for skey, sitem in six.iteritems(self.win[name][key]):
-                    if isinstance(sitem, types.DictType):
+                    if isinstance(sitem, dict):
                         for ssitem in six.itervalues(self.win[name][key][skey]):
-                            if not isinstance(ssitem, types.BooleanType) and \
-                               isinstance(ssitem, types.IntType):
+                            if not isinstance(ssitem, bool) and \
+                               isinstance(ssitem, int):
                                 self.FindWindowById(ssitem).Enable(enabled)
                     else:
                         # type(bool) != types.IntType but
                         # isinstance(bool) == types.IntType
-                        if not isinstance(sitem, types.BooleanType) and \
-                           isinstance(sitem, types.IntType):
+                        if not isinstance(sitem, bool) and \
+                           isinstance(sitem, int):
                             self.FindWindowById(sitem).Enable(enabled)
             else:
-                if not isinstance(item, types.BooleanType) and \
-                   isinstance(item, types.IntType):
+                if not isinstance(item, bool) and \
+                   isinstance(item, int):
                     self.FindWindowById(item).Enable(enabled)
     def SetMapObjUseMap(self, nvizType, attrb, map=None):
@@ -4898,8 +4897,8 @@
         except:  # TODO disabled page
             planeIndex = -1
-        if event.GetId() in (self.win['cplane']['rotation']['rot'].values() +
-                             self.win['cplane']['rotation']['tilt'].values()):
+        if event.GetId() in (list(self.win['cplane']['rotation']['rot'].values()) +
+                             list(self.win['cplane']['rotation']['tilt'].values())):
             action = 'rotation'
         else:
             action = 'position'
@@ -5281,7 +5280,7 @@
                     self.win['surface']['color']['map']).SetValue(value)
             else:  # constant
-                color = map(int, value.split(':'))
+                color = list(map(int, value.split(':')))
                     self.win['surface']['color']['const']).SetColour(color)
             self.SetMapObjUseMap(
@@ -5362,7 +5361,7 @@
             if name == "selection":
                 win.SetSelection(value)
             elif name == "colour":
                 win.SetColour(color)
             else:
                 win.SetValue(value)
@@ -5434,7 +5433,7 @@
         width.SetValue(data['lines']['width']['value'])
         color = self.FindWindowById(self.win['vector']['lines']['color'])
-        color.SetValue(map(int, data['lines']['color']['value'].split(':')))
+        color.SetValue(list(map(int, data['lines']['color']['value'].split(':'))))
         for vtype in ('lines', 'points'):
             if vtype == 'lines':
@@ -5490,7 +5489,7 @@
             if name == 'selection':
                 win.SetSelection(data['points'][prop]['value'])
             elif name == 'color':
-                color = map(int, data['points'][prop]['value'].split(':'))
+                color = list(map(int, data['points'][prop]['value'].split(':')))
                 win.SetValue(color)
             else:
                 win.SetValue(data['points'][prop]['value'])
@@ -5616,7 +5615,7 @@
                         self.win['volume'][attrb]['map']).SetValue(value)
                 else:  # constant
                         self.win['volume'][attrb]['const']).SetColour(color)
             else:
Modified: grass/trunk/gui/wxpython/nviz/wxnviz.py
--- grass/trunk/gui/wxpython/nviz/wxnviz.py	2018-09-16 03:19:01 UTC (rev 73340)
+++ grass/trunk/gui/wxpython/nviz/wxnviz.py	2018-09-16 03:21:45 UTC (rev 73341)
@@ -59,7 +59,7 @@
 from core.debug import Debug
 from core.utils import _, autoCropImageFromFile
-from core.gcmd import EncodeString
+from core.gcmd import EncodeString, DecodeString
 from core.globalvar import wxPythonPhoenix
 from gui_core.wrap import Rect
 import grass.script as grass
@@ -72,6 +72,8 @@
     """Redirect stderr"""
     global log
     if log:
+        if sys.version_info.major >= 3:
+            msg = DecodeString(msg.data)
         log.write(msg)
     else:
         print(msg)
