[GRASS-SVN] r73348 - in grass/trunk/gui/wxpython: core lmgr xml
svn_grass at osgeo.org
Sun Sep 16 12:21:48 PDT 2018
Author: wenzeslaus
Date: 2018-09-16 12:21:47 -0700 (Sun, 16 Sep 2018)
New Revision: 73348
grass/trunk/gui/wxpython/core/workspace.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/xml/grass-gxw.dtd
wxGUI: save database, location and mapset to workspace and switch it when opening it (closes #3575)
It is no longer possible to just open workspace in a different mapset
than the one where it was saved. However, when session element is not
present (deleted or older gxw file) no mapset switching is performed.
Older versions of GRASS GIS simply ignore the session element.
An error message is given when mapset does not exist and options to
proceed or not are given with some details (can be improved by
diagnostics from grass.py if moved to library).
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py 2018-09-16 16:56:01 UTC (rev 73347)
+++ grass/trunk/gui/wxpython/core/workspace.py 2018-09-16 19:21:47 UTC (rev 73348)
@@ -29,6 +29,14 @@
from grass.script import core as gcore
+def get_database_location_mapset():
+ """Returns GRASS database, location, and mapset as a tuple"""
+ gisenv = gcore.gisenv()
+ return (gisenv['GISDBASE'],
+ gisenv['LOCATION_NAME'],
+ gisenv['MAPSET'])
class ProcessWorkspaceFile:
def __init__(self, tree):
@@ -95,6 +103,9 @@
def __processFile(self):
"""Process workspace file"""
+ self.__processSession()
# layer manager
@@ -177,6 +188,17 @@
# process nviz_state
self.__processNvizState(display)
+ def __processSession(self):
+ session = self.root.find('session')
+ if session is None:
+ self.database = None
+ self.location = None
+ self.mapset = None
+ return
+ self.database = self.__filterValue(self.__getNodeText(session, 'database'))
+ self.location = self.__filterValue(self.__getNodeText(session, 'location'))
+ self.mapset = self.__filterValue(self.__getNodeText(session, 'mapset'))
def __processLayers(self, node, inGroup=-1):
"""Process layers/groups of selected display
@@ -813,6 +835,19 @@
self.indent = + 4
+ database, location, mapset = get_database_location_mapset()
+ file.write('{indent}<session>\n'.format(indent=' ' * self.indent))
+ self.indent += 4
+ file.write('{indent}<database>{database}</database>\n'.format(
+ indent=' ' * self.indent, database=database))
+ file.write('{indent}<location>{location}</location>\n'.format(
+ indent=' ' * self.indent, location=location))
+ file.write('{indent}<mapset>{mapset}</mapset>\n'.format(
+ indent=' ' * self.indent, mapset=mapset))
+ self.indent -= 4
+ file.write('{indent}</session>\n'.format(indent=' ' * self.indent))
# layer manager
windowPos = self.lmgr.GetPosition()
windowSize = self.lmgr.GetSize()
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2018-09-16 16:56:01 UTC (rev 73347)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2018-09-16 19:21:47 UTC (rev 73348)
@@ -1375,6 +1375,41 @@
self.workspaceFile = filename
self._setTitle()
+ def _tryToSwitchMapsetFromWorkspaceFile(self, gxwXml):
+ returncode, errors = RunCommand('g.mapset',
+ dbase=gxwXml.database,
+ location=gxwXml.location,
+ mapset=gxwXml.mapset,
+ getErrorMsg=True,
+ if returncode != 0:
+ # TODO: use the function from grass.py
+ reason = _("Most likely the database, location or mapset"
+ " does not exist")
+ details = errors
+ message = _("Unable to change to location and mapset"
+ " specified in the workspace.\n"
+ "Reason: {reason}\nDetails: {details}\n\n"
+ "Do you want to proceed with opening"
+ " the workspace anyway?"
+ ).format(**locals())
+ dlg = wx.MessageDialog(
+ parent=self, message=message, caption=_(
+ "Proceed with opening of the workspace?"),
+ style=wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION)
+ dlg.CenterOnParent()
+ if dlg.ShowModal() in [wx.ID_NO, wx.ID_CANCEL]:
+ return False
+ else:
+ # TODO: copy from ChangeLocation function
+ GMessage(
+ parent=self,
+ message=_("Current location is <%(loc)s>.\n"
+ "Current mapset is <%(mapset)s>.") %
+ {'loc': gxwXml.location,
+ 'mapset': gxwXml.mapset})
+ return True
def LoadWorkspaceFile(self, filename):
"""Load layer tree definition stored in GRASS Workspace XML file (gxw)
@@ -1393,8 +1428,13 @@
"Reading workspace file <%s> failed.\n"
"Invalid file, unable to parse XML document.") %
filename)
- return
+ return False
+ if gxwXml.database and gxwXml.location and gxwXml.mapset:
+ if not self._tryToSwitchMapsetFromWorkspaceFile(gxwXml):
+ return False
+ # the really busy part starts here (mapset change is fast)
busy = wx.BusyInfo(_("Please wait, loading workspace..."),
parent=self)
wx.Yield()
Modified: grass/trunk/gui/wxpython/xml/grass-gxw.dtd
--- grass/trunk/gui/wxpython/xml/grass-gxw.dtd 2018-09-16 16:56:01 UTC (rev 73347)
+++ grass/trunk/gui/wxpython/xml/grass-gxw.dtd 2018-09-16 19:21:47 UTC (rev 73348)
@@ -14,8 +14,13 @@
<!ELEMENT grass-gxw (gxw)>
-<!ELEMENT gxw (layer_manager?, display*)>
+<!ELEMENT gxw (session?, layer_manager?, display*)>
+<!ELEMENT session (database, location, mapset)>
+<!ELEMENT database (#PCDATA)>
+<!ELEMENT location (#PCDATA)>
+<!ELEMENT mapset (#PCDATA)>
<!-- a layer_manager defines properties of Layer Manager
GUI component
