[GRASS-SVN] r73349 - in grass-addons/grass7/raster: r.connectivity/r.connectivity.corridors r.connectivity/r.connectivity.network r.green/r.green.gshp/r.green.gshp.technical r.green/r.green.gshp/r.green.gshp.theoretical r.green/r.green.hydro/r.green.hydro.closest r.green/r.green.hydro/r.green.hydro.discharge r.green/r.green.hydro/r.green.hydro.planning r.green/r.green.hydro/r.green.hydro.recommended r.green/r.green.hydro/r.green.hydro.technical r.green/r.green.hydro/r.green.hydro.theoretical r.green/r.green.install
svn_grass at osgeo.org
Sun Sep 16 14:04:38 PDT 2018
Author: neteler
Date: 2018-09-16 14:04:38 -0700 (Sun, 16 Sep 2018)
New Revision: 73349
grass-addons/grass7/raster/r.connectivity/r.connectivity.corridors/r.connectivity.corridors.py
grass-addons/grass7/raster/r.connectivity/r.connectivity.network/r.connectivity.network.py
grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.technical/r.green.gshp.technical.py
grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.theoretical/r.green.gshp.theoretical.py
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.closest/r.green.hydro.closest.py
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.planning/r.green.hydro.planning.py
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
addons: fix keywords
Modified: grass-addons/grass7/raster/r.connectivity/r.connectivity.corridors/r.connectivity.corridors.py
--- grass-addons/grass7/raster/r.connectivity/r.connectivity.corridors/r.connectivity.corridors.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.connectivity/r.connectivity.corridors/r.connectivity.corridors.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -57,9 +57,11 @@
#%Module
#% description: Compute corridors between habitat patches of an input-layer based on (cost) distance raster maps
-#% keywords: corridor
-#% keywords: cost distance
-#% keywords: least cost paths
+#% keyword: raster
+#% keyword: vector
+#% keyword: corridor
+#% keyword: cost distance
+#% keyword: least cost paths
#%End
#%option G_OPT_V_INPUT
Modified: grass-addons/grass7/raster/r.connectivity/r.connectivity.network/r.connectivity.network.py
--- grass-addons/grass7/raster/r.connectivity/r.connectivity.network/r.connectivity.network.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.connectivity/r.connectivity.network/r.connectivity.network.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -79,9 +79,11 @@
#%Module
#% description: Compute connectivity measures for a set of habitat patches based on graph-theory
-#% keywords: graph theory
-#% keywords: network
-#% keywords: network analysis
+#% keyword: raster
+#% keyword: vector
+#% keyword: graph theory
+#% keyword: network
+#% keyword: network analysis
#%End
Modified: grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.technical/r.green.gshp.technical.py
--- grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.technical/r.green.gshp.technical.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.technical/r.green.gshp.technical.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -5,7 +5,7 @@
# MODULE: r.green.gshp.technical
# AUTHOR(S): Pietro Zambelli
-# PURPOSE: Calculate the ground source heat pump technical poential using
+# PURPOSE: Calculate the ground source heat pump technical potential using
# the ASHRAE method
# COPYRIGHT: (C) 2017 by the GRASS Development Team
@@ -18,7 +18,9 @@
#%module
#% description: Calculate the Ground Source Heat Pump technical potential using the ASHRAE method.
-#% keywords: raster
+#% keyword: raster
+#% keyword: geothermal
+#% keyword: renewable energy
#%end
Modified: grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.theoretical/r.green.gshp.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.theoretical/r.green.gshp.theoretical.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.gshp/r.green.gshp.theoretical/r.green.gshp.theoretical.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -17,7 +17,9 @@
#%module
#% description: Calculate the Ground Source Heat Pump potential
+#% keyword: raster
#%end
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.closest/r.green.hydro.closest.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.closest/r.green.hydro.closest.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.closest/r.green.hydro.closest.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -17,7 +17,9 @@
#%module
#% description: Move points to the closest vector map
-#% keywords: vector
+#% keyword: vector
+#% keyword: hydropower
#%end
#% key: points
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -17,7 +17,9 @@
#%module
#% description: Calculate average natural discharge and minimum flow following regional law an
+#% keyword: raster
#% overwrite: yes
#%end
#%option G_OPT_R_INPUT
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.planning/r.green.hydro.planning.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.planning/r.green.hydro.planning.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.planning/r.green.hydro.planning.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -18,7 +18,9 @@
#%module
#% description: Calculate hydropower energy potential with user's recommendations
+#% keyword: raster
#%end
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.recommended/r.green.hydro.recommended.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -18,7 +18,7 @@
#%module
+#% keyword: raster
#%end
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -17,8 +17,10 @@
#%module
-#% description: Hydropower potential with technical constrains
+#% description: Hydropower potential with technical constraints
+#% keyword: raster
#% overwrite: yes
#%end
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.theoretical/r.green.hydro.theoretical.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -17,9 +17,9 @@
#%module
#% description: Calculate the hydropower energy potential for each basin starting from discharge and elevation data. If existing plants are available it computes the potential installed power in the available part of the rivers.
-#% keywords: hydropower
-#% keywords: renewable energy
+#% keyword: raster
#%end
#%option G_OPT_R_ELEV
#% required: yes
Modified: grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py
--- grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2018-09-16 19:21:47 UTC (rev 73348)
+++ grass-addons/grass7/raster/r.green/r.green.install/r.green.install.py 2018-09-16 21:04:38 UTC (rev 73349)
@@ -16,8 +16,9 @@
#%module
-#% description: Check if evrything is corectly installed and configured
+#% description: Check if everything of r.green is correctly installed and configured
+#% keyword: raster
#%end
#%flag
#% key: i
