[GRASS-SVN] r73372 - grass/branches/releasebranch_7_6/raster/r.fill.stats
Wed Sep 19 06:51:49 PDT 2018
Author: neteler
Date: 2018-09-19 06:51:49 -0700 (Wed, 19 Sep 2018)
New Revision: 73372
   grass/branches/releasebranch_7_6/raster/r.fill.stats/r.fill.stats.html
r.fill.stats manual: example added (derived from r.fillnulls example) (trunk, r73371)
Modified: grass/branches/releasebranch_7_6/raster/r.fill.stats/r.fill.stats.html
--- grass/branches/releasebranch_7_6/raster/r.fill.stats/r.fill.stats.html	2018-09-19 13:51:06 UTC (rev 73371)
+++ grass/branches/releasebranch_7_6/raster/r.fill.stats/r.fill.stats.html	2018-09-19 13:51:49 UTC (rev 73372)
@@ -1,13 +1,12 @@
 <h2>DESCRIPTION</h2>
 <em><b>r.fill.stats</b></em> is a module for fast gap filling and
 interpolation (with smoothing) of dense raster data.
 <p>
-The <em>r.fill.stats</em> module is capable of quickly filling small
-data gaps in large and high-resolution raster maps. It's primary purpose
+The <em>r.fill.stats</em> module is capable of quickly filling <b>small
+data gaps</b> in large and high-resolution raster maps. It's primary purpose
 is to improve high-resolution, rasterized sensor data (such as Lidar
 data). As a rule of thumb, there
 should be at least as many data cells as there are "no data" (NULL) cells in
@@ -367,6 +366,8 @@
 <h2>EXAMPLES</h2>
+<h3>Gap-filling of a dataset using spatially weighted mean (IDW)</h3>
 Gap-fill a dataset using spatially weighted mean (IDW) and a maximum
 search radius of 3.0 map units; also produce uncertainty estimation
 map:
@@ -464,6 +465,39 @@
 d.mon stop=cairo
+<h3>Outlier removal and gap-filling of SRTM elevation data</h3>
+In this example, the SRTM elevation map in the
+North Carolina sample dataset location is filtered for outlier
+elevation values; missing pixels are then re-interpolated to obtain
+a complete elevation map:
+<div class="code"><pre>
+g.region raster=elev_srtm_30m -p
+d.mon wx0
+d.histogram elev_srtm_30m
+# remove SRTM outliers, i.e. SRTM below 50m (esp. lakes), leading to no data areas
+r.mapcalc "elev_srtm_30m_filt = if(elev_srtm_30m < 50.0, null(), elev_srtm_30m)"
+d.histogram elev_srtm_30m_filt
+d.rast elev_srtm_30m_filt
+# using the IDW method to fill these holes in DEM without low-pass filter
+# increase distance to gap-fill larger holes
+r.fill.stats -k input=elev_srtm_30m_filt output=elev_srtm_30m_idw distance=100
+d.histogram elev_srtm_30m_idw
+d.rast elev_srtm_30m_idw
+r.mapcalc "diff_orig_idw = elev_srtm_30m - elev_srtm_30m_idw"
+r.colors diff_orig_idw color=differences
+r.univar -e diff_orig_idw
+d.erase
+d.rast diff_orig_idw
+d.legend diff_orig_idw
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
