[GRASS-SVN] r73373 - grass/trunk/vector/v.univar
Wed Sep 19 07:31:56 PDT 2018
Author: neteler
Date: 2018-09-19 07:31:56 -0700 (Wed, 19 Sep 2018)
New Revision: 73373
   grass/trunk/vector/v.univar/v.univar.html
v.univar manual: beautify example section
Modified: grass/trunk/vector/v.univar/v.univar.html
--- grass/trunk/vector/v.univar/v.univar.html	2018-09-19 13:51:49 UTC (rev 73372)
+++ grass/trunk/vector/v.univar/v.univar.html	2018-09-19 14:31:56 UTC (rev 73373)
@@ -31,10 +31,12 @@
 	between areas)</li>
 </ul>
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
-The example is based on the North Carolina sample dataset:
+The examples are based on the North Carolina sample dataset.
+<h3>Example dataset preparation</h3>
 <div class="code"><pre>
 g.region raster=elevation -p
 v.random output=samples npoints=100
@@ -43,7 +45,7 @@
 v.db.select map=samples
 </pre></div>
-Calculate height attribute statistics:
+<h3>Calculate height attribute statistics</h3>
 v.univar -e samples column=heights type=point
@@ -70,7 +72,7 @@
 90th percentile: 135.023
 </pre></div>
-Compare to statistics of original raster map:
+<h3>Compare to statistics of original raster map</h3>
 r.univar -e elevation
@@ -96,7 +98,7 @@
 90th percentile: 138.66
 </pre></div>
-Calculate distance between sampling points statistics:
+<h3>Calculate statistic of distance between sampling points</h3>
 v.univar -d samples column=heights type=point
