[GRASS-SVN] r73901 - grass/trunk/vector/v.overlay
svn_grass at osgeo.org
Wed Jan 2 04:32:46 PST 2019
Author: mmetz
Date: 2019-01-02 04:32:46 -0800 (Wed, 02 Jan 2019)
New Revision: 73901
grass/trunk/vector/v.overlay/area_area.c
v.overlay: speedup for large, complex input areas
Modified: grass/trunk/vector/v.overlay/area_area.c
--- grass/trunk/vector/v.overlay/area_area.c 2019-01-01 18:28:34 UTC (rev 73900)
+++ grass/trunk/vector/v.overlay/area_area.c 2019-01-02 12:32:46 UTC (rev 73901)
@@ -18,7 +18,10 @@
/* for ilist qsort'ing and bsearch'ing */
static int cmp_int(const void *a, const void *b)
- return (*(int *)a - *(int *)b);
+ if (*(int *)a < *(int *)b)
+ return -1;
+ return (*(int *)a > *(int *)b);
int area_area(struct Map_info *In, int *field, struct Map_info *Tmp,
@@ -35,6 +38,12 @@
dbString stmt;
int nmodif;
int verbose;
+ struct bound_box box;
+ struct spatial_index si;
+ int ocentr, ncentr;
+ int isle, nisles_alloc;
+ struct line_pnts *APoints, **IPoints;
+ struct ilist *List;
verbose = G_verbose();
@@ -44,7 +53,6 @@
/* optional snap */
if (snap > 0) {
int i, j, snapped_lines = 0;
- struct bound_box box;
struct boxlist *boxlist = Vect_new_boxlist(0);
struct ilist *reflist = Vect_new_list();
@@ -85,9 +93,14 @@
/* snap bline to alines */
if (Vect_snap_line(Tmp, reflist, Points, snap, 0, NULL, NULL)) {
/* rewrite bline*/
+#if 0
Vect_delete_line(Tmp, line);
ret = Vect_write_line(Tmp, GV_BOUNDARY, Points, Cats);
G_ilist_add(BList, ret);
+#else
+ ret = Vect_rewrite_line(Tmp, line, GV_BOUNDARY, Points, Cats);
+#endif
snapped_lines++;
G_debug(3, "line %d snapped", line);
@@ -176,44 +189,106 @@
+ /* build a spatial index for new centroids */
+ Vect_spatial_index_init(&si, 0);
+ ncentr = nareas;
+ for (ocentr = 1; ocentr <= ncentr; ocentr++) {
+ box.N = box.S = Centr[ocentr].y;
+ box.E = box.W = Centr[ocentr].x;
+ box.T = box.B = 0;
+ Vect_spatial_index_add_item(&si, ocentr, &box);
+ Centr[ocentr].cat[0] = Vect_new_cats_struct();
+ Centr[ocentr].cat[1] = Vect_new_cats_struct();
+ nisles_alloc = 10;
+ IPoints = G_malloc(nisles_alloc * sizeof(struct line_pnts *));
+ for (isle = 0; isle < nisles_alloc; isle++)
+ IPoints[isle] = Vect_new_line_struct();
+ APoints = Vect_new_line_struct();
+ List = Vect_new_list();
/* Query input maps */
for (input = 0; input < 2; input++) {
G_message(_("Querying vector map <%s>..."),
Vect_get_full_name(&(In[input])));
+ nareas = Vect_get_num_areas(&(In[input]));
+ G_percent(0, nareas, 1);
for (area = 1; area <= nareas; area++) {
- Centr[area].cat[input] = Vect_new_cats_struct();
G_percent(area, nareas, 1);
- in_area =
- Vect_find_area(&(In[input]), Centr[area].x, Centr[area].y);
- if (in_area > 0) {
- in_centr = Vect_get_area_centroid(&(In[input]), in_area);
- if (in_centr > 0) {
- int i;
+ in_centr = Vect_get_area_centroid(&(In[input]), area);
+ if (in_centr > 0) {
+ int i, j;
+ int nisles;
- Vect_read_line(&(In[input]), NULL, Cats, in_centr);
- /* Add all cats with original field number */
- for (i = 0; i < Cats->n_cats; i++) {
- if (Cats->field[i] == field[input]) {
- ATTR *at;
+ Vect_read_line(&(In[input]), NULL, Cats, in_centr);
+ Vect_get_area_points(&(In[input]), area, APoints);
+ nisles = Vect_get_area_num_isles(&(In[input]), area);
+ if (nisles > nisles_alloc) {
+ IPoints = G_realloc(IPoints, (nisles + 10) * sizeof(struct line_pnts *));
+ for (isle = nisles_alloc; isle < nisles + 10; isle++)
+ nisles_alloc = nisles + 10;
+ for (isle = 0; isle < nisles; isle++) {
+ int isle_id = Vect_get_area_isle(&(In[input]), area, isle);
- Vect_cat_set(Centr[area].cat[input], field[input],
- Cats->cat[i]);
+ Vect_get_isle_points(&(In[input]), isle_id, IPoints[isle]);
- /* Mark as used */
- at = find_attr(&(attr[input]), Cats->cat[i]);
- if (!at)
- G_fatal_error(_("Attribute not found"));
+ Vect_line_box(APoints, &box);
+ /* centroid's z is set to zero */
- at->used = 1;
+ Vect_spatial_index_select(&si, &box, List);
+ for (j = 0; j < List->n_values; j++) {
+ int centr_in_area;
+ ocentr = List->value[j];
+ centr_in_area = Vect_point_in_poly(Centr[ocentr].x,
+ Centr[ocentr].y,
+ APoints);
+ if (centr_in_area == 1) {
+ if (Vect_point_in_poly(Centr[ocentr].x,
+ Centr[ocentr].y,
+ IPoints[isle]) > 0) {
+ centr_in_area = 0;
+ break;
+ if (centr_in_area > 0) {
+ /* Add all cats with original field number */
+ for (i = 0; i < Cats->n_cats; i++) {
+ if (Cats->field[i] == field[input]) {
+ ATTR *at;
+ Vect_cat_set(Centr[ocentr].cat[input], field[input],
+ Cats->cat[i]);
+ /* Mark as used */
+ at = find_attr(&(attr[input]), Cats->cat[i]);
+ if (!at)
+ G_fatal_error(_("Attribute not found"));
+ at->used = 1;
+ Vect_spatial_index_destroy(&si);
+ nareas = Vect_get_num_areas(Tmp);
G_message(_("Writing centroids..."));
@@ -374,6 +449,8 @@
Vect_build_partial(Tmp, GV_BUILD_CENTROIDS);
G_set_verbose(verbose);
/* Copy valid boundaries to final output */
+ G_message(_("Copying results to final output map..."));
nlines = Vect_get_num_lines(Tmp);
for (line = 1; line <= nlines; line++) {
