[GRASS-SVN] r73950 - grass/branches/releasebranch_7_6/vector/v.select/testsuite
Wed Jan 16 06:54:50 PST 2019
Author: neteler
Date: 2019-01-16 06:54:50 -0800 (Wed, 16 Jan 2019)
New Revision: 73950
   grass/branches/releasebranch_7_6/vector/v.select/testsuite/test_v_select.py
v.select/testsuite: fix tearDown(), test now succeeds (trunk, r73949)
Modified: grass/branches/releasebranch_7_6/vector/v.select/testsuite/test_v_select.py
--- grass/branches/releasebranch_7_6/vector/v.select/testsuite/test_v_select.py	2019-01-16 14:54:09 UTC (rev 73949)
+++ grass/branches/releasebranch_7_6/vector/v.select/testsuite/test_v_select.py	2019-01-16 14:54:50 UTC (rev 73950)
@@ -30,8 +30,8 @@
     def tearDownClass(cls):
         cls.del_temp_region()
-    def tearDown(self):
-        self.runModule('g.remove', type='vector', flags='f', name=cls.output)
+    def tearDown(cls):
+        cls.runModule('g.remove', type='vector', flags='f', name=cls.output)
     def test_opo(self):
         """Testing operator overlap"""
