[GRASS-SVN] r73951 - grass/trunk/testsuite
Wed Jan 16 08:12:59 PST 2019
Author: neteler
Date: 2019-01-16 08:12:59 -0800 (Wed, 16 Jan 2019)
New Revision: 73951
Added:
   grass/trunk/testsuite/test_framework_GRASS_GIS_with_NC.sh
   grass/trunk/testsuite/README
test_framework_GRASS_GIS_with_NC.sh: script added to easily run test framework based on NC full dataset. Note: script requires configuration to local system in initial part. Online version at http://fatra.cnr.ncsu.edu/grassgistests/summary_report/
Modified: grass/trunk/testsuite/README
--- grass/trunk/testsuite/README	2019-01-16 14:54:50 UTC (rev 73950)
+++ grass/trunk/testsuite/README	2019-01-16 16:12:59 UTC (rev 73951)
@@ -1,8 +1,11 @@
-This directory contains scripts to check the functionality
-of GRASS.
-They may be launched in ../demolocation/
+This directory contains scripts to check the functionality of GRASS GIS.
+Some tests may be launched in ../demolocation/ .
+Most test require the North Carolina Sample dataset, available from
+https://grass.osgeo.org/sampledata/north_carolina/
 For a more advanced test suite, see
- http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/?C=M;O=D
+ http://fatra.cnr.ncsu.edu/grassgistests/summary_report/
Added: grass/trunk/testsuite/test_framework_GRASS_GIS_with_NC.sh
--- grass/trunk/testsuite/test_framework_GRASS_GIS_with_NC.sh	                        (rev 0)
+++ grass/trunk/testsuite/test_framework_GRASS_GIS_with_NC.sh	2019-01-16 16:12:59 UTC (rev 73951)
@@ -0,0 +1,146 @@
+#!/bin/bash
+# MODULE:       r.drain
+# AUTHOR(S):    Markus Neteler, Sören Gebbert, Vaclav Petras
+# PURPOSE:      Test GRASS GIS using the test framework
+#               Documentation:
+#                 https://trac.osgeo.org/grass/wiki/GSoC/2014/TestingFrameworkForGRASS
+#                 https://grass.osgeo.org/grass76/manuals/libpython/gunittest_running_tests.html#example-bash-script-to-run-be-used-as-a-cron-job
+#               Data:
+#                 Since we use the full NC dataset (nc_spm_08_grass7.tar.gz) here, we need to generate
+#                 some simplified names as used in NC basic for some test cases. This happens automatically below.
+# COPYRIGHT:    (C) 2019 by Markus Neteler, and the GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+### CONFIGURATION
+# computer architecture:
+ARCH=x86_64-pc-linux-gnu
+# name of binary:
+GRASSBIN=grass77
+# source code directory as full path:
+GRASSSRC="$HOME/software/grass77"
+# temporary grassdata directory
+GRASSDATA="$HOME/grassdata/tests-grassdata"
+# Python binary to be used (python|python3)
+PYTHON=python
+# here we suppose default compilation settings of GRASS GIS and no 'make install'
+# may be no|yes
+COMPILE="no"
+# configure metascript with compiler flags:
+CONFIGURE="${GRASSSRC}/conf_grass7.sh"
+# directory to store reports, e.g. in a subdirectory
+REPORTS="testreports"
+# publish report on WWW Server (not needed for local tests)
+# may be no|yes
+PUBLISH="no"
+# upload WWW dir on server for report publication (not used for local tests)
+SERVERDIR="/var/www/html/grassgistestreports"
+######### nothing to change below
+set -e  # fail fast
+# here we suppose default compilation settings of GRASS GIS and no make install
+GRASSBIN="$GRASSSRC/bin.${ARCH}/${GRASSBIN}"
+GRASSDIST="$GRASSSRC/dist.${ARCH}"
+# necessary hardcoded GRASS paths
+GRASSDIST_PYTHON="$GRASSDIST/etc/python"
+GRASS_MULTI_RUNNER="$GRASSSRC/lib/python/gunittest/multirunner.py"
+GRASS_MULTI_REPORTER="$GRASSSRC/lib/python/gunittest/multireport.py"
+DATE_FLAGS="--utc +%Y-%m-%d-%H-%M"
+NOW=$(date $DATE_FLAGS)
+# get number of processors of current machine
+MYNPROC=`getconf _NPROCESSORS_ONLN`
+# leave one PROC free for other tasks
+GCCTHREADS=`expr $MYNPROC - 1`
+# contains last executed command stdout and stderr
+# here were rely on reports being absolute
+OUTPUT_LOGFILE="$REPORTS/output-$NOW.txt"
+# these are relative to REPORTS
+CURRENT_REPORT_BASENAME="reports_for_date-"
+FINAL_REPORT_DIR="summary_report"
+CURRENT_REPORTS_DIR="$CURRENT_REPORT_BASENAME$NOW"
+LOGFILE="$REPORTS/runs.log"
+mkdir -p $REPORTS/$CURRENT_REPORTS_DIR
+mkdir -p $GRASSDATA
+# fetch sample data
+SAMPLEDATA=nc_spm_08_grass7.tar.gz
+(cd $GRASSDATA ; wget -c https://grass.osgeo.org/sampledata/north_carolina/$SAMPLEDATA ; tar xfz $SAMPLEDATA )
+echo "Nightly GRASS GIS test started: $NOW" >> ${LOGFILE}
+# Preparation: Since we use the full NC dataset, we need to generate some simplified names as used in NC basic for some test cases
+echo "
+g.copy raster=basin_50K,basin
+g.copy raster=boundary_county_500m,boundary
+g.copy raster=landcover_1m,landcover
+g.copy raster=geology_30m,geology
+g.copy raster=landuse96,landuse
+g.copy raster=soilsID,soils
+g.copy vector=zipcodes_wake,zipcodes
+g.copy vector=schools_wake,schools
+" > $GRASSDATA/tmp_rename.sh
+$GRASSBIN $GRASSDATA/nc_spm_08_grass7/PERMANENT --exec sh $GRASSDATA/tmp_rename.sh
+rm -f $GRASSDATA/tmp_rename.sh
+if [ "$COMPILE" = "yes" ] ; then
+   ## compile current source code from scratch
+   cd $GRASSSRC
+   make distclean -j$GCCTHREADS
+   svn update
+   ./$CONFIGURE ...  # configure meta script containing all the compiler flags
+   make -j$GCCTHREADS
+fi
+# run tests for the current source code
+cd $REPORTS/$CURRENT_REPORTS_DIR
+$PYTHON $GRASS_MULTI_RUNNER \
+    --grassbin $GRASSBIN \
+    --grasssrc $GRASSSRC \
+    --grassdata $GRASSDATA \
+    --location nc_spm_08_grass7 --location-type nc \
+    --location other_location --location-type other_type
+# create overall report of all so far executed tests
+# the script depends on GRASS but just Python part is enough
+export PYTHONPATH="$GRASSDIST_PYTHON:$PYTHONPATH"
+$PYTHON $GRASS_MULTI_REPORTER --output $FINAL_REPORT_DIR \
+    $CURRENT_REPORT_BASENAME*/*
+# publish on Web site
+if [ "$PUBLISH" = "yes" ] ; then
+   ## although we cannot be sure the tests were executed was successfully
+   ## so publish or archive results
+   rsync -rtvu --delete $REPORTS/ $SERVERDIR
+fi
+echo "Nightly ($NOW) GRASS GIS test finished: $(date $DATE_FLAGS)" >> ${LOGFILE}
+exit 0
Property changes on: grass/trunk/testsuite/test_framework_GRASS_GIS_with_NC.sh
___________________________________________________________________
Added: svn:executable
## -0,0 +1 ##
\ No newline at end of property
