[GRASS-SVN] r73966 - grass-addons/grass7/raster/r.fidimo
svn_grass at osgeo.org
Thu Jan 17 12:42:28 PST 2019
Author: neteler
Date: 2019-01-17 12:42:28 -0800 (Thu, 17 Jan 2019)
New Revision: 73966
grass-addons/grass7/raster/r.fidimo/r.fidimo.py
r.fidimo addon: converted tab to space indentation using pycharm tool; tabs are to be avoided, see https://trac.osgeo.org/grass/wiki/Submitting/Python?version=19#Editorsettingsfor4-spaceindentation
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2019-01-17 20:15:48 UTC (rev 73965)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2019-01-17 20:42:28 UTC (rev 73966)
@@ -209,17 +209,17 @@
tmp_map_vect = None
def cleanup():
- if (tmp_map_rast or tmp_map_vect) and not flags['a']:
- grass.run_command("g.remove",
+ if (tmp_map_rast or tmp_map_vect) and not flags['a']:
+ grass.run_command("g.remove",
flags = 'f',
- type = 'raster',
+ type = 'raster',
name = [f + str(os.getpid()) for f in tmp_map_rast],
- quiet = True)
+ quiet = True)
flags = 'f',
- type = 'vector',
+ type = 'vector',
name = [f + str(os.getpid()) for f in tmp_map_vect],
- quiet = True)
+ quiet = True)
@@ -226,909 +226,909 @@
def main():
- # lazy import required numpy and scipy modules
- import numpy
- from scipy import stats
- from scipy import optimize
+ # lazy import required numpy and scipy modules
+ import numpy
+ from scipy import stats
+ from scipy import optimize
- ############ DEFINITION CLEANUP TEMPORARY FILES ##############
- #global variables for cleanup
- global tmp_map_rast
- global tmp_map_vect
+ ############ DEFINITION CLEANUP TEMPORARY FILES ##############
+ #global variables for cleanup
+ global tmp_map_rast
+ global tmp_map_vect
- tmp_map_rast = ['density_final_','density_final_corrected_','density_from_point_tmp_', 'density_from_point_unmasked_tmp_', 'distance_from_point_tmp_', 'distance_raster_tmp_', 'distance_raster_buffered_tmp_', "distance_raster_buffered_div_tmp_", 'distance_raster_grow_tmp_', 'division_overlay_tmp_', 'downstream_drain_tmp_', 'drainage_tmp_', 'flow_direction_tmp_', 'lower_distance_tmp_', 'realised_density_final_','rel_upstream_shreve_tmp_', 'river_raster_cat_tmp_', 'river_raster_tmp_', 'river_raster_combine_tmp_', 'river_raster_buffer_tmp_', 'river_raster_grow_start_tmp_', 'river_raster_nearest_tmp_', 'shreve_tmp_', 'source_populations_scalar_tmp_','source_populations_scalar_corrected_tmp_', 'strahler_tmp_', 'stream_rwatershed_tmp_', 'upper_distance_tmp_', 'upstream_part_tmp_', 'upstream_shreve_tmp_']
+ tmp_map_rast = ['density_final_','density_final_corrected_','density_from_point_tmp_', 'density_from_point_unmasked_tmp_', 'distance_from_point_tmp_', 'distance_raster_tmp_', 'distance_raster_buffered_tmp_', "distance_raster_buffered_div_tmp_", 'distance_raster_grow_tmp_', 'division_overlay_tmp_', 'downstream_drain_tmp_', 'drainage_tmp_', 'flow_direction_tmp_', 'lower_distance_tmp_', 'realised_density_final_','rel_upstream_shreve_tmp_', 'river_raster_cat_tmp_', 'river_raster_tmp_', 'river_raster_combine_tmp_', 'river_raster_buffer_tmp_', 'river_raster_grow_start_tmp_', 'river_raster_nearest_tmp_', 'shreve_tmp_', 'source_populations_scalar_tmp_','source_populations_scalar_corrected_tmp_', 'strahler_tmp_', 'stream_rwatershed_tmp_', 'upper_distance_tmp_', 'upstream_part_tmp_', 'upstream_shreve_tmp_']
- tmp_map_vect = ['river_points_tmp_', 'river_vector_tmp_', 'river_vector_nocat_tmp_','source_points_']
+ tmp_map_vect = ['river_points_tmp_', 'river_vector_tmp_', 'river_vector_nocat_tmp_','source_points_']
- if options['barriers']:
- tmp_map_rast = tmp_map_rast + ['downstream_barrier_density_tmp_','distance_barrier_tmp_','distance_downstream_barrier_tmp_', 'distance_upstream_point_tmp_','inv_distance_downstream_barrier_tmp_', 'lower_distance_barrier_tmp_', 'upper_distance_barrier_tmp_', 'upstream_barrier_tmp_', 'upstream_barrier_density_tmp_']
- tmp_map_vect = tmp_map_vect + ["barriers_",'barriers_tmp_']
+ if options['barriers']:
+ tmp_map_rast = tmp_map_rast + ['downstream_barrier_density_tmp_','distance_barrier_tmp_','distance_downstream_barrier_tmp_', 'distance_upstream_point_tmp_','inv_distance_downstream_barrier_tmp_', 'lower_distance_barrier_tmp_', 'upper_distance_barrier_tmp_', 'upstream_barrier_tmp_', 'upstream_barrier_density_tmp_']
+ tmp_map_vect = tmp_map_vect + ["barriers_",'barriers_tmp_']
- ############ PARAMETER INPUT ##############
- #Stream parameters input
- river = options['river']
- coors = options['coors']
+ ############ PARAMETER INPUT ##############
+ #Stream parameters input
+ river = options['river']
+ coors = options['coors']
- # Barrier input
- input_barriers = options['barriers'].split('@')[0]
- # check if barrier file exists in current mapset (Problem when file in other mapset!!!!)
- if not grass.find_file(name = input_barriers, element = 'vector')['file']:
- grass.fatal(_("Barriers map not found in current mapset"))
- # check if passability_col is provided and existing
- if not options['passability_col']:
- grass.fatal(_("Please provide column name that holds the barriers' passability values ('passability_col')"))
- if not options['passability_col'] in grass.read_command("db.columns", table=input_barriers).split('\n'):
- grass.fatal(_("Please provide correct column name that holds the barriers' passability values ('passability_col')"))
- passability_col = options['passability_col']
+ # Barrier input
+ input_barriers = options['barriers'].split('@')[0]
+ # check if barrier file exists in current mapset (Problem when file in other mapset!!!!)
+ if not grass.find_file(name = input_barriers, element = 'vector')['file']:
+ grass.fatal(_("Barriers map not found in current mapset"))
+ # check if passability_col is provided and existing
+ if not options['passability_col']:
+ grass.fatal(_("Please provide column name that holds the barriers' passability values ('passability_col')"))
+ if not options['passability_col'] in grass.read_command("db.columns", table=input_barriers).split('\n'):
+ grass.fatal(_("Please provide correct column name that holds the barriers' passability values ('passability_col')"))
+ passability_col = options['passability_col']
- # Source population input
- if (options['source_populations'] and options['n_source']) or (str(options['source_populations']) == '' and str(options['n_source']) == ''):
- grass.fatal(_("Provide either fixed or random source population"))
- if options['n_source'] and flags['r']:
- grass.fatal(_("Realisation (flag: 'r') in combination with random source populations (n_source) not possible. Please choose either random source populations or provide source populations to calculate realisation"))
- n_source = options['n_source'] #number of random source points
- source_populations = options['source_populations']
+ # Source population input
+ if (options['source_populations'] and options['n_source']) or (str(options['source_populations']) == '' and str(options['n_source']) == ''):
+ grass.fatal(_("Provide either fixed or random source population"))
+ if options['n_source'] and flags['r']:
+ grass.fatal(_("Realisation (flag: 'r') in combination with random source populations (n_source) not possible. Please choose either random source populations or provide source populations to calculate realisation"))
+ n_source = options['n_source'] #number of random source points
+ source_populations = options['source_populations']
- # Habitat attractivity maps
- if options['habitat_attract']:
- habitat_attract = options['habitat_attract']
- # multiplication value as workaround for very small FLOAT values
- #imporatant for transformation of source population raster into point vector
- scalar = 10000
+ # Habitat attractivity maps
+ if options['habitat_attract']:
+ habitat_attract = options['habitat_attract']
- # Statistical interval
- if (str(options['statistical_interval']) == 'Prediction Interval'):
- interval = "prediction"
- else:
- interval = "confidence"
+ # multiplication value as workaround for very small FLOAT values
+ #imporatant for transformation of source population raster into point vector
+ scalar = 10000
+ # Statistical interval
+ if (str(options['statistical_interval']) == 'Prediction Interval'):
+ interval = "prediction"
+ else:
+ interval = "confidence"
- #Output
- output_fidimo = options['output']
- if (grass.find_file(name = output_fidimo+"_"+"fit", element = 'cell')['file'] and not grass.overwrite()):
- grass.fatal(_("Output file exists already, either change output name or set overwrite-flag"))
+ #Output
+ output_fidimo = options['output']
+ if (grass.find_file(name = output_fidimo+"_"+"fit", element = 'cell')['file'] and not grass.overwrite()):
+ grass.fatal(_("Output file exists already, either change output name or set overwrite-flag"))
- ############ FISHMOVE ##############
- # import required rpy2 module
- import rpy2.robjects as robjects
- from rpy2.robjects.packages import importr
- fm = importr('fishmove')
- #Dispersal parameter input
- if str(options['species']!="Custom species") and (options['l'] or options['ar']):
- grass.message(_("Species settings will be overwritten with l and ar"))
- species = str(options['species'])
- if options['l']:
- l = float(options['l'])
- if options['ar']:
- ar = float(options['ar'])
- t = float(options['t'])
- # Setting Stream order to a vector of 1:9 and calculate fishmove for all streamorders at once
- so = robjects.IntVector((1,2,3,4,5,6,7,8,9))
- m = 0 # m-parameter in dispersal function
- # Share of mobile/stationary individuals
- if options['habitat_p'] or (options['p'] and options['habitat_p']):
- grass.message(_("Map of habitat dependent share of mobile/stationary will be used"))
- habitat_p = options['habitat_p']
- elif (float(options['p']) >= 0 and float(options['p']) < 1):
- p_fixed =float(options['p'])
- else:
- grass.fatal(_("Valid range for p: 0 - 1"))
- ##### Calculating 'fishmove' depending on species or L & AR
- #Set fixed seed if specified
- if options['seed1']:
- seed = ",seed="+str(options['seed1'])
- else:
- seed = ""
+ ############ FISHMOVE ##############
- if species == "Custom species":
- fishmove = eval("fm.fishmove(L=l,AR=ar,SO=so,T=t,interval=interval,rep=200%s)"%(seed))
- else:
+ # import required rpy2 module
+ import rpy2.robjects as robjects
+ from rpy2.robjects.packages import importr
+ fm = importr('fishmove')
+ #Dispersal parameter input
+ if str(options['species']!="Custom species") and (options['l'] or options['ar']):
+ grass.message(_("Species settings will be overwritten with l and ar"))
+ species = str(options['species'])
+ if options['l']:
+ l = float(options['l'])
+ if options['ar']:
+ ar = float(options['ar'])
+ t = float(options['t'])
+ # Setting Stream order to a vector of 1:9 and calculate fishmove for all streamorders at once
+ so = robjects.IntVector((1,2,3,4,5,6,7,8,9))
+ m = 0 # m-parameter in dispersal function
- # using only part of fishmove results (only regression coeffients)
- fishmove = fishmove[1]
- nrun = ['fit','lwr','upr']
+ # Share of mobile/stationary individuals
+ if options['habitat_p'] or (options['p'] and options['habitat_p']):
+ grass.message(_("Map of habitat dependent share of mobile/stationary will be used"))
+ habitat_p = options['habitat_p']
+ elif (float(options['p']) >= 0 and float(options['p']) < 1):
+ p_fixed =float(options['p'])
+ else:
+ grass.fatal(_("Valid range for p: 0 - 1"))
+ ##### Calculating 'fishmove' depending on species or L & AR
+ #Set fixed seed if specified
+ if options['seed1']:
+ seed = ",seed="+str(options['seed1'])
+ else:
+ seed = ""
+ if species == "Custom species":
+ fishmove = eval("fm.fishmove(L=l,AR=ar,SO=so,T=t,interval=interval,rep=200%s)"%(seed))
+ else:
- ############ REGION, DB-CONNECTION ##############
- #Setting region to extent of input River
- grass.run_command("g.region",
- flags = "a",
- rast = river,
- overwrite = True,
- save = "region_Fidimo")
- #Getting resultion, res=cellsize
- res = int(grass.read_command("g.region",
- flags = "m").strip().split('\n')[4].split('=')[1])
+ # using only part of fishmove results (only regression coeffients)
+ fishmove = fishmove[1]
+ nrun = ['fit','lwr','upr']
- #database-connection
- env = grass.gisenv()
- gisdbase = env['GISDBASE']
- location = env['LOCATION_NAME']
- mapset = env['MAPSET']
- grass.run_command("db.connect",
- driver = "sqlite",
- database = "$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db")
- database = sqlite3.connect(os.path.join(gisdbase, location, mapset, 'sqlite.db'))
- db = database.cursor()
+ ############ REGION, DB-CONNECTION ##############
+ #Setting region to extent of input River
+ grass.run_command("g.region",
+ flags = "a",
+ rast = river,
+ overwrite = True,
+ save = "region_Fidimo")
+ #Getting resultion, res=cellsize
+ res = int(grass.read_command("g.region",
+ flags = "m").strip().split('\n')[4].split('=')[1])
+ #database-connection
+ env = grass.gisenv()
+ gisdbase = env['GISDBASE']
+ location = env['LOCATION_NAME']
+ mapset = env['MAPSET']
+ grass.run_command("db.connect",
+ driver = "sqlite",
+ database = "$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db")
+ database = sqlite3.connect(os.path.join(gisdbase, location, mapset, 'sqlite.db'))
+ db = database.cursor()
- ################ Preparation River Raster (Distance-Raster) ################
+ ################ Preparation River Raster (Distance-Raster) ################
- # Populate input-river (raster) with value of resolution
- # *1.0 to get float raster instead of integer
- grass.mapcalc("$river_raster = if(!isnull($river),$res*1.0,null())",
- river_raster = "river_raster_tmp_%d" % os.getpid(),
- river = river,
- res = res,
- overwrite=True)
- # Converting river_raster to river_vector
- grass.run_command("r.to.vect",
- overwrite = True,
- input="river_raster_tmp_%d" % os.getpid(),
- output="river_vector_tmp_%d" % os.getpid(),
- type="line")
- # Converting river_raster to river_point
- overwrite = True,
- output="river_points_tmp_%d" % os.getpid(),
- type="point")
+ # Populate input-river (raster) with value of resolution
+ # *1.0 to get float raster instead of integer
+ grass.mapcalc("$river_raster = if(!isnull($river),$res*1.0,null())",
+ river_raster = "river_raster_tmp_%d" % os.getpid(),
+ river = river,
+ res = res,
+ overwrite=True)
+ # Converting river_raster to river_vector
+ grass.run_command("r.to.vect",
+ overwrite = True,
+ input="river_raster_tmp_%d" % os.getpid(),
+ output="river_vector_tmp_%d" % os.getpid(),
+ type="line")
- #Prepare Barriers/Snap barriers to river_vector
- grass.run_command("g.copy",
- vector = input_barriers + "," + "barriers_tmp_%d" % os.getpid())
+ # Converting river_raster to river_point
+ overwrite = True,
+ output="river_points_tmp_%d" % os.getpid(),
+ type="point")
- grass.run_command("v.db.addcolumn",
- map ="barriers_tmp_%d" % os.getpid(),
- columns="adj_X DOUBLE, adj_Y DOUBLE")
- grass.run_command("v.distance",
- overwrite = True,
- from_="barriers_tmp_%d" % os.getpid(),
- to="river_vector_tmp_%d" % os.getpid(),
- upload="to_x,to_y",
- column="adj_X,adj_Y")
- grass.run_command("v.in.db",
- overwrite = True,
- table="barriers_tmp_%d" % os.getpid(),
- x="adj_X",
- y="adj_Y",
- key="cat",
- output="barriers_%d" % os.getpid())
- map ="barriers_%d" % os.getpid(),
- columns="dist DOUBLE")
- # Making barriers permanent
- vector = "barriers_%d" % os.getpid() + "," + output_fidimo + "_barriers")
- #Breaking river_vector at position of barriers to get segments
- for adj_X,adj_Y in db.execute('SELECT adj_X, adj_Y FROM barriers_%d'% os.getpid()):
- barrier_coors = str(adj_X)+","+str(adj_Y)
- grass.run_command("v.edit",
- map="river_vector_tmp_%d" % os.getpid(),
- tool="break",
- thresh="1,0,0",
- coords=barrier_coors)
- #Getting category values (ASC) for river_network segments
- grass.run_command("v.category",
- overwrite=True,
- input="river_vector_tmp_%d" % os.getpid(),
- option="del",
- output="river_vector_nocat_tmp_%d" % os.getpid())
- overwrite=True,
- input="river_vector_nocat_tmp_%d" % os.getpid(),
- option="add",
- output="river_vector_tmp_%d" % os.getpid())
+ #Prepare Barriers/Snap barriers to river_vector
+ grass.run_command("g.copy",
+ vector = input_barriers + "," + "barriers_tmp_%d" % os.getpid())
+ grass.run_command("v.db.addcolumn",
+ map ="barriers_tmp_%d" % os.getpid(),
+ columns="adj_X DOUBLE, adj_Y DOUBLE")
+ grass.run_command("v.distance",
+ overwrite = True,
+ from_="barriers_tmp_%d" % os.getpid(),
+ to="river_vector_tmp_%d" % os.getpid(),
+ upload="to_x,to_y",
+ column="adj_X,adj_Y")
+ grass.run_command("v.in.db",
+ overwrite = True,
+ table="barriers_tmp_%d" % os.getpid(),
+ x="adj_X",
+ y="adj_Y",
+ key="cat",
+ output="barriers_%d" % os.getpid())
+ map ="barriers_%d" % os.getpid(),
+ columns="dist DOUBLE")
+ # Making barriers permanent
+ vector = "barriers_%d" % os.getpid() + "," + output_fidimo + "_barriers")
+ #Breaking river_vector at position of barriers to get segments
+ for adj_X,adj_Y in db.execute('SELECT adj_X, adj_Y FROM barriers_%d'% os.getpid()):
+ barrier_coors = str(adj_X)+","+str(adj_Y)
- #Check if outflow coors are on river
- # For GRASS7 snap coors to river. Check r.stream.snap - add on
+ grass.run_command("v.edit",
+ map="river_vector_tmp_%d" % os.getpid(),
+ tool="break",
+ thresh="1,0,0",
+ coords=barrier_coors)
- #Calculation of distance from outflow and flow direction for total river
- grass.run_command("r.cost",
- flags = 'n',
- overwrite = True,
- input = "river_raster_tmp_%d" % os.getpid(),
- output = "distance_raster_tmp_%d" % os.getpid(),
- start_coordinates = coors)
+ #Getting category values (ASC) for river_network segments
+ grass.run_command("v.category",
+ overwrite=True,
+ input="river_vector_tmp_%d" % os.getpid(),
+ option="del",
+ output="river_vector_nocat_tmp_%d" % os.getpid())
+ overwrite=True,
+ input="river_vector_nocat_tmp_%d" % os.getpid(),
+ option="add",
+ output="river_vector_tmp_%d" % os.getpid())
- largest_cost_value = grass.raster_info("distance_raster_tmp_%d" % os.getpid())['max']
- # buffer
- grass.run_command("r.grow.distance",
- overwrite=True,
- input="distance_raster_tmp_%d" % os.getpid(),
- value="river_raster_nearest_tmp_%d" % os.getpid())
- #get value of nearest river cell
- grass.run_command("r.grow",
- overwrite=True,
- output="distance_raster_grow_tmp_%d" % os.getpid(),
- radius=2.01,
- old=1,
- new=largest_cost_value*2)
+ #Check if outflow coors are on river
+ # For GRASS7 snap coors to river. Check r.stream.snap - add on
- # remove buffer for start
- grass.mapcalc("$river_raster_grow_start_tmp = if($river_raster_nearest_tmp==0,null(),$distance_raster_grow_tmp)",
- river_raster_grow_start_tmp = "river_raster_grow_start_tmp_%d" % os.getpid(),
- river_raster_nearest_tmp = "river_raster_nearest_tmp_%d" % os.getpid(),
- distance_raster_grow_tmp = "distance_raster_grow_tmp_%d" % os.getpid())
- #grow by one cell to make sure taht the start point is the only cell
- overwrite=True,
- input="river_raster_grow_start_tmp_%d" % os.getpid(),
- output="river_raster_buffer_tmp_%d" % os.getpid(),
- radius=1.01,
- old=largest_cost_value*2,
+ #Calculation of distance from outflow and flow direction for total river
+ grass.run_command("r.cost",
+ flags = 'n',
+ overwrite = True,
+ input = "river_raster_tmp_%d" % os.getpid(),
+ output = "distance_raster_tmp_%d" % os.getpid(),
+ start_coordinates = coors)
- #patch river raster with buffer
- grass.run_command("r.patch",
- overwrite=True,
- input="distance_raster_tmp_%d,river_raster_buffer_tmp_%d" % (os.getpid(),os.getpid()),
- output="distance_raster_buffered_tmp_%d" % os.getpid())
- # Get maximum value and divide if to large (>2200000)
- max_buffer = grass.raster_info("distance_raster_buffered_tmp_%d" % os.getpid())['max']
- if max_buffer>2100000:
- grass.message(_("River network is very large and r.watershed (and e.g stream order extract) might not work"))
- grass.mapcalc("$distance_raster_buffered_div = $distance_raster_buffered/1000.0",
- distance_raster_buffered_div = "distance_raster_buffered_div_tmp_%d" % os.getpid(),
- distance_raster_buffered = "distance_raster_buffered_tmp_%d" % os.getpid())
- # Getting flow direction and stream segments
- grass.run_command("r.watershed",
- flags = 'm', #depends on memory!! #
- elevation = "distance_raster_buffered_div_tmp_%d" % os.getpid(),
- drainage = "drainage_tmp_%d" % os.getpid(),
- stream = "stream_rwatershed_tmp_%d" % os.getpid(),
- threshold = 3,
- overwrite = True)
+ largest_cost_value = grass.raster_info("distance_raster_tmp_%d" % os.getpid())['max']
- else:
- elevation = "distance_raster_buffered_tmp_%d" % os.getpid(),
- threshold = 3,
- overwrite = True)
- grass.mapcalc("$flow_direction_tmp = if($stream_rwatershed_tmp,$drainage_tmp,null())",
- flow_direction_tmp = "flow_direction_tmp_%d" % os.getpid(),
- stream_rwatershed_tmp = "stream_rwatershed_tmp_%d" % os.getpid(),
- drainage_tmp = "drainage_tmp_%d" % os.getpid())
+ # buffer
+ grass.run_command("r.grow.distance",
+ overwrite=True,
+ input="distance_raster_tmp_%d" % os.getpid(),
+ value="river_raster_nearest_tmp_%d" % os.getpid())
- # Stream segments depicts new river_raster (corrected for small tributaries of 1 cell)
- grass.mapcalc("$river_raster_combine_tmp = if(!isnull($stream_rwatershed_tmp) && !isnull($river_raster_tmp),$res*1.0,null())",
- river_raster_combine_tmp = "river_raster_combine_tmp_%d" % os.getpid(),
- river_raster_tmp = "river_raster_tmp_%d" % os.getpid(),
- res = res)
- overwrite=True,
- raster = "river_raster_combine_tmp_%d" % os.getpid() + "," "river_raster_tmp_%d" % os.getpid())
+ #get value of nearest river cell
+ grass.run_command("r.grow",
+ overwrite=True,
+ output="distance_raster_grow_tmp_%d" % os.getpid(),
+ radius=2.01,
+ old=1,
+ new=largest_cost_value*2)
+ # remove buffer for start
+ grass.mapcalc("$river_raster_grow_start_tmp = if($river_raster_nearest_tmp==0,null(),$distance_raster_grow_tmp)",
+ river_raster_grow_start_tmp = "river_raster_grow_start_tmp_%d" % os.getpid(),
+ river_raster_nearest_tmp = "river_raster_nearest_tmp_%d" % os.getpid(),
+ distance_raster_grow_tmp = "distance_raster_grow_tmp_%d" % os.getpid())
- #Calculation of stream order (Shreve/Strahler)
- grass.run_command("r.stream.order",
- stream_rast = "stream_rwatershed_tmp_%d" % os.getpid(),
- direction = "flow_direction_tmp_%d" % os.getpid(),
- shreve = "shreve_tmp_%d" % os.getpid(),
- strahler = "strahler_tmp_%d" % os.getpid(),
- overwrite = True)
+ #grow by one cell to make sure taht the start point is the only cell
+ overwrite=True,
+ input="river_raster_grow_start_tmp_%d" % os.getpid(),
+ output="river_raster_buffer_tmp_%d" % os.getpid(),
+ radius=1.01,
+ old=largest_cost_value*2,
+ #patch river raster with buffer
+ grass.run_command("r.patch",
+ overwrite=True,
+ input="distance_raster_tmp_%d,river_raster_buffer_tmp_%d" % (os.getpid(),os.getpid()),
+ output="distance_raster_buffered_tmp_%d" % os.getpid())
+ # Get maximum value and divide if to large (>2200000)
+ max_buffer = grass.raster_info("distance_raster_buffered_tmp_%d" % os.getpid())['max']
+ if max_buffer>2100000:
+ grass.message(_("River network is very large and r.watershed (and e.g stream order extract) might not work"))
+ grass.mapcalc("$distance_raster_buffered_div = $distance_raster_buffered/1000.0",
+ distance_raster_buffered_div = "distance_raster_buffered_div_tmp_%d" % os.getpid(),
+ distance_raster_buffered = "distance_raster_buffered_tmp_%d" % os.getpid())
+ # Getting flow direction and stream segments
+ grass.run_command("r.watershed",
+ flags = 'm', #depends on memory!! #
+ elevation = "distance_raster_buffered_div_tmp_%d" % os.getpid(),
+ drainage = "drainage_tmp_%d" % os.getpid(),
+ stream = "stream_rwatershed_tmp_%d" % os.getpid(),
+ threshold = 3,
+ overwrite = True)
- ################ Preparation Source Populations ################
- #Defining source points either as random points in river or from input raster
- if options['n_source']:
- grass.run_command("r.random",
- overwrite=True,
- n = n_source,
- vector_output="source_points_%d" % os.getpid())
- map = "source_points_%d" % os.getpid(),
- columns = "n_fish INT, prob_scalar DOUBLE")
+ else:
+ elevation = "distance_raster_buffered_tmp_%d" % os.getpid(),
+ threshold = 3,
+ overwrite = True)
+ grass.mapcalc("$flow_direction_tmp = if($stream_rwatershed_tmp,$drainage_tmp,null())",
+ flow_direction_tmp = "flow_direction_tmp_%d" % os.getpid(),
+ stream_rwatershed_tmp = "stream_rwatershed_tmp_%d" % os.getpid(),
+ drainage_tmp = "drainage_tmp_%d" % os.getpid())
- # Set starting propability of occurence to 1.0*scalar for all random source_points
- grass.write_command("db.execute", input="-",
- stdin = 'UPDATE source_points_%d SET prob_scalar=%d' % (os.getpid(),scalar*1.0))
- stdin = 'UPDATE source_points_%d SET n_fish=%d' % (os.getpid(),1.0))
+ # Stream segments depicts new river_raster (corrected for small tributaries of 1 cell)
+ grass.mapcalc("$river_raster_combine_tmp = if(!isnull($stream_rwatershed_tmp) && !isnull($river_raster_tmp),$res*1.0,null())",
+ river_raster_combine_tmp = "river_raster_combine_tmp_%d" % os.getpid(),
+ river_raster_tmp = "river_raster_tmp_%d" % os.getpid(),
+ res = res)
+ overwrite=True,
+ raster = "river_raster_combine_tmp_%d" % os.getpid() + "," "river_raster_tmp_%d" % os.getpid())
- #if source population raster is provided, then use it, transform raster in vector points
- #create an attribute column "prob_scalar" and "n_fish" and update it with the values from the raster map
- if options['source_populations']:
- #Multiplying source probability with very large scalar to avoid problems
- #with very small floating points (problem: precision of FLOAT); needs retransforamtion in the end
- grass.mapcalc("$source_populations_scalar_tmp = $source_populations*$scalar",
- source_populations = source_populations,
- source_populations_scalar_tmp = "source_populations_scalar_tmp_%d" % os.getpid(),
- scalar = scalar)
- #Exclude source Populations that are outside the river_raster
- grass.mapcalc("$source_populations_scalar_corrected_tmp = if($river_raster_tmp,$source_populations_scalar_tmp)",
- source_populations_scalar_corrected_tmp = "source_populations_scalar_corrected_tmp_%d" % os.getpid(),
- source_populations_scalar_tmp = "source_populations_scalar_tmp_%d" % os.getpid())
- # Convert to source population points
- overwrite = True,
- input = "source_populations_scalar_corrected_tmp_%d" % os.getpid(),
- output = "source_points_%d" % os.getpid(),
- type = "point")
+ #Calculation of stream order (Shreve/Strahler)
+ grass.run_command("r.stream.order",
+ stream_rast = "stream_rwatershed_tmp_%d" % os.getpid(),
+ direction = "flow_direction_tmp_%d" % os.getpid(),
+ shreve = "shreve_tmp_%d" % os.getpid(),
+ strahler = "strahler_tmp_%d" % os.getpid(),
+ overwrite = True)
- #populate n_fish and sample prob from input sourcepopulations raster (multiplied by scalar)
- if flags['r']:
- grass.run_command("v.what.rast",
- raster = source_populations,
- column = "n_fish")
- raster = "source_populations_scalar_tmp_%d" % os.getpid(),
- column = "prob_scalar")
- #Adding columns and coordinates to source points
- columns = "X DOUBLE, Y DOUBLE, segment INT, Strahler INT, habitat_attract DOUBLE, p DOUBLE")
- grass.run_command("v.to.db",
- type = "point",
- option = "coor",
- columns = "X,Y")
- #Convert river from vector to raster format and get cat-value
- grass.run_command("v.to.rast",
- input = "river_vector_tmp_%d" % os.getpid(),
- overwrite = True,
- output = "river_raster_cat_tmp_%d" % os.getpid(),
- use = "cat")
- #Adding information of segment to source points
- raster = "river_raster_cat_tmp_%d" % os.getpid(),
- column = "segment")
- #Adding information of Strahler stream order to source points
- raster = "strahler_tmp_%d" % os.getpid(),
- column = "Strahler")
- #Adding information of habitat attractivenss to source points
- raster = habitat_attract,
- column = "habitat_attract")
- #Adding information of p (share of stationary/mobiles) to source points
- if options['habitat_p']:
- raster = habitat_p,
- column = "p")
- else:
- grass.run_command("v.db.update",
- value = p_fixed,
- column = "p")
+ ################ Preparation Source Populations ################
+ #Defining source points either as random points in river or from input raster
+ if options['n_source']:
+ grass.run_command("r.random",
+ overwrite=True,
+ n = n_source,
+ vector_output="source_points_%d" % os.getpid())
+ map = "source_points_%d" % os.getpid(),
+ columns = "n_fish INT, prob_scalar DOUBLE")
- # Make source points permanent
- vector = "source_points_%d" % os.getpid() + "," + output_fidimo + "_source_points")
- ########### Looping over nrun, over segements, over source points ##########
- if str(options['statistical_interval']) == "no" or str(options['statistical_interval']) == "Random Value within Confidence Interval":
- nrun = ['fit']
- else:
- for i in nrun:
- #update database-connection
+ # Set starting propability of occurence to 1.0*scalar for all random source_points
+ grass.write_command("db.execute", input="-",
+ stdin = 'UPDATE source_points_%d SET prob_scalar=%d' % (os.getpid(),scalar*1.0))
+ stdin = 'UPDATE source_points_%d SET n_fish=%d' % (os.getpid(),1.0))
- mapcalc_list_Ba = []
- mapcalc_list_Bb = []
+ #if source population raster is provided, then use it, transform raster in vector points
+ #create an attribute column "prob_scalar" and "n_fish" and update it with the values from the raster map
+ if options['source_populations']:
+ #Multiplying source probability with very large scalar to avoid problems
+ #with very small floating points (problem: precision of FLOAT); needs retransforamtion in the end
+ grass.mapcalc("$source_populations_scalar_tmp = $source_populations*$scalar",
+ source_populations = source_populations,
+ source_populations_scalar_tmp = "source_populations_scalar_tmp_%d" % os.getpid(),
+ scalar = scalar)
+ #Exclude source Populations that are outside the river_raster
+ grass.mapcalc("$source_populations_scalar_corrected_tmp = if($river_raster_tmp,$source_populations_scalar_tmp)",
+ source_populations_scalar_corrected_tmp = "source_populations_scalar_corrected_tmp_%d" % os.getpid(),
+ source_populations_scalar_tmp = "source_populations_scalar_tmp_%d" % os.getpid())
- ########## Loop over segments ############
- # Extract Segments-Info to loop over
- segment_list = grass.read_command("db.select", flags="c", sql= "SELECT segment FROM source_points_%d" % os.getpid()).split("\n")[:-1] # remove last (empty line)
- segment_list = map(int, segment_list)
- segment_list = sorted(list(set(segment_list)))
- for j in segment_list:
+ # Convert to source population points
+ overwrite = True,
+ input = "source_populations_scalar_corrected_tmp_%d" % os.getpid(),
+ output = "source_points_%d" % os.getpid(),
+ type = "point")
- segment_cat = str(j)
- grass.debug(_("This is segment nr.: " +str(segment_cat)))
+ #populate n_fish and sample prob from input sourcepopulations raster (multiplied by scalar)
+ if flags['r']:
+ grass.run_command("v.what.rast",
+ raster = source_populations,
+ column = "n_fish")
- mapcalc_list_Aa = []
- mapcalc_list_Ab = []
+ raster = "source_populations_scalar_tmp_%d" % os.getpid(),
+ column = "prob_scalar")
- # Loop over Source points
- source_points_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, X, Y, n_fish, prob_scalar, Strahler, habitat_attract, p FROM source_points_%d WHERE segment=%d" % (os.getpid(),int(j))).split("\n")[:-1] # remove last (empty line)
- source_points_list = list(csv.reader(source_points_list,delimiter="|"))
+ #Adding columns and coordinates to source points
+ columns = "X DOUBLE, Y DOUBLE, segment INT, Strahler INT, habitat_attract DOUBLE, p DOUBLE")
+ grass.run_command("v.to.db",
+ type = "point",
+ option = "coor",
+ columns = "X,Y")
- for k in source_points_list:
- cat = int(k[0])
- X = float(k[1])
- Y = float(k[2])
- prob_scalar = float(k[4])
- Strahler = int(k[5])
- coors = str(X)+","+str(Y)
- if flags['r']:
- n_fish = int(k[3])
- source_habitat_attract = float(k[6])
- p = float(k[7])
+ #Convert river from vector to raster format and get cat-value
+ grass.run_command("v.to.rast",
+ input = "river_vector_tmp_%d" % os.getpid(),
+ overwrite = True,
+ output = "river_raster_cat_tmp_%d" % os.getpid(),
+ use = "cat")
- # Progress bar
- # add here progressbar
+ #Adding information of segment to source points
+ raster = "river_raster_cat_tmp_%d" % os.getpid(),
+ column = "segment")
+ #Adding information of Strahler stream order to source points
+ raster = "strahler_tmp_%d" % os.getpid(),
+ column = "Strahler")
+ #Adding information of habitat attractivenss to source points
+ raster = habitat_attract,
+ column = "habitat_attract")
- # Debug messages
- grass.debug(_("Start looping over source points"))
- grass.debug(_("Source point coors:"+coors+" in segment nr: " +str(segment_cat)))
- #Select dispersal parameters
- SO = 'SO='+str(Strahler)
- grass.debug(_("This is i:"+str(i)))
- grass.debug(_("This is "+str(SO)))
- #if Random Value within Confidence Interval than select a sigma value that is within the CI assuming a normal distribution of sigma within the CI
- if str(options['statistical_interval']) == "Random Value within Confidence Interval":
- random.seed(int(options['seed1']))
- sigma_stat = random.gauss(mu=fishmove.rx("fit",'sigma_stat',1,1,SO,1)[0],
- sigma=(fishmove.rx("upr",'sigma_stat',1,1,SO,1)[0]-fishmove.rx("lwr",'sigma_stat',1,1,SO,1)[0])/4)
- sigma_mob = random.gauss(mu=fishmove.rx("fit",'sigma_mob',1,1,SO,1)[0],
- sigma=(fishmove.rx("upr",'sigma_mob',1,1,SO,1)[0]-fishmove.rx("lwr",'sigma_mob',1,1,SO,1)[0])/4)
- else:
- sigma_stat = fishmove.rx(i,'sigma_stat',1,1,SO,1)
- sigma_mob = fishmove.rx(i,'sigma_mob',1,1,SO,1)
+ #Adding information of p (share of stationary/mobiles) to source points
+ if options['habitat_p']:
+ raster = habitat_p,
+ column = "p")
+ else:
+ grass.run_command("v.db.update",
+ value = p_fixed,
+ column = "p")
+ # Make source points permanent
+ vector = "source_points_%d" % os.getpid() + "," + output_fidimo + "_source_points")
- grass.debug(_("Dispersal parameters: prob_scalar="+str(prob_scalar)+", sigma_stat="+str(sigma_stat)+", sigma_mob="+str(sigma_mob)+", p="+str(p)))
+ ########### Looping over nrun, over segements, over source points ##########
- # Getting maximum distance (cutting distance) based on truncation criterion
- def func(x,sigma_stat,sigma_mob,m,truncation,p):
- return p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob) - truncation
- if options['truncation'] == "inf":
- max_dist = 0
- else:
- truncation = float(options['truncation'])
- max_dist = int(optimize.zeros.newton(func, 1., args=(sigma_stat,sigma_mob,m,truncation,p)))
+ if str(options['statistical_interval']) == "no" or str(options['statistical_interval']) == "Random Value within Confidence Interval":
+ nrun = ['fit']
+ else:
- grass.debug(_("Distance from each source point is calculated up to a treshold of: "+str(max_dist)))
+ for i in nrun:
+ #update database-connection
- flags = 'n',
- overwrite = True,
- output = "distance_from_point_tmp_%d" % os.getpid(),
- start_coordinates = coors,
- max_cost = max_dist)
+ mapcalc_list_Ba = []
+ mapcalc_list_Bb = []
- # Getting upper and lower distance (cell boundaries) based on the fact that there are different flow lenghts through a cell depending on the direction (diagonal-orthogonal)
- grass.mapcalc("$upper_distance = if($flow_direction==2||$flow_direction==4||$flow_direction==6||$flow_direction==8||$flow_direction==-2||$flow_direction==-4||$flow_direction==-6||$flow_direction==-8, $distance_from_point+($ds/2.0), $distance_from_point+($dd/2.0))",
- upper_distance = "upper_distance_tmp_%d" % os.getpid(),
- flow_direction = "flow_direction_tmp_%d" % os.getpid(),
- distance_from_point = "distance_from_point_tmp_%d" % os.getpid(),
- ds = res,
- dd = math.sqrt(2)*res,
- overwrite = True)
- grass.mapcalc("$lower_distance = if($flow_direction==2||$flow_direction==4||$flow_direction==6||$flow_direction==8||$flow_direction==-2||$flow_direction==-4||$flow_direction==-6||$flow_direction==-8, $distance_from_point-($ds/2.0), $distance_from_point-($dd/2.0))",
- lower_distance = "lower_distance_tmp_%d" % os.getpid(),
- ds = res,
- overwrite = True)
- # MAIN PART: leptokurtic probability density kernel based on fishmove
- grass.debug(_("Begin with core of fidimo, application of fishmove on garray"))
- def cdf(x):
- return (p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob)) * prob_scalar
- #Calculation Kernel Density from Distance Raster
- #only for m=0 because of cdf-function
- if grass.find_file(name = "density_from_point_unmasked_tmp_%d" % os.getpid(), element = 'cell')['file']:
- grass.run_command("g.remove", flags = 'f', type = 'raster', name = "density_from_point_unmasked_tmp_%d" % os.getpid())
- x1 = garray.array()
- x1.read("lower_distance_tmp_%d" % os.getpid())
- x2 = garray.array()
- x2.read("upper_distance_tmp_%d" % os.getpid())
- Density = garray.array()
- Density[...] = cdf(x2) - cdf(x1)
- grass.debug(_("Write density from point to garray. unmasked"))
- Density.write("density_from_point_unmasked_tmp_%d" % os.getpid())
+ ########## Loop over segments ############
+ # Extract Segments-Info to loop over
+ segment_list = grass.read_command("db.select", flags="c", sql= "SELECT segment FROM source_points_%d" % os.getpid()).split("\n")[:-1] # remove last (empty line)
+ segment_list = map(int, segment_list)
+ segment_list = sorted(list(set(segment_list)))
- # Mask density output because Density.write doesn't provide nulls()
- grass.mapcalc("$density_from_point = if($distance_from_point>=0, $density_from_point_unmasked, null())",
- density_from_point = "density_from_point_tmp_%d" % os.getpid(),
- density_from_point_unmasked = "density_from_point_unmasked_tmp_%d" % os.getpid(),
- overwrite = True)
+ for j in segment_list:
+ segment_cat = str(j)
+ grass.debug(_("This is segment nr.: " +str(segment_cat)))
- # Defining up and downstream of source point
- grass.debug(_("Defining up and downstream of source point"))
+ mapcalc_list_Aa = []
+ mapcalc_list_Ab = []
- # Defining area upstream source point
- grass.run_command("r.stream.basins",
- overwrite = True,
- coordinates = coors,
- basins = "upstream_part_tmp_%d" % os.getpid())
+ # Loop over Source points
+ source_points_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, X, Y, n_fish, prob_scalar, Strahler, habitat_attract, p FROM source_points_%d WHERE segment=%d" % (os.getpid(),int(j))).split("\n")[:-1] # remove last (empty line)
+ source_points_list = list(csv.reader(source_points_list,delimiter="|"))
- # Defining area downstream source point
- grass.run_command("r.drain",
- input = "distance_raster_tmp_%d" % os.getpid(),
- output = "downstream_drain_tmp_%d" % os.getpid(),
- overwrite = True,
- # Applying upstream split at network nodes based on inverse shreve stream order
- grass.debug(_("Applying upstream split at network nodes based on inverse shreve stream order"))
+ for k in source_points_list:
+ cat = int(k[0])
+ X = float(k[1])
+ Y = float(k[2])
+ prob_scalar = float(k[4])
+ Strahler = int(k[5])
+ coors = str(X)+","+str(Y)
+ if flags['r']:
+ n_fish = int(k[3])
+ source_habitat_attract = float(k[6])
+ p = float(k[7])
+ # Progress bar
+ # add here progressbar
+ # Debug messages
+ grass.debug(_("Start looping over source points"))
+ grass.debug(_("Source point coors:"+coors+" in segment nr: " +str(segment_cat)))
+ #Select dispersal parameters
+ SO = 'SO='+str(Strahler)
+ grass.debug(_("This is i:"+str(i)))
+ grass.debug(_("This is "+str(SO)))
+ #if Random Value within Confidence Interval than select a sigma value that is within the CI assuming a normal distribution of sigma within the CI
+ if str(options['statistical_interval']) == "Random Value within Confidence Interval":
+ random.seed(int(options['seed1']))
+ sigma_stat = random.gauss(mu=fishmove.rx("fit",'sigma_stat',1,1,SO,1)[0],
+ sigma=(fishmove.rx("upr",'sigma_stat',1,1,SO,1)[0]-fishmove.rx("lwr",'sigma_stat',1,1,SO,1)[0])/4)
+ sigma_mob = random.gauss(mu=fishmove.rx("fit",'sigma_mob',1,1,SO,1)[0],
+ sigma=(fishmove.rx("upr",'sigma_mob',1,1,SO,1)[0]-fishmove.rx("lwr",'sigma_mob',1,1,SO,1)[0])/4)
+ else:
+ sigma_stat = fishmove.rx(i,'sigma_stat',1,1,SO,1)
+ sigma_mob = fishmove.rx(i,'sigma_mob',1,1,SO,1)
+ grass.debug(_("Dispersal parameters: prob_scalar="+str(prob_scalar)+", sigma_stat="+str(sigma_stat)+", sigma_mob="+str(sigma_mob)+", p="+str(p)))
+ # Getting maximum distance (cutting distance) based on truncation criterion
+ def func(x,sigma_stat,sigma_mob,m,truncation,p):
+ return p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob) - truncation
+ if options['truncation'] == "inf":
+ max_dist = 0
+ else:
+ truncation = float(options['truncation'])
+ max_dist = int(optimize.zeros.newton(func, 1., args=(sigma_stat,sigma_mob,m,truncation,p)))
+ grass.debug(_("Distance from each source point is calculated up to a treshold of: "+str(max_dist)))
+ flags = 'n',
+ overwrite = True,
+ output = "distance_from_point_tmp_%d" % os.getpid(),
+ start_coordinates = coors,
+ max_cost = max_dist)
+ # Getting upper and lower distance (cell boundaries) based on the fact that there are different flow lenghts through a cell depending on the direction (diagonal-orthogonal)
+ grass.mapcalc("$upper_distance = if($flow_direction==2||$flow_direction==4||$flow_direction==6||$flow_direction==8||$flow_direction==-2||$flow_direction==-4||$flow_direction==-6||$flow_direction==-8, $distance_from_point+($ds/2.0), $distance_from_point+($dd/2.0))",
+ upper_distance = "upper_distance_tmp_%d" % os.getpid(),
+ flow_direction = "flow_direction_tmp_%d" % os.getpid(),
+ distance_from_point = "distance_from_point_tmp_%d" % os.getpid(),
+ ds = res,
+ dd = math.sqrt(2)*res,
+ overwrite = True)
+ grass.mapcalc("$lower_distance = if($flow_direction==2||$flow_direction==4||$flow_direction==6||$flow_direction==8||$flow_direction==-2||$flow_direction==-4||$flow_direction==-6||$flow_direction==-8, $distance_from_point-($ds/2.0), $distance_from_point-($dd/2.0))",
+ lower_distance = "lower_distance_tmp_%d" % os.getpid(),
+ ds = res,
+ overwrite = True)
+ # MAIN PART: leptokurtic probability density kernel based on fishmove
+ grass.debug(_("Begin with core of fidimo, application of fishmove on garray"))
+ def cdf(x):
+ return (p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob)) * prob_scalar
+ #Calculation Kernel Density from Distance Raster
+ #only for m=0 because of cdf-function
+ if grass.find_file(name = "density_from_point_unmasked_tmp_%d" % os.getpid(), element = 'cell')['file']:
+ grass.run_command("g.remove", flags = 'f', type = 'raster', name = "density_from_point_unmasked_tmp_%d" % os.getpid())
+ x1 = garray.array()
+ x1.read("lower_distance_tmp_%d" % os.getpid())
+ x2 = garray.array()
+ x2.read("upper_distance_tmp_%d" % os.getpid())
+ Density = garray.array()
+ Density[...] = cdf(x2) - cdf(x1)
+ grass.debug(_("Write density from point to garray. unmasked"))
+ Density.write("density_from_point_unmasked_tmp_%d" % os.getpid())
+ # Mask density output because Density.write doesn't provide nulls()
+ grass.mapcalc("$density_from_point = if($distance_from_point>=0, $density_from_point_unmasked, null())",
+ density_from_point = "density_from_point_tmp_%d" % os.getpid(),
+ density_from_point_unmasked = "density_from_point_unmasked_tmp_%d" % os.getpid(),
+ overwrite = True)
+ # Defining up and downstream of source point
+ grass.debug(_("Defining up and downstream of source point"))
+ # Defining area upstream source point
+ grass.run_command("r.stream.basins",
+ overwrite = True,
+ coordinates = coors,
+ basins = "upstream_part_tmp_%d" % os.getpid())
+ # Defining area downstream source point
+ grass.run_command("r.drain",
+ input = "distance_raster_tmp_%d" % os.getpid(),
+ output = "downstream_drain_tmp_%d" % os.getpid(),
+ overwrite = True,
+ # Applying upstream split at network nodes based on inverse shreve stream order
+ grass.debug(_("Applying upstream split at network nodes based on inverse shreve stream order"))
- grass.mapcalc("$upstream_shreve = if($upstream_part, $shreve)",
- upstream_shreve = "upstream_shreve_tmp_%d" % os.getpid(),
- upstream_part = "upstream_part_tmp_%d" % os.getpid(),
- overwrite = True)
- max_shreve = grass.raster_info("upstream_shreve_tmp_%d" % os.getpid())['max']
- grass.mapcalc("$rel_upstream_shreve = $upstream_shreve / $max_shreve",
- rel_upstream_shreve = "rel_upstream_shreve_tmp_%d" % os.getpid(),
- max_shreve = max_shreve,
- overwrite = True)
+ grass.mapcalc("$upstream_shreve = if($upstream_part, $shreve)",
+ upstream_shreve = "upstream_shreve_tmp_%d" % os.getpid(),
+ upstream_part = "upstream_part_tmp_%d" % os.getpid(),
+ overwrite = True)
+ max_shreve = grass.raster_info("upstream_shreve_tmp_%d" % os.getpid())['max']
+ grass.mapcalc("$rel_upstream_shreve = $upstream_shreve / $max_shreve",
+ rel_upstream_shreve = "rel_upstream_shreve_tmp_%d" % os.getpid(),
+ max_shreve = max_shreve,
+ overwrite = True)
- grass.mapcalc("$division_overlay = if(isnull($downstream_drain), $rel_upstream_shreve, $downstream_drain)",
- division_overlay = "division_overlay_tmp_%d" % os.getpid(),
- downstream_drain = "downstream_drain_tmp_%d" % os.getpid(),
- overwrite = True)
- grass.mapcalc("$density = if($density_from_point, $density_from_point*$division_overlay, null())",
- density = "density_"+str(cat),
- overwrite = True)
- grass.run_command("r.null", map="density_"+str(cat), null="0")
+ grass.mapcalc("$division_overlay = if(isnull($downstream_drain), $rel_upstream_shreve, $downstream_drain)",
+ division_overlay = "division_overlay_tmp_%d" % os.getpid(),
+ downstream_drain = "downstream_drain_tmp_%d" % os.getpid(),
+ overwrite = True)
+ grass.mapcalc("$density = if($density_from_point, $density_from_point*$division_overlay, null())",
+ density = "density_"+str(cat),
+ overwrite = True)
- ###### Barriers per source point #######
- grass.mapcalc("$distance_upstream_point = if($upstream_part, $distance_from_point, null())",
- distance_upstream_point = "distance_upstream_point_tmp_%d" % os.getpid(),
- upstream_part ="upstream_part_tmp_%d" % os.getpid(),
- overwrite = True)
+ grass.run_command("r.null", map="density_"+str(cat), null="0")
- #Getting distance of barriers and information if barrier is involved/affected
- map = "barriers_%d" % os.getpid(),
- raster = "distance_upstream_point_tmp_%d" % os.getpid(),
- column = "dist")
- # Loop over the affected barriers (from most downstream barrier to most upstream barrier)
- # Initally affected = all barriers where density > 0
- barriers_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, adj_X, adj_Y, dist, %s FROM barriers_%d WHERE dist > 0 ORDER BY dist" % (passability_col,os.getpid())).split("\n")[:-1] # remove last (empty line)
- barriers_list = list(csv.reader(barriers_list,delimiter="|"))
- #if affected barriers then define the last loop (find the upstream most barrier)
- if barriers_list:
- last_barrier = float(barriers_list[-1][3])
+ ###### Barriers per source point #######
+ grass.mapcalc("$distance_upstream_point = if($upstream_part, $distance_from_point, null())",
+ distance_upstream_point = "distance_upstream_point_tmp_%d" % os.getpid(),
+ upstream_part ="upstream_part_tmp_%d" % os.getpid(),
+ overwrite = True)
- for l in barriers_list:
+ #Getting distance of barriers and information if barrier is involved/affected
+ map = "barriers_%d" % os.getpid(),
+ raster = "distance_upstream_point_tmp_%d" % os.getpid(),
+ column = "dist")
- barrier_cat = int(l[0])
- adj_X = float(l[1])
- adj_Y = float(l[2])
- dist = float(l[3])
- passability = float(l[4])
- coors_barriers = str(adj_X)+","+str(adj_Y)
- grass.debug(_("Starting with calculating barriers-effect (coors_barriers: "+coors_barriers+")"))
+ # Loop over the affected barriers (from most downstream barrier to most upstream barrier)
+ # Initally affected = all barriers where density > 0
+ barriers_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, adj_X, adj_Y, dist, %s FROM barriers_%d WHERE dist > 0 ORDER BY dist" % (passability_col,os.getpid())).split("\n")[:-1] # remove last (empty line)
+ barriers_list = list(csv.reader(barriers_list,delimiter="|"))
- #Defining upstream the barrier
- overwrite = True,
- coordinates = coors_barriers,
- basins = "upstream_barrier_tmp_%d" % os.getpid())
+ #if affected barriers then define the last loop (find the upstream most barrier)
+ if barriers_list:
+ last_barrier = float(barriers_list[-1][3])
- grass.run_command("r.null", map="density_"+str(cat), setnull="0")
- #Getting density upstream barrier only
- grass.mapcalc("$upstream_barrier_density = if($upstream_barrier, $density, null())",
- upstream_barrier_density = "upstream_barrier_density_tmp_%d" % os.getpid(),
- upstream_barrier = "upstream_barrier_tmp_%d" % os.getpid(),
- overwrite = True)
- #Getting sum of upstream density and density to relocate downstream
- d = {'n':5, 'min': 6, 'max': 7, 'mean': 9, 'sum': 14, 'median':16, 'range':8}
- univar_upstream_barrier_density = grass.read_command("r.univar", map = "upstream_barrier_density_tmp_%d" % os.getpid(), flags = 'e')
- if univar_upstream_barrier_density:
- sum_upstream_barrier_density = float(univar_upstream_barrier_density.split('\n')[d['sum']].split(':')[1])
- else:
- # if no upstream density to allocate than stop that "barrier-loop" and continue with next barrier
- grass.message(_("No upstream denisty to allocate downstream for that barrier: "+coors_barriers))
- continue
+ for l in barriers_list:
- density_for_downstream = sum_upstream_barrier_density*(1-passability)
- # barrier_effect = Length of Effect of barriers (linear decrease up to max (barrier_effect)
- barrier_effect=200 #units as in mapset (m)
- # Calculating distance from barriers (up- and downstream)
- overwrite = True,
- output = "distance_barrier_tmp_%d" % os.getpid(),
- start_coordinates = coors_barriers,
- max_cost=barrier_effect)
+ barrier_cat = int(l[0])
+ adj_X = float(l[1])
+ adj_Y = float(l[2])
+ dist = float(l[3])
+ passability = float(l[4])
+ coors_barriers = str(adj_X)+","+str(adj_Y)
+ grass.debug(_("Starting with calculating barriers-effect (coors_barriers: "+coors_barriers+")"))
- # Getting distance map for downstream of barrier only
- grass.mapcalc("$distance_downstream_barrier = if(isnull($upstream_barrier), $distance_barrier, null())",
- distance_downstream_barrier = "distance_downstream_barrier_tmp_%d" % os.getpid(),
- distance_barrier = "distance_barrier_tmp_%d" % os.getpid(),
- overwrite = True)
+ #Defining upstream the barrier
+ overwrite = True,
+ coordinates = coors_barriers,
+ basins = "upstream_barrier_tmp_%d" % os.getpid())
- # Getting inverse distance map for downstream of barrier only
- grass.mapcalc("$inv_distance_downstream_barrier = 1.0/$distance_downstream_barrier",
- inv_distance_downstream_barrier = "inv_distance_downstream_barrier_tmp_%d" % os.getpid(),
- overwrite = True)
+ grass.run_command("r.null", map="density_"+str(cat), setnull="0")
- # Getting parameters for distance weighted relocation of densities downstream the barrier (inverse to distance (reciprocal), y=(density/sum(1/distance))/distance)
- univar_distance_downstream_barrier = grass.read_command("r.univar", map = "inv_distance_downstream_barrier_tmp_%d" % os.getpid(), flags = 'e')
- sum_inv_distance_downstream_barrier = float(univar_distance_downstream_barrier.split('\n')[d['sum']].split(':')[1])
- grass.debug(_("sum_inv_distance_downstream_barrier: "+str(sum_inv_distance_downstream_barrier)))
+ #Getting density upstream barrier only
+ grass.mapcalc("$upstream_barrier_density = if($upstream_barrier, $density, null())",
+ upstream_barrier_density = "upstream_barrier_density_tmp_%d" % os.getpid(),
+ upstream_barrier = "upstream_barrier_tmp_%d" % os.getpid(),
+ overwrite = True)
- #Calculation Density downstream the barrier
- grass.mapcalc("$downstream_barrier_density = ($density_for_downstream/$sum_inv_distance_downstream_barrier)/$distance_downstream_barrier",
- downstream_barrier_density = "downstream_barrier_density_tmp_%d" % os.getpid(),
- density_for_downstream=density_for_downstream,
- sum_inv_distance_downstream_barrier = sum_inv_distance_downstream_barrier,
- overwrite = True)
+ #Getting sum of upstream density and density to relocate downstream
+ d = {'n':5, 'min': 6, 'max': 7, 'mean': 9, 'sum': 14, 'median':16, 'range':8}
+ univar_upstream_barrier_density = grass.read_command("r.univar", map = "upstream_barrier_density_tmp_%d" % os.getpid(), flags = 'e')
+ if univar_upstream_barrier_density:
+ sum_upstream_barrier_density = float(univar_upstream_barrier_density.split('\n')[d['sum']].split(':')[1])
+ else:
+ # if no upstream density to allocate than stop that "barrier-loop" and continue with next barrier
+ grass.message(_("No upstream denisty to allocate downstream for that barrier: "+coors_barriers))
+ continue
- # Combination upstream and downstream density from barrier
- grass.run_command("r.null", map="downstream_barrier_density_tmp_%d" % os.getpid(), null="0")
- grass.mapcalc("$density_point = if(isnull($upstream_barrier), $downstream_barrier_density+$density_point, $upstream_barrier_density*$passability)",
- density_point = "density_"+str(cat),
- passability=passability,
- overwrite = True)
- if dist == last_barrier :
- else:
- # Get a list of all densities processed so far within this segement
- mapcalc_list_Aa.append("density_"+str(cat))
+ density_for_downstream = sum_upstream_barrier_density*(1-passability)
- # Multiply (Weight) density point with relative attractiveness. realative attractive in relation to habitat attractivness at source
- grass.mapcalc("$density_point_attract = $density_point*($habitat_attract/$source_habitat_attract)",
- density_point_attract = "density_attract_"+str(cat),
- habitat_attract = habitat_attract,
- source_habitat_attract = source_habitat_attract,
- overwrite = True)
- grass.run_command("g.rename",
- raster = "density_attract_"+str(cat) + "," + "density_"+str(cat),
- overwrite=True)
+ # barrier_effect = Length of Effect of barriers (linear decrease up to max (barrier_effect)
+ barrier_effect=200 #units as in mapset (m)
- if flags['r']:
- # Realisation of Probablity raster, Multinomial backtransformation from probability into fish counts per cell
- grass.debug(_("Write Realisation (fish counts) from point to garray. This is point cat: "+str(cat)))
- CorrectedDensity = garray.array()
- CorrectedDensity.read("density_"+str(cat))
+ # Calculating distance from barriers (up- and downstream)
+ overwrite = True,
+ output = "distance_barrier_tmp_%d" % os.getpid(),
+ start_coordinates = coors_barriers,
+ max_cost=barrier_effect)
- RealisedDensity = garray.array()
- if options['seed2']:
- numpy.random.seed(int(options['seed2']))
- RealisedDensity[...] = numpy.random.multinomial(n_fish, (CorrectedDensity/numpy.sum(CorrectedDensity)).flat, size=1).reshape(CorrectedDensity.shape)
- RealisedDensity.write("realised_density_"+str(cat))
+ # Getting distance map for downstream of barrier only
+ grass.mapcalc("$distance_downstream_barrier = if(isnull($upstream_barrier), $distance_barrier, null())",
+ distance_downstream_barrier = "distance_downstream_barrier_tmp_%d" % os.getpid(),
+ distance_barrier = "distance_barrier_tmp_%d" % os.getpid(),
+ overwrite = True)
- grass.run_command("r.null", map="realised_density_"+str(cat), null="0")
+ # Getting inverse distance map for downstream of barrier only
+ grass.mapcalc("$inv_distance_downstream_barrier = 1.0/$distance_downstream_barrier",
+ inv_distance_downstream_barrier = "inv_distance_downstream_barrier_tmp_%d" % os.getpid(),
+ overwrite = True)
- # Get a list of all realised densities processed so far within this segement
- mapcalc_list_Ab.append("realised_density_"+str(cat))
+ # Getting parameters for distance weighted relocation of densities downstream the barrier (inverse to distance (reciprocal), y=(density/sum(1/distance))/distance)
+ univar_distance_downstream_barrier = grass.read_command("r.univar", map = "inv_distance_downstream_barrier_tmp_%d" % os.getpid(), flags = 'e')
+ sum_inv_distance_downstream_barrier = float(univar_distance_downstream_barrier.split('\n')[d['sum']].split(':')[1])
+ grass.debug(_("sum_inv_distance_downstream_barrier: "+str(sum_inv_distance_downstream_barrier)))
- # Aggregation per segment
- mapcalc_string_Aa_aggregate = "+".join(mapcalc_list_Aa)
- mapcalc_string_Aa_removal = ",".join(mapcalc_list_Aa)
- grass.mapcalc("$density_segment = $mapcalc_string_Aa_aggregate",
- density_segment = "density_segment_"+segment_cat,
- mapcalc_string_Aa_aggregate = mapcalc_string_Aa_aggregate,
- overwrite = True)
- grass.run_command("g.remove", flags = 'bf', type = 'raster', name = mapcalc_string_Aa_removal)
+ #Calculation Density downstream the barrier
+ grass.mapcalc("$downstream_barrier_density = ($density_for_downstream/$sum_inv_distance_downstream_barrier)/$distance_downstream_barrier",
+ downstream_barrier_density = "downstream_barrier_density_tmp_%d" % os.getpid(),
+ density_for_downstream=density_for_downstream,
+ sum_inv_distance_downstream_barrier = sum_inv_distance_downstream_barrier,
+ overwrite = True)
- grass.run_command("r.null", map="density_segment_"+segment_cat, null="0") # Final density map per segment, set 0 for aggregation with r.mapcalc
- mapcalc_list_Ba.append("density_segment_"+segment_cat)
+ # Combination upstream and downstream density from barrier
+ grass.run_command("r.null", map="downstream_barrier_density_tmp_%d" % os.getpid(), null="0")
- if flags['r']:
- mapcalc_string_Ab_aggregate = "+".join(mapcalc_list_Ab)
- mapcalc_string_Ab_removal = ",".join(mapcalc_list_Ab)
- grass.mapcalc("$realised_density_segment = $mapcalc_string_Ab_aggregate",
- realised_density_segment = "realised_density_segment_"+segment_cat,
- mapcalc_string_Ab_aggregate = mapcalc_string_Ab_aggregate,
- overwrite = True)
- grass.run_command("g.remove", flags = 'bf', type = 'raster', name = mapcalc_string_Ab_removal)
- grass.run_command("r.null", map="realised_density_segment_"+segment_cat, null="0") # Final density map per segment, set 0 for aggregation with r.mapcalc
- mapcalc_list_Bb.append("realised_density_segment_"+segment_cat)
+ grass.mapcalc("$density_point = if(isnull($upstream_barrier), $downstream_barrier_density+$density_point, $upstream_barrier_density*$passability)",
+ density_point = "density_"+str(cat),
+ passability=passability,
+ overwrite = True)
+ if dist == last_barrier :
+ else:
- # Overall aggregation
- mapcalc_string_Ba_aggregate = "+".join(mapcalc_list_Ba)
- mapcalc_string_Ba_removal = ",".join(mapcalc_list_Ba)
- # Final raster map, Final map is sum of all
- # density maps (for each segement), All contributing maps (string_Ba_removal) are deleted
- # in the end.
- grass.mapcalc("$density_final = $mapcalc_string_Ba_aggregate",
- density_final = "density_final_%d" % os.getpid(),
- mapcalc_string_Ba_aggregate = mapcalc_string_Ba_aggregate,
- overwrite = True)
+ # Get a list of all densities processed so far within this segement
+ mapcalc_list_Aa.append("density_"+str(cat))
- if flags['r']:
- mapcalc_string_Bb_aggregate = "+".join(mapcalc_list_Bb)
- mapcalc_string_Bb_removal = ",".join(mapcalc_list_Bb)
- grass.mapcalc("$realised_density_final = $mapcalc_string_Bb_aggregate",
- realised_density_final = "realised_density_final_%d" % os.getpid(),
- mapcalc_string_Bb_aggregate = mapcalc_string_Bb_aggregate,
- overwrite = True)
- raster = "realised_density_final_%d" % os.getpid() + ",realised_" + output_fidimo+"_"+i)
- # Set all 0-values to NULL, Backgroundvalues
- grass.run_command("r.null", map="realised_"+output_fidimo+"_"+i, setnull="0")
- grass.run_command("g.remove", flags = 'bf', type = 'raster', name = mapcalc_string_Bb_removal)
- # backtransformation (divide by scalar which was defined before)
- grass.mapcalc("$density_final_corrected = $density_final/$scalar",
- density_final_corrected = "density_final_corrected_%d" % os.getpid(),
- scalar = scalar,
- overwrite=True)
+ # Multiply (Weight) density point with relative attractiveness. realative attractive in relation to habitat attractivness at source
+ grass.mapcalc("$density_point_attract = $density_point*($habitat_attract/$source_habitat_attract)",
+ density_point_attract = "density_attract_"+str(cat),
+ habitat_attract = habitat_attract,
+ source_habitat_attract = source_habitat_attract,
+ overwrite = True)
- raster = "density_final_corrected_%d" % os.getpid() + "," + output_fidimo+"_"+i)
- grass.run_command("r.null", map=output_fidimo+"_"+i, setnull="0")
- grass.run_command("g.remove", flags = 'bf', type = 'raster', name = mapcalc_string_Ba_removal)
+ grass.run_command("g.rename",
+ raster = "density_attract_"+str(cat) + "," + "density_"+str(cat),
+ overwrite=True)
- # Delete basic maps if flag "b" is set
- if flags['b']:
- grass.run_command("g.remove", flags = 'bf', type = 'vector', name = output_fidimo + "_source_points")
- grass.run_command("g.remove", flags = 'bf', type = 'vector', name = output_fidimo + "_barriers")
- return 0
+ if flags['r']:
+ # Realisation of Probablity raster, Multinomial backtransformation from probability into fish counts per cell
+ grass.debug(_("Write Realisation (fish counts) from point to garray. This is point cat: "+str(cat)))
+ CorrectedDensity = garray.array()
+ CorrectedDensity.read("density_"+str(cat))
+ RealisedDensity = garray.array()
+ if options['seed2']:
+ numpy.random.seed(int(options['seed2']))
+ RealisedDensity[...] = numpy.random.multinomial(n_fish, (CorrectedDensity/numpy.sum(CorrectedDensity)).flat, size=1).reshape(CorrectedDensity.shape)
+ RealisedDensity.write("realised_density_"+str(cat))
+ grass.run_command("r.null", map="realised_density_"+str(cat), null="0")
+ # Get a list of all realised densities processed so far within this segement
+ mapcalc_list_Ab.append("realised_density_"+str(cat))
+ # Aggregation per segment
+ mapcalc_string_Aa_aggregate = "+".join(mapcalc_list_Aa)
+ mapcalc_string_Aa_removal = ",".join(mapcalc_list_Aa)
+ grass.mapcalc("$density_segment = $mapcalc_string_Aa_aggregate",
+ density_segment = "density_segment_"+segment_cat,
+ mapcalc_string_Aa_aggregate = mapcalc_string_Aa_aggregate,
+ overwrite = True)
+ grass.run_command("g.remove", flags = 'bf', type = 'raster', name = mapcalc_string_Aa_removal)
+ grass.run_command("r.null", map="density_segment_"+segment_cat, null="0") # Final density map per segment, set 0 for aggregation with r.mapcalc
+ mapcalc_list_Ba.append("density_segment_"+segment_cat)
+ if flags['r']:
+ mapcalc_string_Ab_aggregate = "+".join(mapcalc_list_Ab)
+ mapcalc_string_Ab_removal = ",".join(mapcalc_list_Ab)
+ grass.mapcalc("$realised_density_segment = $mapcalc_string_Ab_aggregate",
+ realised_density_segment = "realised_density_segment_"+segment_cat,
+ mapcalc_string_Ab_aggregate = mapcalc_string_Ab_aggregate,
+ overwrite = True)
+ grass.run_command("g.remove", flags = 'bf', type = 'raster', name = mapcalc_string_Ab_removal)
+ grass.run_command("r.null", map="realised_density_segment_"+segment_cat, null="0") # Final density map per segment, set 0 for aggregation with r.mapcalc
+ mapcalc_list_Bb.append("realised_density_segment_"+segment_cat)
+ # Overall aggregation
+ mapcalc_string_Ba_aggregate = "+".join(mapcalc_list_Ba)
+ mapcalc_string_Ba_removal = ",".join(mapcalc_list_Ba)
+ # Final raster map, Final map is sum of all
+ # density maps (for each segement), All contributing maps (string_Ba_removal) are deleted
+ # in the end.
+ grass.mapcalc("$density_final = $mapcalc_string_Ba_aggregate",
+ density_final = "density_final_%d" % os.getpid(),
+ mapcalc_string_Ba_aggregate = mapcalc_string_Ba_aggregate,
+ overwrite = True)
+ if flags['r']:
+ mapcalc_string_Bb_aggregate = "+".join(mapcalc_list_Bb)
+ mapcalc_string_Bb_removal = ",".join(mapcalc_list_Bb)
+ grass.mapcalc("$realised_density_final = $mapcalc_string_Bb_aggregate",
+ realised_density_final = "realised_density_final_%d" % os.getpid(),
+ mapcalc_string_Bb_aggregate = mapcalc_string_Bb_aggregate,
+ overwrite = True)
+ raster = "realised_density_final_%d" % os.getpid() + ",realised_" + output_fidimo+"_"+i)
+ # Set all 0-values to NULL, Backgroundvalues
+ grass.run_command("r.null", map="realised_"+output_fidimo+"_"+i, setnull="0")
+ grass.run_command("g.remove", flags = 'bf', type = 'raster', name = mapcalc_string_Bb_removal)
+ # backtransformation (divide by scalar which was defined before)
+ grass.mapcalc("$density_final_corrected = $density_final/$scalar",
+ density_final_corrected = "density_final_corrected_%d" % os.getpid(),
+ scalar = scalar,
+ overwrite=True)
+ raster = "density_final_corrected_%d" % os.getpid() + "," + output_fidimo+"_"+i)
+ grass.run_command("r.null", map=output_fidimo+"_"+i, setnull="0")
+ grass.run_command("g.remove", flags = 'bf', type = 'raster', name = mapcalc_string_Ba_removal)
+ # Delete basic maps if flag "b" is set
+ if flags['b']:
+ grass.run_command("g.remove", flags = 'bf', type = 'vector', name = output_fidimo + "_source_points")
+ if options['barriers']:
+ grass.run_command("g.remove", flags = 'bf', type = 'vector', name = output_fidimo + "_barriers")
+ return 0
if __name__ == "__main__":
- options, flags = grass.parser()
- atexit.register(cleanup)
- sys.exit(main())
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
