[GRASS-SVN] r73967 - in grass-addons/grass7/raster: r.object.activelearning r.object.spatialautocor r.to.vect.tiled
Thu Jan 17 12:53:34 PST 2019
Author: neteler
Date: 2019-01-17 12:53:33 -0800 (Thu, 17 Jan 2019)
New Revision: 73967
   grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py
   grass-addons/grass7/raster/r.object.spatialautocor/r.object.spatialautocor.py
   grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py
r.object.activelearning, r.object.spatialautocor, r.to.vect.tiled addons: converted tab to space indentation using pycharm tool; tabs are to be avoided, see https://trac.osgeo.org/grass/wiki/Submitting/Python?version=19#Editorsettingsfor4-spaceindentation
Modified: grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py
--- grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py	2019-01-17 20:42:28 UTC (rev 73966)
+++ grass-addons/grass7/raster/r.object.activelearning/r.object.activelearning.py	2019-01-17 20:53:33 UTC (rev 73967)
@@ -96,13 +96,13 @@
 try : # You can run the tests outside of grass where those imports are not available
-	import grass as grass
-	import grass.script as gcore
+    import grass as grass
+    import grass.script as gcore
 except ImportError :
-	pass
+    pass
-import numpy as np
-import scipy
+import numpy as np
+import scipy
 import os.path
 import sys
@@ -112,469 +112,469 @@
 def load_data(file_path, labeled=False, skip_header=1, scale=True) :
-		Load the data from a csv file
+        Load the data from a csv file
-		:param file_path: Path to the csv data file
-		:param labeled: True if the data is labeled (default=False)
-		:param skip_header: Header size (in line) (default=1)
-		:param scale: True if the data should be normalize (default=True)
+        :param file_path: Path to the csv data file
+        :param labeled: True if the data is labeled (default=False)
+        :param skip_header: Header size (in line) (default=1)
+        :param scale: True if the data should be normalize (default=True)
-		:type file_path: string
-		:type labeled: boolean
-		:type skip_header: int
-		:type scale: boolean
+        :type file_path: string
+        :type labeled: boolean
+        :type skip_header: int
+        :type scale: boolean
-		:return: Return 4 arrays, the features X, the IDs, the labels y and the header
-		:rtype: ndarray
-	data = np.genfromtxt(file_path, delimiter=',', skip_header=0, dtype=None)
+        :return: Return 4 arrays, the features X, the IDs, the labels y and the header
+        :rtype: ndarray
+    data = np.genfromtxt(file_path, delimiter=',', skip_header=0, dtype=None)
-	header = np.array([])
-	if skip_header != 0 :
-		header = data[0:skip_header,:]
-	data = data[skip_header:, :] #Remove header
-	data = data.astype(np.float)
+    header = np.array([])
-	ID = data[:,0] #get only row 0s
-	if labeled :
-		y = data[:,1] #get only row 1
-		X = data[:,2:] #remove ID and label
-	else :
-		y = []
-		X = data[:,1:] #remove ID
+    if skip_header != 0 :
+        header = data[0:skip_header,:]
+    data = data[skip_header:, :] #Remove header
+    data = data.astype(np.float)
-	if scale :
-		X = preprocessing.scale(X)
+    ID = data[:,0] #get only row 0s
+    if labeled :
+        y = data[:,1] #get only row 1
+        X = data[:,2:] #remove ID and label
+    else :
+        y = []
+        X = data[:,1:] #remove ID
-	return X, ID, y, header
+    if scale :
+        X = preprocessing.scale(X)
+    return X, ID, y, header
 def write_result_file(ID, X_unlabeled, predictions, header, filename) :
-		Write all samples with their ID and their class prediction in csv file. Also add the header to this csv file.
+        Write all samples with their ID and their class prediction in csv file. Also add the header to this csv file.
-		:param ID: Samples'IDs
-		:X_unlabeled: Samples'features
-		:predictions: Class predictin for each sample
-		:header: Header of the csv file
-		:filename: Name of the csv file
-	data = np.copy(X_unlabeled)
-	data = np.insert(data, 0, map(str, ID), axis=1)
-	data = np.insert(data, 1, map(str, predictions), axis=1)
+        :param ID: Samples'IDs
+        :X_unlabeled: Samples'features
+        :predictions: Class predictin for each sample
+        :header: Header of the csv file
+        :filename: Name of the csv file
+    data = np.copy(X_unlabeled)
+    data = np.insert(data, 0, map(str, ID), axis=1)
+    data = np.insert(data, 1, map(str, predictions), axis=1)
-	if header.size != 0 :
-		header = np.insert(header, 1, ['Class'])
-		data = np.insert(data.astype(str), 0, header , axis=0)
-	np.savetxt(filename, data, delimiter=",",fmt="%s")
-	return True
+    if header.size != 0 :
+        header = np.insert(header, 1, ['Class'])
+        data = np.insert(data.astype(str), 0, header , axis=0)
+    np.savetxt(filename, data, delimiter=",",fmt="%s")
+    return True
 def update(update_file, X_train, ID_train, y_train, X_unlabeled, ID_unlabeled) :
-		Transfer features and labels from the unlabeled arrays to the training arrays based on the update file.
+        Transfer features and labels from the unlabeled arrays to the training arrays based on the update file.
-		:param update_file: Path to the update file
-		:param X_train: Features for the training samples
-		:param ID_train: IDs of the training samples
-		:param y_train: Labels of the training samples
-		:param X_unlabeled: Features for the training samples
-		:param ID_unlabeled: IDs of the unlabeled samples
-	update = np.genfromtxt(update_file, delimiter=',', skip_header=1)
-	if update.size == 0 :
-		return X_train, ID_train, y_train
-	elif update.ndim == 1 :
-		update = [update]
-	for index_update, row in enumerate(update) :
-		index = np.where(ID_unlabeled == row[0]) # Find in 'unlabeled' the line corresping to the ID
-		if index[0].size != 0 : # Check if row exists
-			features = X_unlabeled[index[0][0]] # Features
-			ID = ID_unlabeled[index[0][0]]
-			label = row[1]
-			X_train = np.append(X_train, [features], axis=0)
-			ID_train = np.append(ID_train, [ID], axis=0)
-			y_train = np.append(y_train, [label], axis=0)
-		else :
-			gcore.warning("The following sample could not be found :{}".format(row[0]))
+        :param update_file: Path to the update file
+        :param X_train: Features for the training samples
+        :param ID_train: IDs of the training samples
+        :param y_train: Labels of the training samples
+        :param X_unlabeled: Features for the training samples
+        :param ID_unlabeled: IDs of the unlabeled samples
+    update = np.genfromtxt(update_file, delimiter=',', skip_header=1)
+    if update.size == 0 :
+        return X_train, ID_train, y_train
+    elif update.ndim == 1 :
+        update = [update]
+    for index_update, row in enumerate(update) :
+        index = np.where(ID_unlabeled == row[0]) # Find in 'unlabeled' the line corresping to the ID
+        if index[0].size != 0 : # Check if row exists
+            features = X_unlabeled[index[0][0]] # Features
+            ID = ID_unlabeled[index[0][0]]
+            label = row[1]
+            X_train = np.append(X_train, [features], axis=0)
+            ID_train = np.append(ID_train, [ID], axis=0)
+            y_train = np.append(y_train, [label], axis=0)
+        else :
+            gcore.warning("The following sample could not be found :{}".format(row[0]))
 def write_update(update_file, training_file, unlabeled_file, new_training_filename, new_unlabeled_filename) :
-		Transfer samples from the unlabeled set to the training set based on an update file
-		with IDs of samples to transfer and their classes.
+        Transfer samples from the unlabeled set to the training set based on an update file
+        with IDs of samples to transfer and their classes.
-		:param training_file: Path to the training file
-		:param unlabeled_file: Path to the unlabeled file
-		:param new_training_filename: Path to the new training file that will be created
-		:param new_unlabeled_filename: Path to the new unlabeled file that will be created
+        :param training_file: Path to the training file
+        :param unlabeled_file: Path to the unlabeled file
+        :param new_training_filename: Path to the new training file that will be created
+        :param new_unlabeled_filename: Path to the new unlabeled file that will be created
-		:type update_file: string
-		:type training_file: string
-		:type unlabeled_file: string
-		:type new_training_filename: string
-		:type new_unlabeled_filename: string
-	training = np.genfromtxt(training_file, delimiter=',', skip_header=0, dtype=None)
-	unlabeled = np.genfromtxt(unlabeled_file, delimiter=',', skip_header=0, dtype=None)
-	successful_updates = []
+        :type update_file: string
+        :type training_file: string
+        :type unlabeled_file: string
+        :type new_training_filename: string
+        :type new_unlabeled_filename: string
+    training = np.genfromtxt(training_file, delimiter=',', skip_header=0, dtype=None)
+    unlabeled = np.genfromtxt(unlabeled_file, delimiter=',', skip_header=0, dtype=None)
+    successful_updates = []
-		return
-		update = [update]
+        return
+        update = [update]
-		index = np.where(unlabeled == str(row[0])) # Find in 'unlabeled' the line corresping to the ID
-			data = unlabeled[index[0][0]][1:] # Features
-			data = np.insert(data, 0, row[0], axis=0) # ID
-			data = np.insert(data, 1, row[1], axis=0) # Class
-			training = np.append(training, [data], axis=0)
-			unlabeled = np.delete(unlabeled, index[0][0], axis=0)
-			successful_updates.append(index_update)
-		else :
-			gcore.warning("Unable to update completely: the following sample could not be found in the unlabeled set:{}".format(row[0]))
+        index = np.where(unlabeled == str(row[0])) # Find in 'unlabeled' the line corresping to the ID
+            data = unlabeled[index[0][0]][1:] # Features
+            data = np.insert(data, 0, row[0], axis=0) # ID
+            data = np.insert(data, 1, row[1], axis=0) # Class
+            training = np.append(training, [data], axis=0)
+            unlabeled = np.delete(unlabeled, index[0][0], axis=0)
+            successful_updates.append(index_update)
+        else :
+            gcore.warning("Unable to update completely: the following sample could not be found in the unlabeled set:{}".format(row[0]))
-	with open(update_file) as f:
-   		header = f.readline()
-		header = header.split(',')
-	update = np.delete(update, successful_updates, axis=0)
-	update = np.insert(update.astype(str), 0, header, axis=0)
+    with open(update_file) as f:
+        header = f.readline()
+        header = header.split(',')
-	# Save files
-	if new_training_filename != '' :
-		write_updated_file(new_training_filename, training)
-		gcore.message("New training file written to {}".format(new_training_filename))
-	if new_unlabeled_filename != '':
-		write_updated_file(new_unlabeled_filename, unlabeled)
-		gcore.message("New unlabeled file written to {}".format(new_unlabeled_filename))
+    update = np.delete(update, successful_updates, axis=0)
+    update = np.insert(update.astype(str), 0, header, axis=0)
+    # Save files
+    if new_training_filename != '' :
+        write_updated_file(new_training_filename, training)
+        gcore.message("New training file written to {}".format(new_training_filename))
+    if new_unlabeled_filename != '':
+        write_updated_file(new_unlabeled_filename, unlabeled)
+        gcore.message("New unlabeled file written to {}".format(new_unlabeled_filename))
 def write_updated_file(file_path, data) :
-		Write to disk some csv data. Add '_updated' at the end of the filename
-		:param filename: location where the file will be saved
-		:param data: data to save
+        Write to disk some csv data. Add '_updated' at the end of the filename
+        :param filename: location where the file will be saved
+        :param data: data to save
-		:type data: ndarray
-	np.savetxt(file_path, data, delimiter=",",fmt="%s")
+        :type data: ndarray
+    np.savetxt(file_path, data, delimiter=",",fmt="%s")
 def linear_scale(data) :
-		Linearly scale values : 5th percentile to 0 and 95th percentile to 1
+        Linearly scale values : 5th percentile to 0 and 95th percentile to 1
-		:param data: Features
-		:type data: ndarray(#samples x #features)
+        :param data: Features
+        :type data: ndarray(#samples x #features)
-		:return: Linearly scaled data
-		:rtype: ndarray(#samples x #features)
-	p5 = np.percentile(data, 5, axis=0, interpolation='nearest')[np.newaxis] 	# 5th percentiles as a 2D array (-> newaxis)
-	p95 = np.percentile(data, 95, axis=0, interpolation='nearest')[np.newaxis]	# 95th percentiles as a 2D array (-> newaxis)
-	return (data-p5)/(p95-p5)
+        :return: Linearly scaled data
+        :rtype: ndarray(#samples x #features)
+    p5 = np.percentile(data, 5, axis=0, interpolation='nearest')[np.newaxis] 	# 5th percentiles as a 2D array (-> newaxis)
+    p95 = np.percentile(data, 95, axis=0, interpolation='nearest')[np.newaxis]	# 95th percentiles as a 2D array (-> newaxis)
+    return (data-p5)/(p95-p5)
 def train(X, y, c_svm, gamma_parameter) :
-		Train a SVM classifier.
+        Train a SVM classifier.
-		:param c: Penalty parameter C of the error term.
-		:param gamma: Kernel coefficient
-		:param X: Features of the training samples
-		:param y: Labels of the training samples
+        :param c: Penalty parameter C of the error term.
+        :param gamma: Kernel coefficient
+        :param X: Features of the training samples
+        :param y: Labels of the training samples
-		:return: Returns the trained classifier
-		:rtype: sklearn.svm.SVC
-	classifier = svm.SVC(kernel='rbf', C=c_svm, gamma=gamma_parameter, probability=False,decision_function_shape='ovr', random_state=1938475632)
-	classifier.fit(X, y)
+        :return: Returns the trained classifier
+        :rtype: sklearn.svm.SVC
+    classifier = svm.SVC(kernel='rbf', C=c_svm, gamma=gamma_parameter, probability=False,decision_function_shape='ovr', random_state=1938475632)
+    classifier.fit(X, y)
-	return classifier
+    return classifier
 def active_diversity_sample_selection(X_unlabled, nbr, classifier) :
-		Select a number of samples to label based on uncertainety and diversity
+        Select a number of samples to label based on uncertainety and diversity
-		:param X_unlabeled: Pool of unlabeled samples
-		:param nbr: Number of samples to select from the pool
-		:param classifier: Used to predict the class of each sample
+        :param X_unlabeled: Pool of unlabeled samples
+        :param nbr: Number of samples to select from the pool
+        :param classifier: Used to predict the class of each sample
-		:type X_unlabeled: ndarray(#samples x #features)
-		:type nbr: int
-		:type classifier: sklearn.svm.SVC
+        :type X_unlabeled: ndarray(#samples x #features)
+        :type nbr: int
+        :type classifier: sklearn.svm.SVC
-		:return: Indexes of selected samples
-		:rtype: ndarray
-	batch_size = nbr_uncertainty	# Number of samples to select with the uncertainty criterion
+        :return: Indexes of selected samples
+        :rtype: ndarray
-	uncertain_samples_index = uncertainty_filter(X_unlabled, batch_size, classifier)	# Take twice as many samples as needed
-	uncertain_samples = X_unlabled[uncertain_samples_index]
-	return diversity_filter(uncertain_samples, uncertain_samples_index, nbr, diversity_lambda)
+    batch_size = nbr_uncertainty	# Number of samples to select with the uncertainty criterion
-def uncertainty_filter(samples, nbr, classifier) :
-		Keep only a few samples based on an uncertainty criterion
-		Return the indexes of samples to keep
+    uncertain_samples_index = uncertainty_filter(X_unlabled, batch_size, classifier)	# Take twice as many samples as needed
+    uncertain_samples = X_unlabled[uncertain_samples_index]
-		:param samples: Pool of unlabeled samples to select from
-		:param nbr: number of samples to select from the pool
+    return diversity_filter(uncertain_samples, uncertain_samples_index, nbr, diversity_lambda)
-		:type nbr: int
+def uncertainty_filter(samples, nbr, classifier) :
+        Keep only a few samples based on an uncertainty criterion
+        Return the indexes of samples to keep
-		:rtype: ndarray
-	NBR_NEW_SAMPLE = nbr
-	decision_function = np.absolute(classifier.decision_function(samples))
+        :param samples: Pool of unlabeled samples to select from
+        :param nbr: number of samples to select from the pool
-	# Check if the number of samples to return is not
-	# bigger than the total number of samples
-	if (nbr >= samples.shape[0]) :
-		NBR_NEW_SAMPLE = samples.shape[0] - 1
+        :type nbr: int
-	# Get the max distance to each class hyperplane for each example
-	max_index = np.argmax(decision_function[:,:], axis=1)
-	max_values = decision_function[np.arange(len(decision_function)), max_index]
+        :rtype: ndarray
+    NBR_NEW_SAMPLE = nbr
+    decision_function = np.absolute(classifier.decision_function(samples))
-	# Make the max values very small.
-	# The max value is now the second best
-	decision_function[np.arange(len(decision_function)), max_index] = np.NINF
-	# Get the second max distance to each class to hyperplane for each example
-	second_max_index = np.argmax(decision_function[:,:], axis=1)
-	second_max_values = decision_function[np.arange(len(decision_function)), second_max_index]
+    # Check if the number of samples to return is not
+    # bigger than the total number of samples
+    if (nbr >= samples.shape[0]) :
+        NBR_NEW_SAMPLE = samples.shape[0] - 1
-	# "Functionnal margin" for multiclass classifiers for each sample
-	f_MC = max_values - second_max_values
-	selected_sample_index = np.argpartition(f_MC, NBR_NEW_SAMPLE)[:NBR_NEW_SAMPLE]
+    # Get the max distance to each class hyperplane for each example
+    max_index = np.argmax(decision_function[:,:], axis=1)
+    max_values = decision_function[np.arange(len(decision_function)), max_index]
-	return selected_sample_index
+    # Make the max values very small.
+    # The max value is now the second best
+    decision_function[np.arange(len(decision_function)), max_index] = np.NINF
+    # Get the second max distance to each class to hyperplane for each example
+    second_max_index = np.argmax(decision_function[:,:], axis=1)
+    second_max_values = decision_function[np.arange(len(decision_function)), second_max_index]
+    # "Functionnal margin" for multiclass classifiers for each sample
+    f_MC = max_values - second_max_values
+    selected_sample_index = np.argpartition(f_MC, NBR_NEW_SAMPLE)[:NBR_NEW_SAMPLE]
+    return selected_sample_index
 def diversity_filter(samples, uncertain_samples_index, nbr, diversity_lambda=0.25) :
-		Keep only 'nbr' samples based on a diversity criterion (bruzzone2009 : Active Learning For Classification Of Remote Sensing Images)
+        Keep only 'nbr' samples based on a diversity criterion (bruzzone2009 : Active Learning For Classification Of Remote Sensing Images)
-		:param uncertain_samples: Indexes of uncertain samples in the arry of samples
-		:param diversity_lambda: Heuristic parameter, between 0 and 1. Weight between the average distance to other samples and the distance to the closest sample. (default=0.25)
+        :param uncertain_samples: Indexes of uncertain samples in the arry of samples
+        :param diversity_lambda: Heuristic parameter, between 0 and 1. Weight between the average distance to other samples and the distance to the closest sample. (default=0.25)
-		:type uncertain_samples_index: ndarray(#uncertain_samples)
-		:type nbr: int
-		:type diversity_lambda: float
+        :type uncertain_samples_index: ndarray(#uncertain_samples)
+        :type nbr: int
+        :type diversity_lambda: float
-		:rtype: ndarray
-	L = diversity_lambda
-	m = samples.shape[0]	# Number of samples
-	samples_cpy = np.empty(samples.shape)
-	samples_cpy[:] = samples
+        :rtype: ndarray
+    L = diversity_lambda
+    m = samples.shape[0]	# Number of samples
+    samples_cpy = np.empty(samples.shape)
+    samples_cpy[:] = samples
-	selected_sample_index = uncertain_samples_index	# At the begining, take all samples
+    selected_sample_index = uncertain_samples_index	# At the begining, take all samples
-	while (selected_sample_index.shape[0] > nbr) :
+    while (selected_sample_index.shape[0] > nbr) :
-		dist_to_closest = distance_to_closest(samples_cpy)
-		average_dist = average_distance(samples_cpy)
-		discard = np.argmax(L*dist_to_closest + (1-L) * (1./m) * average_dist)
-		selected_sample_index = np.delete(selected_sample_index, discard)	# Remove the sample to discard
-		samples_cpy = np.delete(samples_cpy, discard, axis=0)
+        dist_to_closest = distance_to_closest(samples_cpy)
+        average_dist = average_distance(samples_cpy)
+        discard = np.argmax(L*dist_to_closest + (1-L) * (1./m) * average_dist)
+        selected_sample_index = np.delete(selected_sample_index, discard)	# Remove the sample to discard
+        samples_cpy = np.delete(samples_cpy, discard, axis=0)
 def distance_to_closest(samples) :
-		For each sample, computes the distance to its closest neighbour
+        For each sample, computes the distance to its closest neighbour
-		:param samples: Samples to consider
-		:type samples: ndarray(#samples x #features)
+        :param samples: Samples to consider
+        :type samples: ndarray(#samples x #features)
-		:return: For each sample, the distance to its closest neighbour
-		:rtype: ndarray(#samples)
-	dist_with_samples = rbf_kernel(samples, samples) # Distance between each samples (symetric matrix)
-	np.fill_diagonal(dist_with_samples, np.NINF) # Do not take into acount the distance between a sample and itself (values on the diagonal)
-	dist_with_closest = dist_with_samples.max(axis=0) # For each sample, the distance to the closest other sample
-	return dist_with_closest
+        :return: For each sample, the distance to its closest neighbour
+        :rtype: ndarray(#samples)
+    dist_with_samples = rbf_kernel(samples, samples) # Distance between each samples (symetric matrix)
+    np.fill_diagonal(dist_with_samples, np.NINF) # Do not take into acount the distance between a sample and itself (values on the diagonal)
+    dist_with_closest = dist_with_samples.max(axis=0) # For each sample, the distance to the closest other sample
+    return dist_with_closest
 def average_distance(samples) :
-		For each sample, computes the average distance to all other samples
+        For each sample, computes the average distance to all other samples
-		:return: For each sample, the average distance to all other samples
-	samples = np.asarray(samples)
-	nbr_samples = samples.shape[0]
-	average_dist = (dist_with_samples.sum(axis=1) - 1)/(nbr_samples-1)	# Remove dist to itself (=1)
-	return average_dist
+        :return: For each sample, the average distance to all other samples
+    samples = np.asarray(samples)
+    nbr_samples = samples.shape[0]
+    average_dist = (dist_with_samples.sum(axis=1) - 1)/(nbr_samples-1)	# Remove dist to itself (=1)
+    return average_dist
 def learning(X_train, y_train, X_test, y_test, X_unlabeled, ID_unlabeled, steps, sample_selection) :
-		Train a SVM classifier with the training data, compute the score of the classifier based on testing data and
-		make a class prediction for each sample in the unlabeled data.
-		Find the best samples to label that would increase the most the classification score
+        Train a SVM classifier with the training data, compute the score of the classifier based on testing data and
+        make a class prediction for each sample in the unlabeled data.
+        Find the best samples to label that would increase the most the classification score
-		:param X_train: Features of training samples
-		:param y_train: Labels of training samples
-		:param X_test: Features of test samples
-		:param y_test: Labels of test samples
-		:param X_unlabeled: Features of unlabeled samples
-		:param ID_unlabeled: IDs of unlabeled samples
-		:param steps: Number of samples to label
-		:param sample_selection: Function used to select the samples to label (different heuristics)
+        :param X_train: Features of training samples
+        :param y_train: Labels of training samples
+        :param X_test: Features of test samples
+        :param y_test: Labels of test samples
+        :param X_unlabeled: Features of unlabeled samples
+        :param ID_unlabeled: IDs of unlabeled samples
+        :param steps: Number of samples to label
+        :param sample_selection: Function used to select the samples to label (different heuristics)
-		:type X_train: ndarray(#samples x #features)
-		:type y_train: ndarray(#samples)
-		:type X_test: ndarray(#samples x #features)
-		:type y_test: ndarray(#samples)
-		:type ID_unlabeled: ndarray(#samples)
-		:type steps: int
-		:type samples_selection: callable
+        :type X_train: ndarray(#samples x #features)
+        :type y_train: ndarray(#samples)
+        :type X_test: ndarray(#samples x #features)
+        :type y_test: ndarray(#samples)
+        :type ID_unlabeled: ndarray(#samples)
+        :type steps: int
+        :type samples_selection: callable
-		:return: The IDs of samples to label, the score of the classifier and the prediction for all unlabeled samples
-		:rtype indexes: ndarray(#steps)
-		:rtype score: float
-		:rtype predictions: ndarray(#unlabeled_samples)
+        :return: The IDs of samples to label, the score of the classifier and the prediction for all unlabeled samples
+        :rtype indexes: ndarray(#steps)
+        :rtype score: float
+        :rtype predictions: ndarray(#unlabeled_samples)
-	if(X_unlabeled.size == 0) :
-		raise Exception("Pool of unlabeled samples empty")
+    if(X_unlabeled.size == 0) :
+        raise Exception("Pool of unlabeled samples empty")
-	c_svm, gamma_parameter = SVM_parameters(options['c_svm'], options['gamma_parameter'], X_train, y_train, search_iter)
-	gcore.message('Parameters used : C={}, gamma={}, lambda={}'.format(c_svm, gamma_parameter, diversity_lambda))
+    c_svm, gamma_parameter = SVM_parameters(options['c_svm'], options['gamma_parameter'], X_train, y_train, search_iter)
+    gcore.message('Parameters used : C={}, gamma={}, lambda={}'.format(c_svm, gamma_parameter, diversity_lambda))
-	classifier = train(X_train, y_train, c_svm, gamma_parameter)
-	score = classifier.score(X_test, y_test)
+    classifier = train(X_train, y_train, c_svm, gamma_parameter)
+    score = classifier.score(X_test, y_test)
-	predictions = classifier.predict(X_unlabeled)
-	samples_to_label = sample_selection(X_unlabeled, steps, classifier)
+    predictions = classifier.predict(X_unlabeled)
-	return ID_unlabeled[samples_to_label], score, predictions
+    samples_to_label = sample_selection(X_unlabeled, steps, classifier)
+    return ID_unlabeled[samples_to_label], score, predictions
 def SVM_parameters(c, gamma, X_train, y_train, n_iter) :
-		Determine the parameters (C and gamma) for the SVM classifier.
-		If a parameter is specified in the parameters, keep this value.
-		If it is not specified, compute the 'best' value by grid search (cross validation set)
+        Determine the parameters (C and gamma) for the SVM classifier.
+        If a parameter is specified in the parameters, keep this value.
+        If it is not specified, compute the 'best' value by grid search (cross validation set)
-		:param X_train: Features of the training samples
-		:param n_iter: Number of parameter settings that are sampled. n_iter trades off runtime vs quality of the solution.
+        :param X_train: Features of the training samples
+        :param n_iter: Number of parameter settings that are sampled. n_iter trades off runtime vs quality of the solution.
-		:type c: string
-		:type gamma: string
-		:type Y_train: ndarray
-		:type n_iter: int
+        :type c: string
+        :type gamma: string
+        :type Y_train: ndarray
+        :type n_iter: int
-		:return: The c and gamma parameters
-		:rtype: floats
+        :return: The c and gamma parameters
+        :rtype: floats
-	parameters = {}
-	if c == '' or gamma == '':
-		parameters = {'C': scipy.stats.expon(scale=100), 'gamma': scipy.stats.expon(scale=.1),
-  						'kernel': ['rbf'], 'class_weight':['balanced', None]}
-	if parameters != {} :
-		svr = svm.SVC()
-		clf = RandomizedSearchCV(svr, parameters, n_iter=n_iter, n_jobs=-1, verbose=0)
-		clf.fit(X_train, y_train)
+    parameters = {}
+    if c == '' or gamma == '':
+        parameters = {'C': scipy.stats.expon(scale=100), 'gamma': scipy.stats.expon(scale=.1),
+                      'kernel': ['rbf'], 'class_weight':['balanced', None]}
-	if c == '' :
-		c = clf.best_params_['C']
-	if gamma == '' :
-		gamma = clf.best_params_['gamma']
-	return float(c), float(gamma)
+    if parameters != {} :
+        svr = svm.SVC()
+        clf = RandomizedSearchCV(svr, parameters, n_iter=n_iter, n_jobs=-1, verbose=0)
+        clf.fit(X_train, y_train)
+    if c == '' :
+        c = clf.best_params_['C']
+    if gamma == '' :
+        gamma = clf.best_params_['gamma']
+    return float(c), float(gamma)
 def main() :
-	global learning_steps
-	global diversity_lambda
-	global nbr_uncertainty
-	global search_iter
+    global learning_steps
+    global diversity_lambda
+    global nbr_uncertainty
+    global search_iter
-        global svm, preprocessing, train_test_split, RandomizedSearchCV
-        global StratifiedKFold, rbf_kernel
-        try :
-                from sklearn import svm
-                from sklearn import preprocessing
-                from sklearn.model_selection import train_test_split
-                from sklearn.model_selection import RandomizedSearchCV
-                from sklearn.model_selection import StratifiedKFold
-                from sklearn.metrics.pairwise import rbf_kernel
-        except ImportError :
-                gcore.fatal("This module requires the scikit-learn python package. Please install it.")
+    global svm, preprocessing, train_test_split, RandomizedSearchCV
+    global StratifiedKFold, rbf_kernel
+    try :
+        from sklearn import svm
+        from sklearn import preprocessing
+        from sklearn.model_selection import train_test_split
+        from sklearn.model_selection import RandomizedSearchCV
+        from sklearn.model_selection import StratifiedKFold
+        from sklearn.metrics.pairwise import rbf_kernel
+    except ImportError :
+        gcore.fatal("This module requires the scikit-learn python package. Please install it.")
-	learning_steps = int(options['learning_steps']) if options['learning_steps'] != '0' else 5
-	search_iter = int(options['search_iter']) if options['search_iter'] != '0' else 10					# Number of samples to label at each iteration
-	diversity_lambda = float(options['diversity_lambda']) if options['diversity_lambda'] != '' else 0.25		# Lambda parameter used in the diversity heuristic
-	nbr_uncertainty = int(options['nbr_uncertainty']) if options['nbr_uncertainty'] != '0' else 15 	# Number of samples to select (based on uncertainty criterion) before applying the diversity criterion. Must be at least greater or equal to [LEARNING][steps]
-	X_train, ID_train, y_train, header_train = load_data(options['training_set'], labeled = True)
-	X_test, ID_test, y_test, header_test = load_data(options['test_set'], labeled = True)
-	X_unlabeled, ID_unlabeled, y_unlabeled, header_unlabeled = load_data(options['unlabeled_set'])
-	nbr_train = ID_train.shape[0]
+    learning_steps = int(options['learning_steps']) if options['learning_steps'] != '0' else 5
+    search_iter = int(options['search_iter']) if options['search_iter'] != '0' else 10					# Number of samples to label at each iteration
+    diversity_lambda = float(options['diversity_lambda']) if options['diversity_lambda'] != '' else 0.25		# Lambda parameter used in the diversity heuristic
+    nbr_uncertainty = int(options['nbr_uncertainty']) if options['nbr_uncertainty'] != '0' else 15 	# Number of samples to select (based on uncertainty criterion) before applying the diversity criterion. Must be at least greater or equal to [LEARNING][steps]
-	if (options['update'] !='') : # If an update file has been specified, transfer samples
-		X_train, ID_train, y_train = update(options['update'], X_train, ID_train, y_train, X_unlabeled, ID_unlabeled)
-		if (options['training_updated'] != '' or options['unlabeled_updated'] != '') :
-			write_update(options['update'], options['training_set'], options['unlabeled_set'], options['training_updated'], options['unlabeled_updated'])
-	elif (options['update'] =='' and (options['training_updated'] != '' or options['unlabeled_updated'] != '')) :
-		gcore.warning('No update file specified : could not write the updated files.')
-	nbr_new_train = ID_train.shape[0]
+    X_train, ID_train, y_train, header_train = load_data(options['training_set'], labeled = True)
+    X_test, ID_test, y_test, header_test = load_data(options['test_set'], labeled = True)
+    X_unlabeled, ID_unlabeled, y_unlabeled, header_unlabeled = load_data(options['unlabeled_set'])
-	samples_to_label_IDs, score, predictions = learning(X_train, y_train, X_test, y_test, X_unlabeled, ID_unlabeled, learning_steps, active_diversity_sample_selection)
-	X_unlabeled, ID_unlabeled, y_unlabeled, header_unlabeled = load_data(options['unlabeled_set'], scale=False) # Load unscaled data
+    nbr_train = ID_train.shape[0]
-	predictions_file = options['predictions']
-	if (predictions_file != '') : # Write the class prediction only if an output file has been specified by the user
-		write_result_file(ID_unlabeled, X_unlabeled, predictions, header_unlabeled,  predictions_file)
-		gcore.message("Class predictions written to {}".format(predictions_file))
+    if (options['update'] !='') : # If an update file has been specified, transfer samples
+        X_train, ID_train, y_train = update(options['update'], X_train, ID_train, y_train, X_unlabeled, ID_unlabeled)
+        if (options['training_updated'] != '' or options['unlabeled_updated'] != '') :
+            write_update(options['update'], options['training_set'], options['unlabeled_set'], options['training_updated'], options['unlabeled_updated'])
+    elif (options['update'] =='' and (options['training_updated'] != '' or options['unlabeled_updated'] != '')) :
+        gcore.warning('No update file specified : could not write the updated files.')
+    nbr_new_train = ID_train.shape[0]
+    samples_to_label_IDs, score, predictions = learning(X_train, y_train, X_test, y_test, X_unlabeled, ID_unlabeled, learning_steps, active_diversity_sample_selection)
-	gcore.message('Training set : {}'.format(X_train.shape[0]))
-	gcore.message('Test set : {}'.format(X_test.shape[0]))
-	gcore.message('Unlabeled set : {}'.format(X_unlabeled.shape[0] - (nbr_new_train - nbr_train)))
-	gcore.message('Score : {}'.format(score))
+    X_unlabeled, ID_unlabeled, y_unlabeled, header_unlabeled = load_data(options['unlabeled_set'], scale=False) # Load unscaled data
-	for ID in samples_to_label_IDs :
-		print(int(ID))
+    predictions_file = options['predictions']
+    if (predictions_file != '') : # Write the class prediction only if an output file has been specified by the user
+        write_result_file(ID_unlabeled, X_unlabeled, predictions, header_unlabeled,  predictions_file)
+        gcore.message("Class predictions written to {}".format(predictions_file))
+    gcore.message('Training set : {}'.format(X_train.shape[0]))
+    gcore.message('Test set : {}'.format(X_test.shape[0]))
+    gcore.message('Unlabeled set : {}'.format(X_unlabeled.shape[0] - (nbr_new_train - nbr_train)))
+    gcore.message('Score : {}'.format(score))
+    for ID in samples_to_label_IDs :
+        print(int(ID))
 if __name__ == '__main__' :
-	options, flags = grass.script.parser()
-	main()
+    options, flags = grass.script.parser()
+    main()
Modified: grass-addons/grass7/raster/r.object.spatialautocor/r.object.spatialautocor.py
--- grass-addons/grass7/raster/r.object.spatialautocor/r.object.spatialautocor.py	2019-01-17 20:42:28 UTC (rev 73966)
+++ grass-addons/grass7/raster/r.object.spatialautocor/r.object.spatialautocor.py	2019-01-17 20:53:33 UTC (rev 73967)
@@ -102,48 +102,48 @@
     """ Calculate either Moran's I or Geary's C for values of the given raster """
     raster_vars = gscript.parse_command('r.univar',
-			  		map_=raster,
-			  		flags='g',
-			  		quiet=True)
+                    map_=raster,
+                    flags='g',
+                    quiet=True)
     global_mean = float(raster_vars['mean'])
     univar_res = gscript.read_command('r.univar',
-			 	      flags='t',
-			 	      map_=raster,
-			 	      zones=mapname,
-			 	      out='-',
-			 	      sep='comma',
-                                      quiet=True)
+                    flags='t',
+                    map_=raster,
+                    zones=mapname,
+                    out='-',
+                    sep='comma',
+                    quiet=True)
     means = {}
     mean_diffs = {}
     firstline = True
     for line in univar_res.splitlines():
-	l = line.split(',')
-	if firstline:
-	    i = l.index('mean')
-	    firstline = False
-	else:
-	    means[l[0]] = float(l[i])
-	    mean_diffs[l[0]] = float(l[i]) - global_mean
+        l = line.split(',')
+        if firstline:
+            i = l.index('mean')
+            firstline = False
+        else:
+            means[l[0]] = float(l[i])
+            mean_diffs[l[0]] = float(l[i]) - global_mean
     sum_sq_mean_diffs = sum(x**2 for x in mean_diffs.values())
     total_nb_neighbors = 0
     for region in neighbordict:
-	total_nb_neighbors += len(neighbordict[region])
+        total_nb_neighbors += len(neighbordict[region])
     N = len(means)
     sum_products = 0
     sum_squared_differences = 0
-	region_value = means[region] - global_mean
-	neighbors = neighbordict[region]
-	nb_neighbors = len(neighbors)
-	for neighbor in neighbors:
-	    neighbor_value = means[neighbor] - global_mean
-	    sum_products += region_value * neighbor_value
-            sum_squared_differences = ( means[region] - means[neighbor] ) ** 2
+        region_value = means[region] - global_mean
+        neighbors = neighbordict[region]
+        nb_neighbors = len(neighbors)
+        for neighbor in neighbors:
+            neighbor_value = means[neighbor] - global_mean
+            sum_products += region_value * neighbor_value
+                sum_squared_differences = ( means[region] - means[neighbor] ) ** 2
     if method == 'moran':
         autocor = ( ( float(N) / total_nb_neighbors ) * (float(sum_products)  /  sum_sq_mean_diffs ) )
Modified: grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py
--- grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py	2019-01-17 20:42:28 UTC (rev 73966)
+++ grass-addons/grass7/raster/r.to.vect.tiled/r.to.vect.tiled.py	2019-01-17 20:53:33 UTC (rev 73967)
@@ -117,31 +117,31 @@
     rtvflags=""
     for key in 'sbtvz':
-	if flags[key]:
-	    rtvflags += key
+        if flags[key]:
+            rtvflags += key
     # check options
     if xtiles <= 0:
-	grass.fatal(_("Number of tiles in x direction must be > 0"))
+        grass.fatal(_("Number of tiles in x direction must be > 0"))
     if ytiles < 0:
-	grass.fatal(_("Number of tiles in y direction must be > 0"))
+        grass.fatal(_("Number of tiles in y direction must be > 0"))
     if grass.find_file(name = input)['name'] == '':
-	grass.fatal(_("Input raster %s not found") % input)
+        grass.fatal(_("Input raster %s not found") % input)
     grass.use_temp_region()
     curr = grass.region()
     width = int(curr['cols'] / xtiles)
     if width <= 1:
-	grass.fatal("The requested number of tiles in x direction is too large")
+        grass.fatal("The requested number of tiles in x direction is too large")
     height = int(curr['rows'] / ytiles)
     if height <= 1:
-	grass.fatal("The requested number of tiles in y direction is too large")
+        grass.fatal("The requested number of tiles in y direction is too large")
     do_clip = False
     overlap = 0
     if flags['s'] and ftype == 'area':
-	do_clip = True
-	overlap = 2
+        do_clip = True
+        overlap = 2
     ewres = curr['ewres']
     nsres = curr['nsres']
@@ -153,11 +153,11 @@
     e = curr['e']
     w = curr['w'] + xoverlap
     if w >= e:
-	grass.fatal(_("Overlap is too large"))
+        grass.fatal(_("Overlap is too large"))
     n = curr['n'] - yoverlap
     s = curr['s']
     if s >= n:
     datatype = grass.raster_info(input)['datatype']
     vtiles = None
@@ -164,88 +164,88 @@
     # north to south
     for ytile in range(ytiles):
-	n = curr['n'] - ytile * height * nsres
-	s = n - height * nsres - yoverlap
-	if ytile == ytiles - 1:
-	    s = curr['s']
-	# west to east
-	for xtile in range(xtiles):
-	    w = curr['w'] + xtile * width * ewres
-	    e = w + width * ewres + xoverlap
+        n = curr['n'] - ytile * height * nsres
+        s = n - height * nsres - yoverlap
+        if ytile == ytiles - 1:
+            s = curr['s']
+        # west to east
+        for xtile in range(xtiles):
+            w = curr['w'] + xtile * width * ewres
+            e = w + width * ewres + xoverlap
-	    if xtile == xtiles - 1:
-	        e = curr['e']
+            if xtile == xtiles - 1:
+                e = curr['e']
-	    grass.run_command('g.region', n = n, s = s, e = e, w = w, nsres = nsres, ewres = ewres)
-	    if do_clip:
-		tilename = output + '_stile_' + str(ytile) + str(xtile)
-	    else:
-		tilename = output + '_tile_' + str(ytile) + str(xtile)
+            grass.run_command('g.region', n = n, s = s, e = e, w = w, nsres = nsres, ewres = ewres)
-	    outname = output + '_tile_' + str(ytile) + str(xtile)
+            if do_clip:
+                tilename = output + '_stile_' + str(ytile) + str(xtile)
+            else:
+                tilename = output + '_tile_' + str(ytile) + str(xtile)
-	    grass.run_command('r.to.vect', input = input, output = tilename,
-	                      type = ftype, column = column, flags = rtvflags)
+            outname = output + '_tile_' + str(ytile) + str(xtile)
-	    if do_clip:
-		n2 = curr['n'] - ytile * height * nsres - yoverlap2
-		s2 = n2 - height * nsres
-		if ytile == 0:
-		    n2 = curr['n']
-		    s2 = n2 - height * nsres - yoverlap2
-		    s2 = curr['s']
+            grass.run_command('r.to.vect', input = input, output = tilename,
+                              type = ftype, column = column, flags = rtvflags)
-		w2 = curr['w'] + xtile * width * ewres + xoverlap2
-		e2 = w2 + width * ewres
-		if xtile == 0:
-		    w2 = curr['w']
-		    e2 = w2 + width * ewres + xoverlap2
-		    e2 = curr['e']
+            if do_clip:
+                n2 = curr['n'] - ytile * height * nsres - yoverlap2
+                s2 = n2 - height * nsres
+                if ytile == 0:
+                    n2 = curr['n']
+                    s2 = n2 - height * nsres - yoverlap2
+                    s2 = curr['s']
-		if grass.vector_info_topo(tilename)['areas'] > 0:
-		    grass.run_command('g.region', n = n2, s = s2, e = e2, w = w2,
-				      nsres = nsres, ewres = ewres)
-		    extname = 'extent_tile_' + str(ytile) + str(xtile)
-		    grass.run_command('v.in.region', output = extname, flags = 'd')
-		    grass.run_command('v.overlay', ainput = tilename, binput = extname,
-				      output = outname, operator = 'and', olayer = '0,1,0')
-		    grass.run_command('g.remove', flags='f', type='vector', name= extname, quiet = True)
+                w2 = curr['w'] + xtile * width * ewres + xoverlap2
+                e2 = w2 + width * ewres
+                if xtile == 0:
+                    w2 = curr['w']
+                    e2 = w2 + width * ewres + xoverlap2
+                    e2 = curr['e']
-		    if vtiles is None:
-			vtiles = outname
-		    else:
-			vtiles = vtiles + ',' + outname
+                if grass.vector_info_topo(tilename)['areas'] > 0:
+                    grass.run_command('g.region', n = n2, s = s2, e = e2, w = w2,
+                                      nsres = nsres, ewres = ewres)
-		grass.run_command('g.remove', flags='f', type='vector', name= tilename, quiet = True)
+                    extname = 'extent_tile_' + str(ytile) + str(xtile)
+                    grass.run_command('v.in.region', output = extname, flags = 'd')
+                    grass.run_command('v.overlay', ainput = tilename, binput = extname,
+                                      output = outname, operator = 'and', olayer = '0,1,0')
+                    grass.run_command('g.remove', flags='f', type='vector', name= extname, quiet = True)
-	    else:
-		# write cmd history:
-		grass.vector_history(outname)
-		    vtiles = outname
-		else:
+                    if vtiles is None:
+                        vtiles = outname
+                    else:
+                        vtiles = vtiles + ',' + outname
+                grass.run_command('g.remove', flags='f', type='vector', name= tilename, quiet = True)
+            else:
+                # write cmd history:
+                grass.vector_history(outname)
+                    vtiles = outname
+                else:
     if flags['p']:
-	grass.run_command('v.patch', input = vtiles, output = output,
-			  flags = 'e')
+        grass.run_command('v.patch', input = vtiles, output = output,
+                          flags = 'e')
         grass.run_command('g.remove', flags='f', type='vector', name= vtiles, quiet = True)
-	if grass.vector_info_topo(output)['boundaries'] > 0:
-	    outpatch = output + '_patch'
-	    grass.run_command('g.rename', vector = (output,outpatch))
-	    grass.run_command('v.clean', input = outpatch, output = output,
-			      tool = 'break', flags = 'c')
-	    grass.run_command('g.remove', flags='f', type='vector', name= outpatch)
+        if grass.vector_info_topo(output)['boundaries'] > 0:
+            outpatch = output + '_patch'
+            grass.run_command('g.rename', vector = (output,outpatch))
+            grass.run_command('v.clean', input = outpatch, output = output,
+                              tool = 'break', flags = 'c')
+            grass.run_command('g.remove', flags='f', type='vector', name= outpatch)
     grass.message(_("%s complete") % 'r.to.vect.tiled')
     return 0
