[GRASS-SVN] r74013 - grass/trunk/lib/vector/Vlib
Fri Jan 25 12:58:33 PST 2019
Author: martinl
Date: 2019-01-25 12:58:32 -0800 (Fri, 25 Jan 2019)
New Revision: 74013
   grass/trunk/lib/vector/Vlib/build_pg.c
   grass/trunk/lib/vector/Vlib/pg_local_proto.h
   grass/trunk/lib/vector/Vlib/write_pg.c
postgis topology: missing relations, fix #3339
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c	2019-01-25 10:58:28 UTC (rev 74012)
+++ grass/trunk/lib/vector/Vlib/build_pg.c	2019-01-25 20:58:32 UTC (rev 74013)
@@ -391,6 +391,8 @@
                 Vect__execute_pg(pg_info->conn, "ROLLBACK");
                 return 0;
+            Vect__define_topo_relation(pg_info, area, area);
Modified: grass/trunk/lib/vector/Vlib/pg_local_proto.h
--- grass/trunk/lib/vector/Vlib/pg_local_proto.h	2019-01-25 10:58:28 UTC (rev 74012)
+++ grass/trunk/lib/vector/Vlib/pg_local_proto.h	2019-01-25 20:58:32 UTC (rev 74013)
@@ -82,6 +82,7 @@
                         const struct line_cats *);
 int V2__update_area_pg(struct Map_info *, const struct line_pnts **, int,
                        int);
+int Vect__define_topo_relation(const struct Format_info_pg *, int, int);
 int Vect__insert_face_pg(struct Map_info *, int);
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c	2019-01-25 10:58:28 UTC (rev 74012)
+++ grass/trunk/lib/vector/Vlib/write_pg.c	2019-01-25 20:58:32 UTC (rev 74013)
@@ -61,6 +61,7 @@
                          const struct line_pnts **, int, int);
 static char *build_insert_stmt(const struct Format_info_pg *, const char *, int, int);
 static int insert_topo_element(struct Map_info *, int, int, const char *);
+static int type_to_topogeom(const struct Format_info_pg *);
 static int update_next_edge(struct Map_info*, int, int);
 static int delete_face(const struct Map_info *, int);
 static int update_topo_edge(struct Map_info *, int);
@@ -1912,6 +1913,11 @@
             return -1;
+        if (pg_info->feature_type != SF_POLYGON) {
+            /* define relation */
+            Vect__define_topo_relation(pg_info, topo_id, topo_id);
     /* build INSERT statement
@@ -1961,20 +1967,9 @@
     topogeom_type = -1;
     if (pg_info->toposchema_name) {
-        switch (pg_info->feature_type) {
-        case SF_POINT:
-            topogeom_type = 1;
-            break;
-        case SF_LINESTRING:
-            topogeom_type = 2;
-            break;
-        case SF_POLYGON:
-            topogeom_type = 3;
-            break;
-        default:
-            G_warning(_("Unsupported feature type %d"), pg_info->feature_type);
+        topogeom_type = type_to_topogeom(pg_info);
+        if (topogeom_type < 0)
             return NULL;
     Fi = pg_info->fi;
@@ -2347,6 +2342,49 @@
     return topo_id;
+int type_to_topogeom(const struct Format_info_pg *pg_info)
+    int topogeom_type;
+    topogeom_type = -1;
+    switch (pg_info->feature_type) {
+    case SF_POINT:
+        topogeom_type = 1;
+        break;
+    case SF_LINESTRING:
+        topogeom_type = 2;
+        break;
+    case SF_POLYGON:
+        topogeom_type = 3;
+        break;
+    default:
+        G_warning(_("Unsupported feature type %d"), pg_info->feature_type);
+    return topogeom_type;
+int Vect__define_topo_relation(const struct Format_info_pg *pg_info, int topo_id, int element_id)
+    char stmt[DB_SQL_MAX];
+        return -1;
+    sprintf(stmt, "INSERT into \"%s\".relation VALUES(%d, 1, %d, %d)",
+            pg_info->toposchema_name, topo_id, element_id, topogeom_type);
+    G_debug(3, "SQL: %s", stmt);
+    if (Vect__execute_pg(pg_info->conn, stmt) == -1) {
+        Vect__execute_pg(pg_info->conn, "ROLLBACK");
+        return -1;
+    return 0;
   \brief Find next line (topo only)
