[GRASS-SVN] r74014 - grass/trunk/scripts/v.report
svn_grass at osgeo.org
Fri Jan 25 16:50:41 PST 2019
Author: hcho
Date: 2019-01-25 16:50:41 -0800 (Fri, 25 Jan 2019)
New Revision: 74014
grass/trunk/scripts/v.report/v.report.py
v.report: Report statistics with no db records
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py 2019-01-25 20:58:32 UTC (rev 74013)
+++ grass/trunk/scripts/v.report/v.report.py 2019-01-26 00:50:41 UTC (rev 74014)
@@ -6,7 +6,7 @@
# AUTHOR(S): Markus Neteler, converted to Python by Glynn Clements
# Bug fixes, sort for coor by Huidae Cho <grass4u gmail.com>
# PURPOSE: Reports geometry statistics for vector maps
-# COPYRIGHT: (C) 2005, 2007-2017 by MN and the GRASS Development Team
+# COPYRIGHT: (C) 2005, 2007-2017, 2019 by MN and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -103,10 +103,12 @@
p = grass.pipe_command('v.db.select', quiet=True, map=mapname, layer=layer)
records1 = []
catcol = -1
+ ncols = 0
for line in p.stdout:
cols = decode(line).rstrip('\r\n').split('|')
if catcol == -1:
- for i in range(0, len(cols)):
+ ncols = len(cols)
+ for i in range(0, ncols):
if cols[i] == f['key']:
catcol = i
break
@@ -149,8 +151,11 @@
# v.db.select can return attributes that are not linked to features.
records3 = []
for r2 in records2:
- res = list(filter(lambda r1: r1[catcol] == r2[0],
- records1))[0] + r2[1:]
+ rec = list(filter(lambda r1: r1[catcol] == r2[0], records1))
+ if len(rec) > 0:
+ res = rec[0] + r2[1:]
+ else:
+ res = [r2[0]] + [''] * (ncols - 1) + r2[1:]
records3.append(res)
else:
catcol = 0
