[GRASS-SVN] r74015 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Fri Jan 25 18:07:04 PST 2019
Author: hcho
Date: 2019-01-25 18:07:04 -0800 (Fri, 25 Jan 2019)
New Revision: 74015
grass/trunk/vector/v.select/main.c
v.select: Fix reverse flag
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c 2019-01-26 00:50:41 UTC (rev 74014)
+++ grass/trunk/vector/v.select/main.c 2019-01-26 02:07:04 UTC (rev 74015)
@@ -6,8 +6,9 @@
* Glynn Clements <glynn gclements.plus.com>
* Markus Neteler <neteler itc.it>
* Martin Landa <landa.martin gmail.com> (GEOS support)
+ * Huidae Cho <grass4u gmail.com> (reverse flag fix)
* PURPOSE: Select features from one map by features in another map.
- * COPYRIGHT: (C) 2003-2017 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2017, 2019 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -41,6 +42,7 @@
struct GFlag flag;
struct Map_info In[2], Out;
struct field_info *IFi;
+ int nlines, nareas;
G_gisinit(argv[0]);
@@ -112,9 +114,12 @@
/* Alloc space for input lines array */
- ALines = (int *)G_calloc(Vect_get_num_lines(&(In[0])) + 1, sizeof(int));
- AAreas = (int *)G_calloc(Vect_get_num_areas(&(In[0])) + 1, sizeof(int));
+ nlines = Vect_get_num_lines(&(In[0]));
+ nareas = Vect_get_num_areas(&(In[0]));
+ ALines = (int *)G_calloc(nlines + 1, sizeof(int));
+ AAreas = (int *)G_calloc(nareas + 1, sizeof(int));
/* Read field info */
IFi = Vect_get_field(&(In[0]), ifield[0]);
@@ -143,7 +148,8 @@
- if (nfound != 0) {
+ if ((!flag.reverse->answer && nfound > 0) ||
+ (flag.reverse->answer && nlines + nareas - nfound > 0)) {
/* Open output */
if (Vect_open_new(&Out, parm.output->answer, Vect_is_3d(&(In[0]))) < 0)
G_fatal_error(_("Unable to create vector map <%s>"),
