[GRASS-SVN] r74174 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Thu Mar 7 08:04:56 PST 2019
Author: mmetz
Date: 2019-03-07 08:04:56 -0800 (Thu, 07 Mar 2019)
New Revision: 74174
grass/trunk/general/g.proj/local_proto.h
grass/trunk/general/g.proj/main.c
g.proj: +list_codes to list codes for given authority, compatible with PROJ 4, 5, 6
Modified: grass/trunk/general/g.proj/local_proto.h
--- grass/trunk/general/g.proj/local_proto.h 2019-03-06 23:22:33 UTC (rev 74173)
+++ grass/trunk/general/g.proj/local_proto.h 2019-03-07 16:04:56 UTC (rev 74174)
@@ -1,5 +1,12 @@
#include <grass/config.h>
+#ifdef HAVE_PROJ_H
+#include <proj.h>
+#if PROJ_VERSION_MAJOR >= 6
+#define USE_PROJDB
+#endif
+#endif
extern struct Key_Value *projinfo, *projunits, *projepsg;
extern struct Cell_head cellhd;
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2019-03-06 23:22:33 UTC (rev 74173)
+++ grass/trunk/general/g.proj/main.c 2019-03-07 16:04:56 UTC (rev 74174)
@@ -17,15 +17,56 @@
#include <stdlib.h>
#include <string.h>
+#include <unistd.h>
#include <grass/gis.h>
#include <grass/glocale.h>
+#ifndef HAVE_PROJ_H
+#include <proj_api.h>
+#endif
#include "local_proto.h"
+static char *get_authority_names()
+ char *authnames;
+#ifdef USE_PROJDB
+ /* PROJ 6 */
+ int i, len;
+ PROJ_STRING_LIST authlist = proj_get_authorities_from_database(NULL);
+ len = 0;
+ for (i = 0; authlist[i]; i++) {
+ len += strlen(authlist[i]) + 1;
+ if (len > 0) {
+ authnames = G_malloc((len + 1) * sizeof(char)); /* \0 */
+ *authnames = '\0';
+ if (i > 0)
+ strcat(authnames, ",");
+ strcat(authnames, authlist[i]);
+ else {
+ authnames = G_store("");
+#else
+ /* PROJ 4, 5 */
+ /* there are various init files in share/proj/:
+ * EPSG,GL27,IGNF,ITRF2000,ITRF2008,ITRF2014,nad27,nad83,esri
+ * but they have different formats: bothering only with EPSG here */
+ authnames = G_store("EPSG");
+#endif
+ return authnames;
int main(int argc, char *argv[])
struct Flag *printinfo, /* Print contents of PROJ_INFO & PROJ_UNITS */
@@ -48,6 +89,7 @@
*ingeo, /* Input geo-referenced file readable by
* GDAL or OGR */
#endif
+ *listcodes, /* list codes of given authority */
*datum, /* datum to add (or replace existing datum) */
*dtrans; /* index to datum transform option */
struct GModule *module;
@@ -159,6 +201,14 @@
inepsg->description = _("EPSG projection code");
#endif
+ listcodes = G_define_option();
+ listcodes->key = "list_codes";
+ listcodes->type = TYPE_STRING;
+ listcodes->required = NO;
+ listcodes->options = get_authority_names();
+ listcodes->guisection = _("Print");
+ listcodes->description = _("List codes for given authority, e.g. EPSG, and exit");
datum = G_define_option();
datum->key = "datum";
datum->type = TYPE_STRING;
@@ -207,6 +257,136 @@
/* Initialisation & Validation */
+ /* list codes for given authority */
+ if (listcodes->answer) {
+#ifdef USE_PROJDB
+ /* PROJ 6+ */
+ int i, crs_cnt;
+ PROJ_CRS_INFO **proj_crs_info;
+ crs_cnt = 0;
+ proj_crs_info = proj_get_crs_info_list_from_database(NULL, listcodes->answer, NULL, &crs_cnt);
+ if (crs_cnt < 1)
+ G_fatal_error(_("No codes found for authority %s"),
+ listcodes->answer;
+ for (i = 0; i < crs_cnt; i++) {
+ char *proj_definition;
+ PJ *pj;
+ pj = proj_create_from_database(NULL,
+ proj_crs_info[i]->auth_name,
+ proj_crs_info[i]->code,
+ PJ_CATEGORY_CRS,
+ 0, NULL);
+ proj_definition = proj_as_proj_string(NULL, pj, PJ_PROJ_5, NULL);
+ fprintf(stdout, "%s|%s|%s\n", proj_crs_info[i]->code,
+ proj_crs_info[i]->name,
+ proj_definition);
+#else
+ char pathname[GPATH_MAX];
+ char *authname;
+ char code[GNAME_MAX], name[GNAME_MAX], proj_def[GNAME_MAX];
+ FILE *fp;
+ char buf[4096];
+ int line, have_name;
+#ifdef HAVE_PROJ_H
+ /* PROJ 5 */
+ PJ_INIT_INFO init_info;
+ authname = listcodes->answer;
+ if (G_strcasecmp(authname, "EPSG") == 0)
+ authname = "epsg";
+ init_info = proj_init_info(authname);
+ sprintf(pathname, init_info.filename);
+ if (access(pathname, F_OK) != 0)
+ G_fatal_error(_("Unable to find init file %s"), authname);
+#else
+ /* PROJ 4 */
+ projCtx ctx;
+ ctx = pj_ctx_alloc();
+ if (!pj_find_file(ctx, authname, pathname, GPATH_MAX))
+ pj_ctx_free(ctx);
+#endif
+ /* PROJ 4 / 5 */
+ /* the init files do not have a common structure, thus restrict to epsg */
+ if (strcmp(authname, "epsg") != 0)
+ G_fatal_error(_("Only epsg file is currently supported"));
+ /* open the init file */
+ fp = fopen(pathname, "r");
+ if (!fp) {
+ G_fatal_error(_("Unable to open init file <%s>"), authname);
+ have_name = 0;
+ /* print list of codes, names, definitions */
+ for (line = 1; G_getl2(buf, sizeof(buf), fp); line++) {
+ G_strip(buf);
+ if (*buf == '\0')
+ continue;
+ if (strncmp(buf, "<metadata>", strlen("<metadata>")) == 0)
+ continue;
+ /* name: line starts with '# ' */
+ /* code and definition in next line */
+ if (!have_name) {
+ if (*buf != '#')
+ continue;
+ sprintf(name, buf + 2);
+ have_name = 1;
+ if (have_name && *buf == '#') {
+ continue;
+ if (have_name && *buf == '<') {
+ int i, j, buflen;
+ buflen = strlen(buf);
+ i = 0;
+ while (i < buflen && buf[i] != '>')
+ i++;
+ buf[i] = '\0';
+ sprintf(code, buf + 1);
+ i++;
+ j = i;
+ while (i < buflen && buf[i] != '<')
+ i++;
+ if (i < buflen && buf[i] == '<')
+ buf[i] = '\0';
+ sprintf(proj_def, buf + j);
+ G_strip(proj_def);
+ fprintf(stdout, "%s|%s|%s\n", code, name, proj_def);
+ have_name = 0;
+ name[0] = '\0';
+ fclose(fp);
+#endif
+ exit(EXIT_SUCCESS);
#ifdef HAVE_OGR
/* -e implies -w */
if (esristyle->answer && !printwkt->answer)
