[GRASS-SVN] r74175 - in grass/trunk/gui/wxpython: core gui_core location_wizard
svn_grass at osgeo.org
Thu Mar 7 08:07:02 PST 2019
Author: mmetz
Date: 2019-03-07 08:07:02 -0800 (Thu, 07 Mar 2019)
New Revision: 74175
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/gui/wxpython/location_wizard/wizard.py
wxGUI: use g.proj list_codes=EPSG to read EPSG codes
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2019-03-07 16:04:56 UTC (rev 74174)
+++ grass/trunk/gui/wxpython/core/utils.py 2019-03-07 16:07:02 UTC (rev 74175)
@@ -509,45 +509,21 @@
return path
-def ReadEpsgCodes(path):
- """Read EPSG code from the file
+def ReadEpsgCodes():
+ """Read EPSG codes with g.proj
- :param path: full path to the file with EPSG codes
- Raise OpenError on failure.
:return: dictionary of EPSG code
epsgCodeDict = dict()
- try:
- try:
- f = open(path, "r")
- except IOError:
- raise OpenError(_("failed to open '{0}'").format(path))
- code = None
- for line in f.readlines():
- line = line.strip()
- if len(line) < 1 or line.startswith('<metadata>'):
- continue
+ ret = RunCommand('g.proj',
+ read=True,
+ list_codes="EPSG")
- if line[0] == '#':
- descr = line[1:].strip()
- elif line[0] == '<':
- code, params = line.split(" ", 1)
- try:
- code = int(code.replace('<', '').replace('>', ''))
- except ValueError as e:
- raise OpenError('{0}'.format(e))
+ for line in ret.splitlines():
+ code, descr, params = line.split("|")
+ epsgCodeDict[code] = (descr, params)
- if code is not None:
- epsgCodeDict[code] = (descr, params)
- code = None
- f.close()
- except Exception as e:
return epsgCodeDict
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2019-03-07 16:04:56 UTC (rev 74174)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2019-03-07 16:07:02 UTC (rev 74175)
@@ -1901,7 +1901,7 @@
self.winId['projection:statusbar:epsg'])
wx.BeginBusyCursor()
try:
- self.epsgCodeDict = ReadEpsgCodes(path)
+ self.epsgCodeDict = ReadEpsgCodes()
except OpenError as e:
wx.EndBusyCursor()
epsgCombo.SetItems([])
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py 2019-03-07 16:04:56 UTC (rev 74174)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py 2019-03-07 16:07:02 UTC (rev 74175)
@@ -1699,7 +1699,7 @@
def OnBrowseCodes(self, event, search=None):
"""Browse EPSG codes"""
try:
- self.epsgCodeDict = utils.ReadEpsgCodes(self.tfile.GetValue())
+ self.epsgCodeDict = utils.ReadEpsgCodes()
GError(
parent=self,
@@ -1946,7 +1946,7 @@
"""Browse IAU codes"""
try:
GError(
parent=self,
