[GRASS-SVN] r74181 - grass/branches/releasebranch_7_4
svn_grass at osgeo.org
Thu Mar 7 12:06:00 PST 2019
Author: neteler
Date: 2019-03-07 12:06:00 -0800 (Thu, 07 Mar 2019)
New Revision: 74181
grass/branches/releasebranch_7_4/configure
grass/branches/releasebranch_7_4/configure.in
configure: nad2bin check no longer needed; (user custom) grids are used via PROJ (trunk r74179)
Modified: grass/branches/releasebranch_7_4/configure
--- grass/branches/releasebranch_7_4/configure 2019-03-07 20:05:01 UTC (rev 74180)
+++ grass/branches/releasebranch_7_4/configure 2019-03-07 20:06:00 UTC (rev 74181)
@@ -5709,45 +5709,6 @@
-# nad2bin needs to be in path for installing datum gridshift files
-# Extract the first word of "nad2bin", so it can be a program name with args.
-set dummy nad2bin; ac_word=$2
-echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:5718: checking for $ac_word" >&5
-case "$NAD2BIN" in
- ac_cv_path_NAD2BIN="$NAD2BIN" # Let the user override the test with a path.
- ac_cv_path_NAD2BIN="$NAD2BIN" # Let the user override the test with a dos path.
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
- ac_dummy="$PATH"
- for ac_dir in $ac_dummy; do
- test -z "$ac_dir" && ac_dir=.
- if test -f $ac_dir/$ac_word; then
- ac_cv_path_NAD2BIN="$ac_dir/$ac_word"
- break
- fi
- done
- IFS="$ac_save_ifs"
- test -z "$ac_cv_path_NAD2BIN" && ac_cv_path_NAD2BIN="no"
-esac
-NAD2BIN="$ac_cv_path_NAD2BIN"
-if test -n "$NAD2BIN"; then
- echo "$ac_t""$NAD2BIN" 1>&6
-else
- echo "$ac_t""no" 1>&6
-fi
-if test "$NAD2BIN" = "no"; then
- { echo "configure: error: *** Unable to locate nad2bin (needs to be in PATH)." 1>&2; exit 1; }
-fi
# Done checking PROJ
# Enable regex option
@@ -5754,7 +5715,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5758: checking whether to use regex" >&5
+echo "configure:5719: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5774,7 +5735,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5778: checking for location of regex includes" >&5
+echo "configure:5739: checking for location of regex includes" >&5
case "$with_regex_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5800,15 +5761,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:5804: checking for $ac_hdr" >&5
+echo "configure:5765: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 5807 "configure"
+#line 5768 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:5812: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5773: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -5842,7 +5803,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5846: checking for location of regex library" >&5
+echo "configure:5807: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5867,10 +5828,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5871: checking for regcomp" >&5
+echo "configure:5832: checking for regcomp" >&5
-#line 5874 "configure"
+#line 5835 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char regcomp(); below. */
@@ -5893,7 +5854,7 @@
; return 0; }
EOF
-if { (eval echo configure:5897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5920,13 +5881,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5924: checking for regcomp in -lregex" >&5
+echo "configure:5885: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lregex $LIBS"
-#line 5930 "configure"
+#line 5891 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -5937,7 +5898,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -5987,7 +5948,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5991: checking whether to use Readline" >&5
+echo "configure:5952: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -6008,7 +5969,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:6012: checking for location of Readline includes" >&5
+echo "configure:5973: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -6034,15 +5995,15 @@
do
-echo "configure:6038: checking for $ac_hdr" >&5
+echo "configure:5999: checking for $ac_hdr" >&5
-#line 6041 "configure"
+#line 6002 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6046: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6078,15 +6039,15 @@
do
-echo "configure:6082: checking for $ac_hdr" >&5
+echo "configure:6043: checking for $ac_hdr" >&5
-#line 6085 "configure"
+#line 6046 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6090: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6051: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6120,7 +6081,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6124: checking for location of Readline library" >&5
+echo "configure:6085: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6145,13 +6106,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6149: checking for readline in -lreadline" >&5
+echo "configure:6110: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6155 "configure"
+#line 6116 "configure"
@@ -6162,7 +6123,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6197,13 +6158,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6201: checking for add_history in -lhistory" >&5
+echo "configure:6162: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6207 "configure"
+#line 6168 "configure"
@@ -6214,7 +6175,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6256,7 +6217,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6260: checking whether to use GDAL" >&5
+echo "configure:6221: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6274,7 +6235,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6278: checking for $ac_word" >&5
+echo "configure:6239: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6329,7 +6290,7 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6333 "configure"
+#line 6294 "configure"
#include <gdal.h>
int main() {
@@ -6336,7 +6297,7 @@
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6345,7 +6306,7 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6349 "configure"
+#line 6310 "configure"
#include <gdal.h>
int main() {
@@ -6352,7 +6313,7 @@
; return 0; }
EOF
-if { (eval echo configure:6356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6384,7 +6345,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6388: checking whether to use libLAS" >&5
+echo "configure:6349: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6401,7 +6362,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6405: checking for $ac_word" >&5
+echo "configure:6366: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6454,15 +6415,15 @@
do
-echo "configure:6458: checking for $ac_hdr" >&5
+echo "configure:6419: checking for $ac_hdr" >&5
-#line 6461 "configure"
+#line 6422 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6466: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6488,7 +6449,7 @@
done
-#line 6492 "configure"
+#line 6453 "configure"
#include <liblas/capi/liblas.h>
int main() {
@@ -6495,7 +6456,7 @@
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6503,7 +6464,7 @@
rm -rf conftest*
-#line 6507 "configure"
+#line 6468 "configure"
int main() {
@@ -6510,7 +6471,7 @@
; return 0; }
EOF
-if { (eval echo configure:6514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6543,7 +6504,7 @@
# PDAL option
echo $ac_n "checking whether to use PDAL""... $ac_c" 1>&6
-echo "configure:6547: checking whether to use PDAL" >&5
+echo "configure:6508: checking whether to use PDAL" >&5
# new and currently used way to switch language to C++
# AC_LANG_PUSH(C++)
@@ -6571,7 +6532,7 @@
# Extract the first word of "pdal-config", so it can be a program name with args.
set dummy pdal-config; ac_word=$2
-echo "configure:6575: checking for $ac_word" >&5
+echo "configure:6536: checking for $ac_word" >&5
case "$PDAL_CONFIG" in
@@ -6621,7 +6582,7 @@
CFLAGS="$CFLAGS $PDAL_CFLAGS"
CPPFLAGS="$CPPFLAGS $PDAL_CPPFLAGS $PDAL_INC"
-#line 6625 "configure"
+#line 6586 "configure"
#include <pdal/PointTable.hpp>
int main() {
@@ -6628,7 +6589,7 @@
pdal::PointTable table;
; return 0; }
EOF
-if { (eval echo configure:6632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6593: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6636,7 +6597,7 @@
rm -rf conftest*
-#line 6640 "configure"
+#line 6601 "configure"
int main() {
@@ -6643,7 +6604,7 @@
; return 0; }
EOF
-if { (eval echo configure:6647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
PDAL_LIBS="$PDAL_LIBS"
else
@@ -6693,7 +6654,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6697: checking whether to use NetCDF" >&5
+echo "configure:6658: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6710,7 +6671,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6714: checking for $ac_word" >&5
+echo "configure:6675: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6757,7 +6718,7 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6761 "configure"
+#line 6722 "configure"
#include <netcdf.h>
int main() {
@@ -6764,7 +6725,7 @@
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6772,7 +6733,7 @@
rm -rf conftest*
-#line 6776 "configure"
+#line 6737 "configure"
#include <netcdf.h>
int main() {
@@ -6779,7 +6740,7 @@
; return 0; }
EOF
-if { (eval echo configure:6783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6810,7 +6771,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6814: checking whether to use GEOS" >&5
+echo "configure:6775: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6828,7 +6789,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6832: checking for $ac_word" >&5
+echo "configure:6793: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6876,15 +6837,15 @@
do
-echo "configure:6880: checking for $ac_hdr" >&5
+echo "configure:6841: checking for $ac_hdr" >&5
-#line 6883 "configure"
+#line 6844 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6849: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6923,13 +6884,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6927: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6888: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6933 "configure"
+#line 6894 "configure"
@@ -6940,7 +6901,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6984,7 +6945,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6988: checking whether to use TIFF" >&5
+echo "configure:6949: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -7004,7 +6965,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7008: checking for location of TIFF includes" >&5
+echo "configure:6969: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7030,15 +6991,15 @@
do
-echo "configure:7034: checking for $ac_hdr" >&5
+echo "configure:6995: checking for $ac_hdr" >&5
-#line 7037 "configure"
+#line 6998 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7003: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7072,7 +7033,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7076: checking for location of TIFF library" >&5
+echo "configure:7037: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7103,13 +7064,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7107: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7068: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 7113 "configure"
+#line 7074 "configure"
@@ -7120,7 +7081,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7139,13 +7100,13 @@
-echo "configure:7143: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7104: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7149 "configure"
+#line 7110 "configure"
@@ -7156,7 +7117,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7175,13 +7136,13 @@
-echo "configure:7179: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7140: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7185 "configure"
+#line 7146 "configure"
@@ -7192,7 +7153,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7211,13 +7172,13 @@
-echo "configure:7215: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7176: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7221 "configure"
+#line 7182 "configure"
@@ -7228,7 +7189,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7232: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7247,13 +7208,13 @@
-echo "configure:7251: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7212: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 7257 "configure"
+#line 7218 "configure"
@@ -7264,7 +7225,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7283,13 +7244,13 @@
-echo "configure:7287: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7248: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7293 "configure"
+#line 7254 "configure"
@@ -7300,7 +7261,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7319,13 +7280,13 @@
-echo "configure:7323: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7284: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7329 "configure"
+#line 7290 "configure"
@@ -7336,7 +7297,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7355,13 +7316,13 @@
-echo "configure:7359: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7320: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7365 "configure"
+#line 7326 "configure"
@@ -7372,7 +7333,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7470,7 +7431,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7474: checking whether to use PNG" >&5
+echo "configure:7435: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7489,7 +7450,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7493: checking for location of PNG includes" >&5
+echo "configure:7454: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7515,15 +7476,15 @@
do
-echo "configure:7519: checking for $ac_hdr" >&5
+echo "configure:7480: checking for $ac_hdr" >&5
-#line 7522 "configure"
+#line 7483 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7557,7 +7518,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7561: checking for location of PNG library" >&5
+echo "configure:7522: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7582,13 +7543,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7586: checking for png_read_image in -lpng" >&5
+echo "configure:7547: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7592 "configure"
+#line 7553 "configure"
@@ -7599,7 +7560,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7641,7 +7602,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7645: checking whether to use PostgreSQL" >&5
+echo "configure:7606: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7668,7 +7629,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7672: checking for location of PostgreSQL includes" >&5
+echo "configure:7633: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7694,15 +7655,15 @@
do
-echo "configure:7698: checking for $ac_hdr" >&5
+echo "configure:7659: checking for $ac_hdr" >&5
-#line 7701 "configure"
+#line 7662 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7667: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7740,7 +7701,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7744: checking for location of PostgreSQL library" >&5
+echo "configure:7705: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7769,13 +7730,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7773: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7734: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7779 "configure"
+#line 7740 "configure"
@@ -7786,7 +7747,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7805,13 +7766,13 @@
-echo "configure:7809: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7770: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7815 "configure"
+#line 7776 "configure"
@@ -7822,7 +7783,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7841,13 +7802,13 @@
-echo "configure:7845: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7806: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7851 "configure"
+#line 7812 "configure"
@@ -7858,7 +7819,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7877,13 +7838,13 @@
-echo "configure:7881: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7842: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7887 "configure"
+#line 7848 "configure"
@@ -7894,7 +7855,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7951,13 +7912,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7955: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7916: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7961 "configure"
+#line 7922 "configure"
@@ -7968,7 +7929,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7990,13 +7951,13 @@
-echo "configure:7994: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7955: checking for PQcmdTuples in -lpq" >&5
-#line 8000 "configure"
+#line 7961 "configure"
@@ -8007,7 +7968,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:8011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8050,7 +8011,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8054: checking whether to use MySQL" >&5
+echo "configure:8015: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -8070,7 +8031,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8074: checking for location of MySQL includes" >&5
+echo "configure:8035: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8096,15 +8057,15 @@
do
-echo "configure:8100: checking for $ac_hdr" >&5
+echo "configure:8061: checking for $ac_hdr" >&5
-#line 8103 "configure"
+#line 8064 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8108: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8141,7 +8102,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8145: checking for location of MySQL library" >&5
+echo "configure:8106: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8172,13 +8133,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8176: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8137: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 8182 "configure"
+#line 8143 "configure"
@@ -8189,7 +8150,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8208,13 +8169,13 @@
-echo "configure:8212: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8173: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8218 "configure"
+#line 8179 "configure"
@@ -8225,7 +8186,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8190: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8244,13 +8205,13 @@
-echo "configure:8248: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8209: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8254 "configure"
+#line 8215 "configure"
@@ -8261,7 +8222,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8280,13 +8241,13 @@
-echo "configure:8284: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8245: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8290 "configure"
+#line 8251 "configure"
@@ -8297,7 +8258,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8316,13 +8277,13 @@
-echo "configure:8320: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8281: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8326 "configure"
+#line 8287 "configure"
@@ -8333,7 +8294,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8352,13 +8313,13 @@
-echo "configure:8356: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8317: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8362 "configure"
+#line 8323 "configure"
@@ -8369,7 +8330,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8388,13 +8349,13 @@
-echo "configure:8392: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8353: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8398 "configure"
+#line 8359 "configure"
@@ -8405,7 +8366,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8424,13 +8385,13 @@
-echo "configure:8428: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8389: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8434 "configure"
+#line 8395 "configure"
@@ -8441,7 +8402,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8531,7 +8492,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:8535: checking for $ac_word" >&5
+echo "configure:8496: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8580,10 +8541,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8584: checking for mysql_server_init" >&5
+echo "configure:8545: checking for mysql_server_init" >&5
-#line 8587 "configure"
+#line 8548 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8609,7 +8570,7 @@
; return 0; }
EOF
-if { (eval echo configure:8613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8661,7 +8622,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8665: checking whether to use SQLite" >&5
+echo "configure:8626: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8681,7 +8642,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8685: checking for location of SQLite includes" >&5
+echo "configure:8646: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8707,15 +8668,15 @@
do
-echo "configure:8711: checking for $ac_hdr" >&5
+echo "configure:8672: checking for $ac_hdr" >&5
-#line 8714 "configure"
+#line 8675 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8680: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8758,7 +8719,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8762: checking for location of SQLite library" >&5
+echo "configure:8723: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8787,13 +8748,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8791: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8752: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8797 "configure"
+#line 8758 "configure"
@@ -8804,7 +8765,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8823,13 +8784,13 @@
-echo "configure:8827: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8788: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8833 "configure"
+#line 8794 "configure"
@@ -8840,7 +8801,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8805: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8859,13 +8820,13 @@
-echo "configure:8863: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8824: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8869 "configure"
+#line 8830 "configure"
@@ -8876,7 +8837,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8895,13 +8856,13 @@
-echo "configure:8899: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8860: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8905 "configure"
+#line 8866 "configure"
@@ -8912,7 +8873,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8987,7 +8948,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:8991: checking whether to use OpenGL" >&5
+echo "configure:8952: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9021,7 +8982,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9025: checking for location of OpenGL includes" >&5
+echo "configure:8986: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9047,15 +9008,15 @@
do
-echo "configure:9051: checking for $ac_hdr" >&5
+echo "configure:9012: checking for $ac_hdr" >&5
-#line 9054 "configure"
+#line 9015 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9089,7 +9050,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9093: checking for location of OpenGL library" >&5
+echo "configure:9054: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9118,13 +9079,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9122: checking for glBegin in -lGL" >&5
+echo "configure:9083: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9128 "configure"
+#line 9089 "configure"
@@ -9135,7 +9096,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9154,13 +9115,13 @@
-echo "configure:9158: checking for glBegin in -lGL" >&5
+echo "configure:9119: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9164 "configure"
+#line 9125 "configure"
@@ -9171,7 +9132,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9190,13 +9151,13 @@
-echo "configure:9194: checking for glBegin in -lGL" >&5
+echo "configure:9155: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9200 "configure"
+#line 9161 "configure"
@@ -9207,7 +9168,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9226,13 +9187,13 @@
-echo "configure:9230: checking for glBegin in -lGL" >&5
+echo "configure:9191: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9236 "configure"
+#line 9197 "configure"
@@ -9243,7 +9204,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9305,13 +9266,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9309: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9270: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9315 "configure"
+#line 9276 "configure"
@@ -9322,7 +9283,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9341,13 +9302,13 @@
-echo "configure:9345: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9306: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9351 "configure"
+#line 9312 "configure"
@@ -9358,7 +9319,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9405,10 +9366,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9409: checking for glXCreatePbuffer" >&5
+echo "configure:9370: checking for glXCreatePbuffer" >&5
-#line 9412 "configure"
+#line 9373 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -9431,7 +9392,7 @@
; return 0; }
EOF
-if { (eval echo configure:9435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9468,10 +9429,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9472: checking for glXCreateGLXPixmap" >&5
+echo "configure:9433: checking for glXCreateGLXPixmap" >&5
-#line 9475 "configure"
+#line 9436 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9494,7 +9455,7 @@
; return 0; }
EOF
-if { (eval echo configure:9498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9537,7 +9498,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9541: checking for location of OpenGL framework" >&5
+echo "configure:9502: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9561,15 +9522,15 @@
do
-echo "configure:9565: checking for $ac_hdr" >&5
+echo "configure:9526: checking for $ac_hdr" >&5
-#line 9568 "configure"
+#line 9529 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9605,10 +9566,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9609: checking for glBegin" >&5
+echo "configure:9570: checking for glBegin" >&5
-#line 9612 "configure"
+#line 9573 "configure"
which can conflict with char glBegin(); below. */
@@ -9631,7 +9592,7 @@
; return 0; }
EOF
-if { (eval echo configure:9635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9668,10 +9629,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9672: checking for gluBeginCurve" >&5
+echo "configure:9633: checking for gluBeginCurve" >&5
-#line 9675 "configure"
+#line 9636 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9694,7 +9655,7 @@
; return 0; }
EOF
-if { (eval echo configure:9698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9742,7 +9703,7 @@
-echo "configure:9746: checking for location of OpenGL includes" >&5
+echo "configure:9707: checking for location of OpenGL includes" >&5
@@ -9768,15 +9729,15 @@
do
-echo "configure:9772: checking for $ac_hdr" >&5
+echo "configure:9733: checking for $ac_hdr" >&5
-#line 9775 "configure"
+#line 9736 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9780: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9810,7 +9771,7 @@
-echo "configure:9814: checking for location of OpenGL library" >&5
+echo "configure:9775: checking for location of OpenGL library" >&5
@@ -9835,11 +9796,11 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9839: checking for OpenGL library" >&5
+echo "configure:9800: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9843 "configure"
+#line 9804 "configure"
#include <GL/gl.h>
int main() {
@@ -9846,7 +9807,7 @@
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9870,11 +9831,11 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9874: checking for GLU library" >&5
+echo "configure:9835: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 9878 "configure"
+#line 9839 "configure"
#include <GL/glu.h>
int main() {
@@ -9881,7 +9842,7 @@
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:9885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -9930,7 +9891,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:9934: checking whether to use ODBC" >&5
+echo "configure:9895: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -9949,7 +9910,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:9953: checking for location of ODBC includes" >&5
+echo "configure:9914: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -9975,15 +9936,15 @@
do
-echo "configure:9979: checking for $ac_hdr" >&5
+echo "configure:9940: checking for $ac_hdr" >&5
-#line 9982 "configure"
+#line 9943 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9948: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10017,7 +9978,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10021: checking for location of ODBC library" >&5
+echo "configure:9982: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10042,13 +10003,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10046: checking for SQLConnect in -lodbc" >&5
+echo "configure:10007: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10052 "configure"
+#line 10013 "configure"
@@ -10059,7 +10020,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10084,13 +10045,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10088: checking for SQLConnect in -liodbc" >&5
+echo "configure:10049: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10094 "configure"
+#line 10055 "configure"
@@ -10101,7 +10062,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10126,11 +10087,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10130: checking for ODBC library" >&5
+echo "configure:10091: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10134 "configure"
+#line 10095 "configure"
#include <windows.h>
#include <sql.h>
@@ -10138,7 +10099,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10187,7 +10148,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10191: checking whether to use FFTW" >&5
+echo "configure:10152: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10206,7 +10167,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10210: checking for location of FFTW includes" >&5
+echo "configure:10171: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10232,15 +10193,15 @@
do
-echo "configure:10236: checking for $ac_hdr" >&5
+echo "configure:10197: checking for $ac_hdr" >&5
-#line 10239 "configure"
+#line 10200 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10244: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10205: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10268,15 +10229,15 @@
do
-echo "configure:10272: checking for $ac_hdr" >&5
+echo "configure:10233: checking for $ac_hdr" >&5
-#line 10275 "configure"
+#line 10236 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10280: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10304,15 +10265,15 @@
do
-echo "configure:10308: checking for $ac_hdr" >&5
+echo "configure:10269: checking for $ac_hdr" >&5
-#line 10311 "configure"
+#line 10272 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10277: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10358,7 +10319,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10362: checking for location of FFTW library" >&5
+echo "configure:10323: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10383,13 +10344,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10387: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10348: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10393 "configure"
+#line 10354 "configure"
@@ -10400,7 +10361,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10425,13 +10386,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10429: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10390: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10435 "configure"
+#line 10396 "configure"
@@ -10442,7 +10403,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10467,13 +10428,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10471: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10432: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10477 "configure"
+#line 10438 "configure"
@@ -10484,7 +10445,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10541,7 +10502,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10545: checking whether to use BLAS" >&5
+echo "configure:10506: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10562,7 +10523,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10566: checking for location of BLAS includes" >&5
+echo "configure:10527: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10582,7 +10543,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10586: checking for location of BLAS library" >&5
+echo "configure:10547: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10608,15 +10569,15 @@
do
-echo "configure:10612: checking for $ac_hdr" >&5
+echo "configure:10573: checking for $ac_hdr" >&5
-#line 10615 "configure"
+#line 10576 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10581: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10651,13 +10612,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10655: checking for dnrm2_ in -lblas" >&5
+echo "configure:10616: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10661 "configure"
+#line 10622 "configure"
@@ -10668,7 +10629,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10687,13 +10648,13 @@
-echo "configure:10691: checking for dnrm2_ in -lblas" >&5
+echo "configure:10652: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10697 "configure"
+#line 10658 "configure"
@@ -10704,7 +10665,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10748,13 +10709,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10752: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10713: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10758 "configure"
+#line 10719 "configure"
@@ -10765,7 +10726,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10780,13 +10741,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10784: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10745: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10790 "configure"
+#line 10751 "configure"
@@ -10797,7 +10758,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10812,13 +10773,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10816: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10777: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10822 "configure"
+#line 10783 "configure"
@@ -10829,7 +10790,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10875,9 +10836,9 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10879: checking for sgemm in $vlib_flags" >&5
+echo "configure:10840: checking for sgemm in $vlib_flags" >&5
-#line 10881 "configure"
+#line 10842 "configure"
int main() {
@@ -10884,7 +10845,7 @@
sgemm
; return 0; }
EOF
-if { (eval echo configure:10888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -10902,13 +10863,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10906: checking for sgemm_ in -lblas" >&5
+echo "configure:10867: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 10912 "configure"
+#line 10873 "configure"
@@ -10919,7 +10880,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10934,13 +10895,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:10938: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10899: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 10944 "configure"
+#line 10905 "configure"
@@ -10951,7 +10912,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:10955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10966,13 +10927,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:10970: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10931: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 10976 "configure"
+#line 10937 "configure"
#include "confdefs.h"
@@ -10983,7 +10944,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11017,13 +10978,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11021: checking for acosp in -lsunmath" >&5
+echo "configure:10982: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11027 "configure"
+#line 10988 "configure"
@@ -11034,7 +10995,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11049,13 +11010,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11053: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11014: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11059 "configure"
+#line 11020 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -11066,7 +11027,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11031: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -11096,13 +11057,13 @@
# Generic BLAS library
-echo "configure:11100: checking for sgemm_ in -lblas" >&5
+echo "configure:11061: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11106 "configure"
+#line 11067 "configure"
@@ -11113,7 +11074,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11152,7 +11113,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11156: checking whether to use LAPACK" >&5
+echo "configure:11117: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11177,7 +11138,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11181: checking for location of LAPACK includes" >&5
+echo "configure:11142: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11197,7 +11158,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11201: checking for location of LAPACK library" >&5
+echo "configure:11162: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11223,15 +11184,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11227: checking for $ac_hdr" >&5
+echo "configure:11188: checking for $ac_hdr" >&5
-#line 11230 "configure"
+#line 11191 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11235: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -11263,10 +11224,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11267: checking for dsegv_" >&5
+echo "configure:11228: checking for dsegv_" >&5
-#line 11270 "configure"
+#line 11231 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char dsegv_(); below. */
@@ -11289,7 +11250,7 @@
; return 0; }
EOF
-if { (eval echo configure:11293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11316,13 +11277,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11320: checking for desgv_ in -llapack" >&5
+echo "configure:11281: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11326 "configure"
+#line 11287 "configure"
@@ -11333,7 +11294,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11365,13 +11326,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11369: checking for dgesv_ in -llapack" >&5
+echo "configure:11330: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11375 "configure"
+#line 11336 "configure"
@@ -11382,7 +11343,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11401,13 +11362,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:11405: checking for dgesv_ in -llapack" >&5
+echo "configure:11366: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11411 "configure"
+#line 11372 "configure"
@@ -11418,7 +11379,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11474,7 +11435,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11478: checking whether to use Cairo" >&5
+echo "configure:11439: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11506,7 +11467,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11510: checking for location of cairo includes" >&5
+echo "configure:11471: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11532,15 +11493,15 @@
do
-echo "configure:11536: checking for $ac_hdr" >&5
+echo "configure:11497: checking for $ac_hdr" >&5
-#line 11539 "configure"
+#line 11500 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11576,7 +11537,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11580: checking for location of cairo library" >&5
+echo "configure:11541: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11596,7 +11557,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11600: checking for cairo linking flags" >&5
+echo "configure:11561: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11612,10 +11573,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11616: checking for cairo_create" >&5
+echo "configure:11577: checking for cairo_create" >&5
-#line 11619 "configure"
+#line 11580 "configure"
which can conflict with char cairo_create(); below. */
@@ -11638,7 +11599,7 @@
; return 0; }
EOF
-if { (eval echo configure:11642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11672,10 +11633,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11676: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11637: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11679 "configure"
+#line 11640 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11698,7 +11659,7 @@
; return 0; }
EOF
-if { (eval echo configure:11702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11731,10 +11692,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11735: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11696: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11738 "configure"
+#line 11699 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11757,7 +11718,7 @@
; return 0; }
EOF
-if { (eval echo configure:11761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11799,7 +11760,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11803: checking whether to use FreeType" >&5
+echo "configure:11764: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11818,7 +11779,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11822: checking for location of FreeType includes" >&5
+echo "configure:11783: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11844,15 +11805,15 @@
do
-echo "configure:11848: checking for $ac_hdr" >&5
+echo "configure:11809: checking for $ac_hdr" >&5
-#line 11851 "configure"
+#line 11812 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11886,7 +11847,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11890: checking for location of FreeType library" >&5
+echo "configure:11851: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11911,13 +11872,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11915: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11876: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 11921 "configure"
+#line 11882 "configure"
@@ -11928,7 +11889,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:11932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11969,7 +11930,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:11973: checking whether to use NLS" >&5
+echo "configure:11934: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -11989,10 +11950,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:11993: checking for gettext" >&5
+echo "configure:11954: checking for gettext" >&5
-#line 11996 "configure"
+#line 11957 "configure"
which can conflict with char gettext(); below. */
@@ -12015,7 +11976,7 @@
; return 0; }
EOF
-if { (eval echo configure:12019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12033,13 +11994,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12037: checking for gettext in -lintl" >&5
+echo "configure:11998: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12043 "configure"
+#line 12004 "configure"
@@ -12050,7 +12011,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12015: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12085,7 +12046,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12089: checking whether to use C++" >&5
+echo "configure:12050: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12101,7 +12062,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:12105: checking for $ac_word" >&5
+echo "configure:12066: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12130,7 +12091,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12134: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12095: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12141,12 +12102,12 @@
cat > conftest.$ac_ext << EOF
-#line 12145 "configure"
+#line 12106 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12172,12 +12133,12 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12176: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12137: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12181: checking whether we are using GNU C++" >&5
+echo "configure:12142: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
@@ -12184,7 +12145,7 @@
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12188: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12202,7 +12163,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12206: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12167: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12240,7 +12201,7 @@
'void exit (int);'
do
-#line 12244 "configure"
+#line 12205 "configure"
#include <stdlib.h>
$ac_declaration
@@ -12248,7 +12209,7 @@
exit (42);
; return 0; }
EOF
-if { (eval echo configure:12252: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12213: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -12258,7 +12219,7 @@
fi
rm -f conftest*
-#line 12262 "configure"
+#line 12223 "configure"
$ac_declaration
int main() {
@@ -12265,7 +12226,7 @@
exit (42);
; return 0; }
EOF
-if { (eval echo configure:12269: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12230: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
break
else
@@ -12294,7 +12255,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12298: checking whether to use openDWG" >&5
+echo "configure:12259: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12314,7 +12275,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12318: checking for location of openDGW includes" >&5
+echo "configure:12279: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12340,15 +12301,15 @@
do
-echo "configure:12344: checking for $ac_hdr" >&5
+echo "configure:12305: checking for $ac_hdr" >&5
-#line 12347 "configure"
+#line 12308 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12352: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12313: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12382,7 +12343,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12386: checking for location of openDWG library" >&5
+echo "configure:12347: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12423,7 +12384,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12427: checking whether to use POSIX threads" >&5
+echo "configure:12388: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12443,7 +12404,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12447: checking for location of POSIX threads includes" >&5
+echo "configure:12408: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12469,15 +12430,15 @@
do
-echo "configure:12473: checking for $ac_hdr" >&5
+echo "configure:12434: checking for $ac_hdr" >&5
-#line 12476 "configure"
+#line 12437 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12481: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12442: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12511,7 +12472,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12515: checking for location of POSIX threads library" >&5
+echo "configure:12476: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12536,10 +12497,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12540: checking for pthread_create" >&5
+echo "configure:12501: checking for pthread_create" >&5
-#line 12543 "configure"
+#line 12504 "configure"
which can conflict with char pthread_create(); below. */
@@ -12562,7 +12523,7 @@
; return 0; }
EOF
-if { (eval echo configure:12566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12589,13 +12550,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12593: checking for pthread_create in -lpthread" >&5
+echo "configure:12554: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 12599 "configure"
+#line 12560 "configure"
@@ -12606,7 +12567,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12656,7 +12617,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12660: checking whether to use OpenMP" >&5
+echo "configure:12621: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12677,7 +12638,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12681: checking for location of OpenMP includes" >&5
+echo "configure:12642: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12703,15 +12664,15 @@
do
-echo "configure:12707: checking for $ac_hdr" >&5
+echo "configure:12668: checking for $ac_hdr" >&5
-#line 12710 "configure"
+#line 12671 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12715: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12676: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12749,7 +12710,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12753: checking for location of OpenMP library" >&5
+echo "configure:12714: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12774,10 +12735,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12778: checking for GOMP_parallel_start" >&5
+echo "configure:12739: checking for GOMP_parallel_start" >&5
-#line 12781 "configure"
+#line 12742 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12800,7 +12761,7 @@
; return 0; }
EOF
-if { (eval echo configure:12804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12827,13 +12788,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12831: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12792: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12837 "configure"
+#line 12798 "configure"
@@ -12844,7 +12805,7 @@
; return 0; }
EOF
-if { (eval echo configure:12848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12917,7 +12878,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12921: checking whether to use OpenCL" >&5
+echo "configure:12882: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -12937,7 +12898,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:12941: checking for location of OpenCL includes" >&5
+echo "configure:12902: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -12964,15 +12925,15 @@
do
-echo "configure:12968: checking for $ac_hdr" >&5
+echo "configure:12929: checking for $ac_hdr" >&5
-#line 12971 "configure"
+#line 12932 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12976: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13012,10 +12973,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13016: checking for clGetPlatformInfo" >&5
+echo "configure:12977: checking for clGetPlatformInfo" >&5
-#line 13019 "configure"
+#line 12980 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -13038,7 +12999,7 @@
; return 0; }
EOF
-if { (eval echo configure:13042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -13077,15 +13038,15 @@
do
-echo "configure:13081: checking for $ac_hdr" >&5
+echo "configure:13042: checking for $ac_hdr" >&5
-#line 13084 "configure"
+#line 13045 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13089: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13050: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13118,7 +13079,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13122: checking for location of OpenCL library" >&5
+echo "configure:13083: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13142,13 +13103,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13146: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13107: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 13152 "configure"
+#line 13113 "configure"
@@ -13159,7 +13120,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13219,7 +13180,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13223: checking for special C compiler options needed for large files" >&5
+echo "configure:13184: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13227,7 +13188,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13231 "configure"
+#line 13192 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13243,7 +13204,7 @@
; return 0; }
EOF
-if { (eval echo configure:13247: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13208: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13252,7 +13213,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13256 "configure"
+#line 13217 "configure"
@@ -13268,7 +13229,7 @@
; return 0; }
EOF
-if { (eval echo configure:13272: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13295,11 +13256,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13299: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13260: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13303 "configure"
+#line 13264 "configure"
@@ -13315,7 +13276,7 @@
; return 0; }
EOF
-if { (eval echo configure:13319: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13280: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13322,7 +13283,7 @@
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13326 "configure"
+#line 13287 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13340,7 +13301,7 @@
; return 0; }
EOF
-if { (eval echo configure:13344: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13305: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13366,11 +13327,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13370: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13331: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13374 "configure"
+#line 13335 "configure"
@@ -13386,7 +13347,7 @@
; return 0; }
EOF
-if { (eval echo configure:13390: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13351: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13393,7 +13354,7 @@
rm -rf conftest*
-#line 13397 "configure"
+#line 13358 "configure"
#define _LARGE_FILES 1
@@ -13411,7 +13372,7 @@
; return 0; }
EOF
-if { (eval echo configure:13415: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13376: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13437,11 +13398,11 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13441: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13402: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13445 "configure"
+#line 13406 "configure"
#include <stdio.h>
int main() {
@@ -13448,7 +13409,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13452: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13413: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13455,7 +13416,7 @@
rm -rf conftest*
-#line 13459 "configure"
+#line 13420 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13464,7 +13425,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13468: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13496,11 +13457,11 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13500: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13461: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13504 "configure"
+#line 13465 "configure"
#include <stdio.h>
int main() {
@@ -13507,7 +13468,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13511: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13472: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13514,7 +13475,7 @@
rm -rf conftest*
-#line 13518 "configure"
+#line 13479 "configure"
#include <stdio.h>
@@ -13523,7 +13484,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13527: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13488: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13553,11 +13514,11 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13557: checking for fseeko" >&5
+echo "configure:13518: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13561 "configure"
+#line 13522 "configure"
#include <stdio.h>
int main() {
@@ -13564,7 +13525,7 @@
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13581,10 +13542,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13585: checking if system supports Large Files at all" >&5
+echo "configure:13546: checking if system supports Large Files at all" >&5
-#line 13588 "configure"
+#line 13549 "configure"
#include <stdio.h>
@@ -13616,7 +13577,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13620: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13581: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13817,7 +13778,6 @@
s%@PROJINC@%$PROJINC%g
s%@PROJLIB@%$PROJLIB%g
s%@PROJSHARE@%$PROJSHARE%g
-s%@NAD2BIN@%$NAD2BIN%g
s%@REGEXINCPATH@%$REGEXINCPATH%g
s%@REGEXLIBPATH@%$REGEXLIBPATH%g
s%@REGEXLIB@%$REGEXLIB%g
Modified: grass/branches/releasebranch_7_4/configure.in
--- grass/branches/releasebranch_7_4/configure.in 2019-03-07 20:05:01 UTC (rev 74180)
+++ grass/branches/releasebranch_7_4/configure.in 2019-03-07 20:06:00 UTC (rev 74181)
@@ -682,13 +682,6 @@
AC_SUBST(PROJLIB)
AC_SUBST(PROJSHARE)
-# nad2bin needs to be in path for installing datum gridshift files
-AC_PATH_PROG(NAD2BIN, nad2bin, no)
-if test "$NAD2BIN" = "no"; then
- AC_MSG_ERROR([*** Unable to locate nad2bin (needs to be in PATH).])
-fi
# Done checking PROJ
# Enable regex option
