[GRASS-SVN] r74182 - grass/trunk
Thu Mar 7 12:54:52 PST 2019
Author: neteler
Date: 2019-03-07 12:54:52 -0800 (Thu, 07 Mar 2019)
New Revision: 74182
   grass/trunk/binaryInstall.src
binaryInstall.src: nad2bin no longer used (completes r74179)
Modified: grass/trunk/binaryInstall.src
--- grass/trunk/binaryInstall.src	2019-03-07 20:06:00 UTC (rev 74181)
+++ grass/trunk/binaryInstall.src	2019-03-07 20:54:52 UTC (rev 74182)
@@ -317,27 +317,6 @@
 echo""
-echo "Creating datum transformation gridshift files..."
-if test -x "${DESTDIR}/etc/proj/nad2bin" ; then
-    NAD2BIN="${DESTDIR}/etc/proj/nad2bin"
-else
-    # Use version installed with PROJ.4 (should be in path)
-    NAD2BIN=nad2bin
-fi
-for i in "${DESTDIR}"/etc/proj/nad/src/*.lla
-do
-    "${NAD2BIN}" < $i \
-    "${DESTDIR}"/etc/proj/nad/`echo \`basename "$i"\` | sed 's/.lla//'` && rm -f "$i"
-done
-if test -z "`ls \"${DESTDIR}/etc/proj/nad/src\"`" ; then
-    rmdir "${DESTDIR}/etc/proj/nad/src"
-fi
-echo""
 echo "Generating display font configuration file..."
 GISBASE="$DESTDIR" GISRC=junk LD_LIBRARY_PATH_VAR="${DESTDIR}/lib:$LD_LIBRARY_PATH_VAR" "${DESTDIR}/bin/g.mkfontcap" -o
