[GRASS-SVN] r74235 - in grass/trunk/scripts/v.dissolve: . testsuite
Wed Mar 13 00:28:18 PDT 2019
Author: lucadelu
Date: 2019-03-13 00:28:17 -0700 (Wed, 13 Mar 2019)
New Revision: 74235
Added:
   grass/trunk/scripts/v.dissolve/testsuite/
   grass/trunk/scripts/v.dissolve/testsuite/test_v_dissolve.py
v.dissolve: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/v.dissolve/testsuite/test_v_dissolve.py
--- grass/trunk/scripts/v.dissolve/testsuite/test_v_dissolve.py	                        (rev 0)
+++ grass/trunk/scripts/v.dissolve/testsuite/test_v_dissolve.py	2019-03-13 07:28:17 UTC (rev 74235)
@@ -0,0 +1,40 @@
+Created on Sun Jun 08 23:58:10 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+class TestVDissolve(TestCase):
+    """Test v.dissolve script"""
+    mapName = 'mysoils_general'
+    outputName = 'mysoils_general_families'
+    @classmethod
+    def setUpClass(cls):
+        """Copy vect"""
+        run_command('g.copy', vector='soils_general,mysoils_general')
+    @classmethod
+    def tearDownClass(cls):
+        """Remove vector"""
+        run_command('g.remove', flags='f', type='vector',
+                    name=(cls.mapName, cls.outputName))
+    def test_dissolve(self):
+        """dissolve test"""
+        module = SimpleModule('v.dissolve', input=self.mapName,
+                              output=self.outputName, column='GSL_NAME')
+        self.assertModule(module)
+        self.assertVectorExists(self.outputName)
+if __name__ == '__main__':
+    test()
Property changes on: grass/trunk/scripts/v.dissolve/testsuite/test_v_dissolve.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
