[GRASS-SVN] r74236 - in grass/trunk/scripts/v.db.update: . testsuite
Wed Mar 13 00:30:03 PDT 2019
Author: lucadelu
Date: 2019-03-13 00:30:03 -0700 (Wed, 13 Mar 2019)
New Revision: 74236
Added:
   grass/trunk/scripts/v.db.update/testsuite/
   grass/trunk/scripts/v.db.update/testsuite/test_v_db_update.py
v.db.update: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/v.db.update/testsuite/test_v_db_update.py
--- grass/trunk/scripts/v.db.update/testsuite/test_v_db_update.py	                        (rev 0)
+++ grass/trunk/scripts/v.db.update/testsuite/test_v_db_update.py	2019-03-13 07:30:03 UTC (rev 74236)
@@ -0,0 +1,41 @@
+Created on Sun Jun 08 22:14:26 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+class TestVDbUpdate(TestCase):
+    """Test v.db.update script"""
+    mapName = 'mygeodetic_pts'
+    @classmethod
+    def setUpClass(cls):
+        """Copy vect"""
+        run_command('g.copy', vector='geodetic_pts,mygeodetic_pts')
+    @classmethod
+    def tearDownClass(cls):
+        """Remove vector"""
+        run_command('v.db.dropcolumn', map=cls.mapName, columns="zval")
+        run_command('g.remove', flags='f', type='vector', name=cls.mapName)
+    def test_update(self):
+        """update value test"""
+        run_command('v.db.addcolumn', map=self.mapName,
+                    column="zval double precision")
+        module = SimpleModule('v.db.update', map=self.mapName, column='zval',
+                              query_column="CAST(z_value AS double precision)",
+                              where="z_value <> 'N/A'")
+        self.assertModule(module)
+if __name__ == '__main__':
+    test()
Property changes on: grass/trunk/scripts/v.db.update/testsuite/test_v_db_update.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
