[GRASS-SVN] r74237 - in grass/trunk/scripts/v.db.univar: . testsuite
svn_grass at osgeo.org
Wed Mar 13 00:31:00 PDT 2019
Author: lucadelu
Date: 2019-03-13 00:31:00 -0700 (Wed, 13 Mar 2019)
New Revision: 74237
Added:
grass/trunk/scripts/v.db.univar/testsuite/
grass/trunk/scripts/v.db.univar/testsuite/test_v_db_univar.py
v.db.univar: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/v.db.univar/testsuite/test_v_db_univar.py
--- grass/trunk/scripts/v.db.univar/testsuite/test_v_db_univar.py (rev 0)
+++ grass/trunk/scripts/v.db.univar/testsuite/test_v_db_univar.py 2019-03-13 07:31:00 UTC (rev 74237)
@@ -0,0 +1,47 @@
+Created on Sun Jun 08 19:08:07 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+class TestVDbUnivar(TestCase):
+ """Test v.db.univar script"""
+ mapName = 'elevation'
+ columnName = 'heights'
+ outputMap = 'samples'
+ @classmethod
+ def setUpClass(cls):
+ """Use temp region"""
+ cls.use_temp_region()
+ cls.runModule('g.region', raster=cls.mapName, flags='p')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove temporary region"""
+ cls.runModule('g.remove', flags='f', type='raster', name=cls.mapName)
+ cls.del_temp_region()
+ def test_calculate(self):
+ """run db.univar"""
+ run_command('v.random', output=self.outputMap, n=100, overwrite='True')
+ run_command('v.db.addtable', map=self.outputMap,
+ column="heights double precision")
+ run_command('v.what.rast', map=self.outputMap, raster=self.mapName,
+ column=self.columnName)
+ run_command('v.db.select', map=self.outputMap)
+ module = SimpleModule('v.db.univar', map=self.outputMap,
+ self.assertModule(module)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/scripts/v.db.univar/testsuite/test_v_db_univar.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
