[GRASS-SVN] r74238 - in grass/trunk/scripts/v.db.renamecolumn: . testsuite
svn_grass at osgeo.org
Wed Mar 13 00:36:23 PDT 2019
Author: lucadelu
Date: 2019-03-13 00:36:23 -0700 (Wed, 13 Mar 2019)
New Revision: 74238
Added:
grass/trunk/scripts/v.db.renamecolumn/testsuite/
grass/trunk/scripts/v.db.renamecolumn/testsuite/test_v_db_renamecolumn.py
v.db.renamecolumn: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/v.db.renamecolumn/testsuite/test_v_db_renamecolumn.py
--- grass/trunk/scripts/v.db.renamecolumn/testsuite/test_v_db_renamecolumn.py (rev 0)
+++ grass/trunk/scripts/v.db.renamecolumn/testsuite/test_v_db_renamecolumn.py 2019-03-13 07:36:23 UTC (rev 74238)
@@ -0,0 +1,41 @@
+Created on Sun Jun 07 19:08:34 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+from grass.script.utils import decode
+class TestVDbRenameColumn(TestCase):
+ """Test v.db.renamecolumn script"""
+ @classmethod
+ def setUpClass(cls):
+ """Copy vector."""
+ run_command('g.copy', vector='roadsmajor,myroads')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove copied vector"""
+ run_command('g.remove', type='vector', name='myroads',
+ flags='f')
+ def test_rename_column(self):
+ """Renaming a column"""
+ module = SimpleModule('v.db.renamecolumn', map='myroads',
+ column=('ROAD_NAME', 'roadname'))
+ self.assertModule(module)
+ m = SimpleModule('v.info', flags='c', map='myroads')
+ self.assertModule(m)
+ self.assertRegexpMatches(decode(m.outputs.stdout), 'roadname')
+ self.assertNotRegexpMatches(decode(m.outputs.stdout), 'ROAD_NAME')
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/scripts/v.db.renamecolumn/testsuite/test_v_db_renamecolumn.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
