[GRASS-SVN] r74241 - in grass/trunk/scripts/v.db.dropcolumn: . testsuite
svn_grass at osgeo.org
Wed Mar 13 11:25:06 PDT 2019
Author: lucadelu
Date: 2019-03-13 11:25:06 -0700 (Wed, 13 Mar 2019)
New Revision: 74241
Added:
grass/trunk/scripts/v.db.dropcolumn/testsuite/
grass/trunk/scripts/v.db.dropcolumn/testsuite/test_v_db_dropcolumn.py
v.db.dropcolumn: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/v.db.dropcolumn/testsuite/test_v_db_dropcolumn.py
--- grass/trunk/scripts/v.db.dropcolumn/testsuite/test_v_db_dropcolumn.py (rev 0)
+++ grass/trunk/scripts/v.db.dropcolumn/testsuite/test_v_db_dropcolumn.py 2019-03-13 18:25:06 UTC (rev 74241)
@@ -0,0 +1,40 @@
+Created on Sun Jun 09 01:12:22 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+from grass.script.utils import decode
+class TestVDbDropColumn(TestCase):
+ """Test v.db.dropcolumn script"""
+ @classmethod
+ def setUpClass(cls):
+ """Copy vector."""
+ run_command('g.copy', vector='roadsmajor,myroads')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove copied vector"""
+ run_command('g.remove', type='vector', name='myroads',
+ flags='f')
+ def test_drop_single_column_check(self):
+ """Drop column to the attribute table"""
+ module = SimpleModule('v.db.dropcolumn', map='myroads',
+ columns='SHAPE_LEN')
+ self.assertModule(module)
+ m = SimpleModule('v.info', map='myroads', flags='c')
+ self.assertModule(m)
+ self.assertNotRegexpMatches(decode(m.outputs.stdout), 'SHAPE_LEN')
+if __name__ == '__main__':
+ test()
