[GRASS-SVN] r74242 - in grass/trunk/scripts/v.db.droptable: . testsuite
svn_grass at osgeo.org
Wed Mar 13 11:33:02 PDT 2019
Author: lucadelu
Date: 2019-03-13 11:33:02 -0700 (Wed, 13 Mar 2019)
New Revision: 74242
Added:
grass/trunk/scripts/v.db.droptable/testsuite/
grass/trunk/scripts/v.db.droptable/testsuite/test_v_db_droptable.py
v.db.droptable: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/v.db.droptable/testsuite/test_v_db_droptable.py
--- grass/trunk/scripts/v.db.droptable/testsuite/test_v_db_droptable.py (rev 0)
+++ grass/trunk/scripts/v.db.droptable/testsuite/test_v_db_droptable.py 2019-03-13 18:33:02 UTC (rev 74242)
@@ -0,0 +1,48 @@
+Created on Sun Jun 09 09:18:39 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+from grass.script.utils import decode
+class TestVDbDropTable(TestCase):
+ """Test v.db.droptable script"""
+ @classmethod
+ def setUpClass(cls):
+ """Copy vector."""
+ run_command('g.copy', vector='roadsmajor,myroads')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove copied vector"""
+ run_command('g.remove', type='vector', name='myroads',
+ flags='f')
+ def test_drop_table_check(self):
+ """Drop table check, the column should still be in the table"""
+ module = SimpleModule('v.db.droptable', map='myroads')
+ self.assertModule(module)
+ m = SimpleModule('db.tables', flags='p')
+ self.assertModule(m)
+ self.assertRegexpMatches(decode(m.outputs.stdout), 'myroads')
+ def test_drop_table_with_force(self):
+ """Drop table with force, the column should not be in the table"""
+ module = SimpleModule('v.db.droptable', map='myroads', flags='f')
+ self.assertNotRegexpMatches(decode(m.outputs.stdout), 'myroads')
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/scripts/v.db.droptable/testsuite/test_v_db_droptable.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
