[GRASS-SVN] r74248 - in grass/trunk/scripts/r.out.xyz: . testsuite
svn_grass at osgeo.org
Wed Mar 13 11:51:50 PDT 2019
Author: lucadelu
Date: 2019-03-13 11:51:50 -0700 (Wed, 13 Mar 2019)
New Revision: 74248
Added:
grass/trunk/scripts/r.out.xyz/testsuite/
grass/trunk/scripts/r.out.xyz/testsuite/test_r_out_xyz.py
r.out.xyz: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/r.out.xyz/testsuite/test_r_out_xyz.py
--- grass/trunk/scripts/r.out.xyz/testsuite/test_r_out_xyz.py (rev 0)
+++ grass/trunk/scripts/r.out.xyz/testsuite/test_r_out_xyz.py 2019-03-13 18:51:50 UTC (rev 74248)
@@ -0,0 +1,43 @@
+Created on Sun Jun 08 10:11:18 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+import os
+class TestROutXyz(TestCase):
+ """Test r.out.xyz script"""
+ mapName = 'elev_lid792_1m'
+ csvFile = 'elev_lid792_1m.csv'
+ @classmethod
+ def setUpClass(cls):
+ """Create maps in a small region."""
+ cls.use_temp_region()
+ cls.runModule('g.region', raster=cls.mapName, flags='p')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove temporary region"""
+ cls.del_temp_region()
+ if (os.path.isfile(cls.csvFile)):
+ os.remove(cls.csvFile)
+ def test_r_out_xyz(self):
+ """ASCII text file test"""
+ module = SimpleModule('r.out.xyz', input=self.mapName,
+ output=self.csvFile, separator=",")
+ self.assertModule(module)
+ self.assertFileExists(filename=self.csvFile)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/scripts/r.out.xyz/testsuite/test_r_out_xyz.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
