[GRASS-SVN] r74249 - in grass/trunk/scripts/r.plane: . testsuite
svn_grass at osgeo.org
Wed Mar 13 11:53:22 PDT 2019
Author: lucadelu
Date: 2019-03-13 11:53:22 -0700 (Wed, 13 Mar 2019)
New Revision: 74249
Added:
grass/trunk/scripts/r.plane/testsuite/
grass/trunk/scripts/r.plane/testsuite/test_r_plane.py
r.plane: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/r.plane/testsuite/test_r_plane.py
--- grass/trunk/scripts/r.plane/testsuite/test_r_plane.py (rev 0)
+++ grass/trunk/scripts/r.plane/testsuite/test_r_plane.py 2019-03-13 18:53:22 UTC (rev 74249)
@@ -0,0 +1,41 @@
+Created on Sun Jun 08 12:12:34 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+class TestRPlane(TestCase):
+ """Test r.plane script"""
+ mapName = 'elevation'
+ mapOutput = 'myplane45'
+ @classmethod
+ def setUpClass(cls):
+ """Create maps in a small region."""
+ cls.use_temp_region()
+ cls.runModule('g.region', raster=cls.mapName, flags='p')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove temporary region"""
+ cls.runModule('g.remove', flags='f', type='raster',
+ name=cls.mapOutput)
+ cls.del_temp_region()
+ def test_creates_raster_plane_map(self):
+ """Create a tilted plane raster map test"""
+ module = SimpleModule('r.plane', output=self.mapOutput, dip=45,
+ easting=527500.0, northing=165000.0,
+ elevation=1000, type='FCELL')
+ self.assertModule(module)
+ self.assertRasterExists(self.mapOutput)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/scripts/r.plane/testsuite/test_r_plane.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
