[GRASS-SVN] r74258 - in grass/trunk/scripts/db.droptable: . testsuite
Wed Mar 13 12:58:38 PDT 2019
Author: lucadelu
Date: 2019-03-13 12:58:38 -0700 (Wed, 13 Mar 2019)
New Revision: 74258
Added:
   grass/trunk/scripts/db.droptable/testsuite/
   grass/trunk/scripts/db.droptable/testsuite/test_db_droptable.py
db.droptable: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/db.droptable/testsuite/test_db_droptable.py
--- grass/trunk/scripts/db.droptable/testsuite/test_db_droptable.py	                        (rev 0)
+++ grass/trunk/scripts/db.droptable/testsuite/test_db_droptable.py	2019-03-13 19:58:38 UTC (rev 74258)
@@ -0,0 +1,50 @@
+Created on Sun Jun 07 19:38:12 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+from grass.script.utils import decode
+class TestDbDropTable(TestCase):
+    """Test db.droptable script"""
+    mapName = 'myroads'
+    @classmethod
+    def setUpClass(cls):
+        """Copy vector."""
+        run_command('g.copy', vector='roadsmajor,myroads')
+    @classmethod
+    def tearDownClass(cls):
+        """Remove copied vector"""
+        run_command('g.remove', type='vector', name=cls.mapName,
+                    flags='f')
+    def test_drop_table_check(self):
+        """Drop table check, the column should still be in the table"""
+        module = SimpleModule('db.droptable', table=self.mapName)
+        self.assertModule(module)
+        m = SimpleModule('db.tables', flags='p')
+        self.assertModule(m)
+        self.assertRegexpMatches(decode(m.outputs.stdout), self.mapName)
+    def test_drop_table_with_force(self):
+        """Drop table with force, the column should not be in the table"""
+        module = SimpleModule('db.droptable', table=self.mapName, flags='f')
+        self.assertNotRegexpMatches(decode(m.outputs.stdout), self.mapName)
+if __name__ == '__main__':
+    test()
Property changes on: grass/trunk/scripts/db.droptable/testsuite/test_db_droptable.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
