[GRASS-SVN] r74259 - in grass/trunk/scripts/db.in.ogr: . testsuite
svn_grass at osgeo.org
Wed Mar 13 13:00:45 PDT 2019
Author: lucadelu
Date: 2019-03-13 13:00:45 -0700 (Wed, 13 Mar 2019)
New Revision: 74259
Added:
grass/trunk/scripts/db.in.ogr/testsuite/
grass/trunk/scripts/db.in.ogr/testsuite/test_db_in_ogr.py
db.in.ogr: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/db.in.ogr/testsuite/test_db_in_ogr.py
--- grass/trunk/scripts/db.in.ogr/testsuite/test_db_in_ogr.py (rev 0)
+++ grass/trunk/scripts/db.in.ogr/testsuite/test_db_in_ogr.py 2019-03-13 20:00:45 UTC (rev 74259)
@@ -0,0 +1,63 @@
+Created on Sun Jun 07 20:14:04 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+from grass.script.utils import decode
+import os
+class TestDbInOgr(TestCase):
+ """Test db.in.ogr script"""
+ csvFile = 'sample_data.csv'
+ dbfFile = 'sample_data.dbf'
+ tableName1 = 'sample_table1'
+ tableName2 = 'sample_table2'
+ @classmethod
+ def setUpClass(cls):
+ """Create temporary files. Remove if the tables already exists."""
+ cls.runModule('db.out.ogr', input='geology', output=cls.csvFile)
+ cls.runModule('db.out.ogr', input='geology', output=cls.dbfFile,
+ format='DBF')
+ cls.runModule('db.droptable', table=cls.tableName1, flags='f')
+ cls.runModule('db.droptable', table=cls.tableName2, flags='f')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the created files and the created table"""
+ os.remove(cls.csvFile)
+ os.remove(cls.dbfFile)
+ def test_import_csv_file(self):
+ """import csv table"""
+ module = SimpleModule('db.in.ogr', input=self.csvFile,
+ output=self.tableName1)
+ self.assertModule(module)
+ m = SimpleModule('db.tables', flags='p')
+ self.assertModule(m)
+ self.assertRegexpMatches(decode(m.outputs.stdout), self.tableName1)
+ def test_import_dbf_file(self):
+ """import dbf table"""
+ module = SimpleModule('db.in.ogr', input=self.dbfFile,
+ output=self.tableName2)
+ self.assertRegexpMatches(decode(m.outputs.stdout), self.tableName2)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/scripts/db.in.ogr/testsuite/test_db_in_ogr.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
