[GRASS-SVN] r74277 - grass/trunk/vector/v.what/testsuite
svn_grass at osgeo.org
Fri Mar 15 15:18:34 PDT 2019
Author: sbl
Date: 2019-03-15 15:18:34 -0700 (Fri, 15 Mar 2019)
New Revision: 74277
grass/trunk/vector/v.what/testsuite/test_vwhat_layers.py
grass/trunk/vector/v.what/testsuite/test_vwhat_ncspm.py
partly fix v.what test
Modified: grass/trunk/vector/v.what/testsuite/test_vwhat_layers.py
--- grass/trunk/vector/v.what/testsuite/test_vwhat_layers.py 2019-03-15 22:01:48 UTC (rev 74276)
+++ grass/trunk/vector/v.what/testsuite/test_vwhat_layers.py 2019-03-15 22:18:34 UTC (rev 74277)
@@ -178,16 +178,16 @@
def test_run(self):
self.assertModule(self.vwhat)
- self.assertLooksLike(reference=out1, actual=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out1, actual=self.vwhat.outputs.stdout.encode('utf8'))
def test_print_options(self):
self.vwhat.flags['a'].value = True
- self.assertLooksLike(reference=out2, actual=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out2, actual=self.vwhat.outputs.stdout.encode('utf8'))
self.vwhat.flags['g'].value = True
- self.assertLooksLike(reference=out3, actual=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out3, actual=self.vwhat.outputs.stdout.encode('utf8'))
def test_print_options_json(self):
import json
@@ -204,16 +204,16 @@
self.vwhat.inputs.layer = 1
- self.assertLooksLike(reference=out4, actual=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out4, actual=self.vwhat.outputs.stdout.encode('utf8'))
self.vwhat.inputs.layer = 2
self.vwhat.flags['a'].value = False
- self.assertLooksLike(reference=out5, actual=self.vwhat.outputs.stdout)
+ self.assertLooksLike(reference=out5, actual=self.vwhat.outputs.stdout.encode('utf8'))
if __name__ == '__main__':
test()
Modified: grass/trunk/vector/v.what/testsuite/test_vwhat_ncspm.py
--- grass/trunk/vector/v.what/testsuite/test_vwhat_ncspm.py 2019-03-15 22:01:48 UTC (rev 74276)
+++ grass/trunk/vector/v.what/testsuite/test_vwhat_ncspm.py 2019-03-15 22:18:34 UTC (rev 74277)
@@ -182,21 +182,21 @@
def test_multiple_maps(self):
- self.assertMultiLineEqual(first=out1, second=self.vwhat.outputs.stdout)
+ self.assertMultiLineEqual(first=out1, second=self.vwhat.outputs.stdout.encode('utf8'))
def test_threshold(self):
self.vwhat.inputs['distance'].value = 100
import json
