[GRASS-SVN] r74278 - grass/trunk/raster/r.contour/testsuite
svn_grass at osgeo.org
Sat Mar 16 06:52:18 PDT 2019
Author: sbl
Date: 2019-03-16 06:52:18 -0700 (Sat, 16 Mar 2019)
New Revision: 74278
grass/trunk/raster/r.contour/testsuite/testrc.py
fix space / tabs in r.contour test
Modified: grass/trunk/raster/r.contour/testsuite/testrc.py
--- grass/trunk/raster/r.contour/testsuite/testrc.py 2019-03-15 22:18:34 UTC (rev 74277)
+++ grass/trunk/raster/r.contour/testsuite/testrc.py 2019-03-16 13:52:18 UTC (rev 74278)
@@ -1,12 +1,12 @@
Purpose: Tests r.contour and its flags/options.
Author: Sunveer Singh, Google Code-in 2018
Copyright: (C) 2018 by Sunveer Singh and the GRASS Development Team
Licence: This program is free software under the GNU General Public
- License (>=v2). Read the file COPYING that comes with GRASS
- for details.
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
from grass.gunittest.case import TestCase
from grass.gunittest.main import test
@@ -74,7 +74,7 @@
def setUpClass(cls):
cls.use_temp_region()
cls.runModule('g.region', raster=cls.input)
@classmethod
def tearDownClass(cls):
cls.del_temp_region()
@@ -90,7 +90,7 @@
max=6"""
self.assertModule('r.contour', input=self.input, output=self.output, levels=1, step=1, flags='t')
self.assertRasterFitsUnivar(self.output,
- reference=string, precision=2)
+ reference=string, precision=2)
def test_vector(self):
"""Testing vector output"""
@@ -97,8 +97,7 @@
self.assertModule('r.contour', input=self.input, output=self.output, step=5, flags='t')
self.assertModule('v.info', map=self.output, flags='t')
topology = dict(points=0, lines=2222, areas=0)
- self.assertVectorFitsTopoInfo(self.output, topology)
+ self.assertVectorFitsTopoInfo(self.output, topology)
def test_v_db_select(self):
"""Testing attribute values of contours with v.db.select """
