[GRASS-SVN] r74302 - grass/trunk/scripts/i.pansharpen
Mon Mar 25 03:17:11 PDT 2019
Author: cmbarton
Date: 2019-03-25 03:17:11 -0700 (Mon, 25 Mar 2019)
New Revision: 74302
   grass/trunk/scripts/i.pansharpen/i.pansharpen.py
improved cleanup and garbage collection
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py	2019-03-24 06:11:29 UTC (rev 74301)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py	2019-03-25 10:17:11 UTC (rev 74302)
@@ -265,8 +265,11 @@
     # Cleanup
     grass.message(_("cleaning up temp files"))
-    grass.run_command('g.remove', flags="f", type="raster",
-                       pattern="tmp%s*" % pid, quiet=True)
+    try:
+        grass.run_command('g.remove', flags="f", type="raster",
+                           pattern="tmp%s*" % pid, quiet=True)
+    except:
 def brovey(pan, ms1, ms2, ms3, out, pid, sproc):
     grass.verbose(_("Using Brovey algorithm"))
@@ -311,13 +314,18 @@
                                  (out, ms3, panmatch3, ms1, ms2, ms3),
                                  overwrite=True)
-        pb.wait()
-        pg.wait()
-        pr.wait()
+        pb.wait(), pg.wait(), pr.wait()
+        try:
+            pb.terminate(), pg.terminate(), pr.terminate()
+        except:
     # Cleanup
-    grass.run_command('g.remove', flags='f', quiet=True, type='raster',
-                      name='%s,%s,%s' % (panmatch1, panmatch2, panmatch3))
+    try:
+        grass.run_command('g.remove', flags='f', quiet=True, type='raster',
+                          name='%s,%s,%s' % (panmatch1, panmatch2, panmatch3))
+    except:
 def ihs(pan, ms1, ms2, ms3, out, pid, sproc):
     grass.verbose(_("Using IHS<->RGB algorithm"))
@@ -347,8 +355,11 @@
                       blue="%s_blue" % out)
     # Cleanup
-                      name=panmatch)
+    try:
+                          name=panmatch)
+    except:
 def pca(pan, ms1, ms2, ms3, out, pid, sproc):
@@ -477,17 +488,16 @@
                                         b3mean),
                                      overwrite=True)
-            pb.wait()
-            pg.wait()
-            pr.wait()
+            try:
+            except:
     # Cleanup
-    grass.run_command('g.remove', flags='f', quiet=True, type="raster",
-                      pattern='tmp%s*' % pid)
 def matchhist(original, target, matched):
     # pan/intensity histogram matching using numpy arrays
     grass.message(_("Histogram matching..."))
