[GRASS-SVN] r74303 - in grass/trunk/vector: v.in.lidar/testsuite v.in.pdal/testsuite
Mon Mar 25 15:53:30 PDT 2019
Author: sbl
Date: 2019-03-25 15:53:30 -0700 (Mon, 25 Mar 2019)
New Revision: 74303
Added:
   grass/trunk/vector/v.in.pdal/testsuite/test_v_in_pdal_basic.py
   grass/trunk/vector/v.in.pdal/testsuite/test_v_in_pdal_filter.py
Removed:
   grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py
   grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py
Move v.in.pdal tests back; see #3792
Deleted: grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py
--- grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py	2019-03-25 10:17:11 UTC (rev 74302)
+++ grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py	2019-03-25 22:53:30 UTC (rev 74303)
@@ -1,73 +0,0 @@
-Name:      basic_test
-Purpose:   v.in.pdal basic functionality test
-Author:    Vaclav Petras
-Copyright: (C) 2015 by Vaclav Petras and the GRASS Development Team
-Licence:   This program is free software under the GNU General Public
-           License (>=v2). Read the file COPYING that comes with GRASS
-           for details.
-import os
-from grass.gunittest.case import TestCase
-from grass.gunittest.main import test
-import unittest
-from grass.script import shutil_which
-class BasicTest(TestCase):
-    """Test case for watershed module
-    This tests expects v.random and v.out.lidar to work properly.
-    # Setup variables to be used for outputs
-    vector_generated = 'vinlidar_basic_generated'
-    vector_points = 'vinlidar_basic_original'
-    imported_points = 'vinlidar_basic_imported'
-    las_file = 'vinlidar_basic_points.las'
-    npoints = 300
-    @classmethod
-    def setUpClass(cls):
-        """Ensures expected computational region and generated data"""
-        cls.use_temp_region()
-        cls.runModule('g.region', n=20, s=10, e=25, w=15, res=1)
-        cls.runModule('v.random', flags='zb', output=cls.vector_generated,
-            npoints=cls.npoints, zmin=200, zmax=500, seed=100)
-        cls.runModule('v.category', input=cls.vector_generated,
-            output=cls.vector_points, option='del', cat=-1)
-        cls.runModule('v.out.lidar', input=cls.vector_points,
-            output=cls.las_file)
-    @classmethod
-    def tearDownClass(cls):
-        """Remove the temporary region and generated data"""
-        cls.runModule('g.remove', flags='f', type='vector',
-            name=(cls.vector_points, cls.vector_generated))
-        if os.path.isfile(cls.las_file):
-            os.remove(cls.las_file)
-        cls.del_temp_region()
-    def tearDown(self):
-        """Remove the outputs created by the import
-        This is executed after each test run.
-        self.runModule('g.remove', flags='f', type='vector',
-            name=self.imported_points)
-    @unittest.skipIf(shutil_which('v.in.pdal') is None, "Cannot find v.in.pdal")
-    def test_same_data(self):
-        """Test to see if the standard outputs are created"""
-        self.assertModule('v.in.pdal', input=self.las_file, flags='c',
-            output=self.imported_points)
-        self.assertVectorExists(self.imported_points)
-        self.assertVectorEqualsVector(
-            actual=self.imported_points,
-            reference=self.vector_points,
-            digits=2, precision=.01)
-if __name__ == '__main__':
-    test()
Deleted: grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py
--- grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py	2019-03-25 10:17:11 UTC (rev 74302)
+++ grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py	2019-03-25 22:53:30 UTC (rev 74303)
@@ -1,227 +0,0 @@
-Name:      filter_test
-Purpose:   v.in.pdal test if various filters and selections
-           for details.
-import os
-import unittest
-POINTS = """\
-17.46938776,18.67346939,143,1,1,2
-20.93877551,17.44897959,125,1,1,2
-18.89795918,14.18367347,130,1,1,3
-15.91836735,10.67346939,126,1,1,3
-21.26530612,11.04081633,128,1,2,3
-22.24489796,13.89795918,123,2,2,3
-23.79591837,17.12244898,151,1,2,3
-17.2244898,16.34693878,124,2,2,4
-17.14285714,14.10204082,134,1,3,4
-19.87755102,11.81632653,146,2,3,4
-18.48979592,11.48979592,140.6,2,3,4
-21.26530612,15.73469388,147,3,3,5
-21.18367347,19.32653061,138,1,3,5
-23.91836735,18.83673469,144,2,3,5
-23.51020408,13.65306122,143,3,3,5
-23.55102041,11.32653061,123,1,4,5
-18.41009273,14.51618034,140.4,2,4,5
-22.13996161,17.2278263,147,3,4,5
-21.41013052,11.05432488,132,4,4,5
-class FilterTest(TestCase):
-    """Test case for filter and selection options
-    vector_points = 'vinlidar_filters_original'
-    imported_points = 'vinlidar_filters_imported'
-    las_file = 'vinlidar_filters_points.las'
-    npoints = 300
-    @classmethod
-        cls.runModule('v.in.ascii', input='-', stdin_=POINTS,
-                      flags='z', z=3, cat=0, separator='comma',
-                      columns="x double precision, y double precision,"
-                              " z double precision, return_n integer,"
-                              " n_returns integer, class_n integer")
-                      input=cls.vector_points, layer=1,
-                      output=cls.las_file,
-                      return_column='return_n',
-                      n_returns_column='n_returns',
-                      class_column='class_n')
-    @classmethod
-            name=cls.vector_points)
-    def test_no_filter(self):
-        This shows if the inpute data are as expected.
-        self.assertVectorFitsTopoInfo(
-            vector=self.imported_points,
-            reference=dict(points=19))
-    def return_filter(self, name, npoints):
-        """Mid return filter test"""
-            output=self.imported_points,
-            return_filter=name)
-            reference=dict(points=npoints))
-    def test_first_return_filter(self):
-        """First return filter test"""
-        self.return_filter('first', 9)
-    def test_mid_return_filter(self):
-        self.return_filter('mid', 5)
-    def test_last_return_filter(self):
-        """Last return filter test"""
-        self.return_filter('last', 5)
-    def class_filter(self, class_n, npoints):
-        """Actual code for testing class filter"""
-            class_filter=class_n)
-    def test_class_2_filter(self):
-        """Test to filter classes"""
-        self.class_filter(2, 2)
-    def test_class_3_filter(self):
-        self.class_filter(3, 5)
-    def test_class_4_filter(self):
-        self.class_filter(4, 4)
-    def test_class_5_filter(self):
-        self.class_filter(5, 8)
-    def return_and_class_filter(self, return_name, class_n, npoints):
-        """Return and class filter combined test code"""
-            return_filter=return_name, class_filter=class_n)
-    def test_first_return_and_class_filter(self):
-        """Combined test for return and class"""
-        self.return_and_class_filter('first', 2, 2)
-    def test_last_return_and_class_filter(self):
-        self.return_and_class_filter('last', 5, 3)
-    def zrange_filter(self, zrange, npoints):
-        """Actual code for zrange option test"""
-            zrange=zrange)
-    def test_zrange_filter(self):
-        """Test zrange option"""
-        self.zrange_filter((130.1, 139.9), 3)
-    def test_non_int_zrange_filter(self):
-        """Test zrange option with float number
-        One test point has z right under and one other right above the min.
-        self.zrange_filter((140.5, 900), 8)
-    def test_zrange_and_class_filter(self):
-        """zrange and class_filter option combined test"""
-            zrange=(141, 900), class_filter=5)
-            reference=dict(points=4))
-    def test_zrange_and_return_filter(self):
-            zrange=(141, 900), return_filter='last')
-            reference=dict(points=2))
-    test()
Copied: grass/trunk/vector/v.in.pdal/testsuite/test_v_in_pdal_basic.py (from rev 74302, grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_basic.py)
--- grass/trunk/vector/v.in.pdal/testsuite/test_v_in_pdal_basic.py	                        (rev 0)
+++ grass/trunk/vector/v.in.pdal/testsuite/test_v_in_pdal_basic.py	2019-03-25 22:53:30 UTC (rev 74303)
@@ -0,0 +1,73 @@
+Name:      basic_test
+Purpose:   v.in.pdal basic functionality test
+Author:    Vaclav Petras
+Copyright: (C) 2015 by Vaclav Petras and the GRASS Development Team
+Licence:   This program is free software under the GNU General Public
+           License (>=v2). Read the file COPYING that comes with GRASS
+           for details.
+import os
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+import unittest
+from grass.script import shutil_which
+class BasicTest(TestCase):
+    """Test case for watershed module
+    This tests expects v.random and v.out.lidar to work properly.
+    # Setup variables to be used for outputs
+    vector_generated = 'vinlidar_basic_generated'
+    vector_points = 'vinlidar_basic_original'
+    imported_points = 'vinlidar_basic_imported'
+    las_file = 'vinlidar_basic_points.las'
+    npoints = 300
+    @classmethod
+    def setUpClass(cls):
+        """Ensures expected computational region and generated data"""
+        cls.use_temp_region()
+        cls.runModule('g.region', n=20, s=10, e=25, w=15, res=1)
+        cls.runModule('v.random', flags='zb', output=cls.vector_generated,
+            npoints=cls.npoints, zmin=200, zmax=500, seed=100)
+        cls.runModule('v.category', input=cls.vector_generated,
+            output=cls.vector_points, option='del', cat=-1)
+        cls.runModule('v.out.lidar', input=cls.vector_points,
+            output=cls.las_file)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region and generated data"""
+        cls.runModule('g.remove', flags='f', type='vector',
+            name=(cls.vector_points, cls.vector_generated))
+        if os.path.isfile(cls.las_file):
+            os.remove(cls.las_file)
+        cls.del_temp_region()
+    def tearDown(self):
+        """Remove the outputs created by the import
+        This is executed after each test run.
+        self.runModule('g.remove', flags='f', type='vector',
+            name=self.imported_points)
+    @unittest.skipIf(shutil_which('v.in.pdal') is None, "Cannot find v.in.pdal")
+    def test_same_data(self):
+        """Test to see if the standard outputs are created"""
+        self.assertModule('v.in.pdal', input=self.las_file, flags='c',
+            output=self.imported_points)
+        self.assertVectorExists(self.imported_points)
+        self.assertVectorEqualsVector(
+            actual=self.imported_points,
+            reference=self.vector_points,
+            digits=2, precision=.01)
+if __name__ == '__main__':
+    test()
Copied: grass/trunk/vector/v.in.pdal/testsuite/test_v_in_pdal_filter.py (from rev 74302, grass/trunk/vector/v.in.lidar/testsuite/test_v_in_pdal_filter.py)
--- grass/trunk/vector/v.in.pdal/testsuite/test_v_in_pdal_filter.py	                        (rev 0)
+++ grass/trunk/vector/v.in.pdal/testsuite/test_v_in_pdal_filter.py	2019-03-25 22:53:30 UTC (rev 74303)
@@ -0,0 +1,227 @@
+Name:      filter_test
+Purpose:   v.in.pdal test if various filters and selections
+           for details.
+import os
+import unittest
+POINTS = """\
+17.46938776,18.67346939,143,1,1,2
+20.93877551,17.44897959,125,1,1,2
+18.89795918,14.18367347,130,1,1,3
+15.91836735,10.67346939,126,1,1,3
+21.26530612,11.04081633,128,1,2,3
+22.24489796,13.89795918,123,2,2,3
+23.79591837,17.12244898,151,1,2,3
+17.2244898,16.34693878,124,2,2,4
+17.14285714,14.10204082,134,1,3,4
+19.87755102,11.81632653,146,2,3,4
+18.48979592,11.48979592,140.6,2,3,4
+21.26530612,15.73469388,147,3,3,5
+21.18367347,19.32653061,138,1,3,5
+23.91836735,18.83673469,144,2,3,5
+23.51020408,13.65306122,143,3,3,5
+23.55102041,11.32653061,123,1,4,5
+18.41009273,14.51618034,140.4,2,4,5
+22.13996161,17.2278263,147,3,4,5
+21.41013052,11.05432488,132,4,4,5
+class FilterTest(TestCase):
+    """Test case for filter and selection options
+    vector_points = 'vinlidar_filters_original'
+    imported_points = 'vinlidar_filters_imported'
+    las_file = 'vinlidar_filters_points.las'
+    npoints = 300
+    @classmethod
+        cls.runModule('v.in.ascii', input='-', stdin_=POINTS,
+                      flags='z', z=3, cat=0, separator='comma',
+                      columns="x double precision, y double precision,"
+                              " z double precision, return_n integer,"
+                              " n_returns integer, class_n integer")
+                      input=cls.vector_points, layer=1,
+                      output=cls.las_file,
+                      return_column='return_n',
+                      n_returns_column='n_returns',
+                      class_column='class_n')
+    @classmethod
+            name=cls.vector_points)
+    def test_no_filter(self):
+        This shows if the inpute data are as expected.
+        self.assertVectorFitsTopoInfo(
+            vector=self.imported_points,
+            reference=dict(points=19))
+    def return_filter(self, name, npoints):
+        """Mid return filter test"""
+            output=self.imported_points,
+            return_filter=name)
+            reference=dict(points=npoints))
+    def test_first_return_filter(self):
+        """First return filter test"""
+        self.return_filter('first', 9)
+    def test_mid_return_filter(self):
+        self.return_filter('mid', 5)
+    def test_last_return_filter(self):
+        """Last return filter test"""
+        self.return_filter('last', 5)
+    def class_filter(self, class_n, npoints):
+        """Actual code for testing class filter"""
+            class_filter=class_n)
+    def test_class_2_filter(self):
+        """Test to filter classes"""
+        self.class_filter(2, 2)
+    def test_class_3_filter(self):
+        self.class_filter(3, 5)
+    def test_class_4_filter(self):
+        self.class_filter(4, 4)
+    def test_class_5_filter(self):
+        self.class_filter(5, 8)
+    def return_and_class_filter(self, return_name, class_n, npoints):
+        """Return and class filter combined test code"""
+            return_filter=return_name, class_filter=class_n)
+    def test_first_return_and_class_filter(self):
+        """Combined test for return and class"""
+        self.return_and_class_filter('first', 2, 2)
+    def test_last_return_and_class_filter(self):
+        self.return_and_class_filter('last', 5, 3)
+    def zrange_filter(self, zrange, npoints):
+        """Actual code for zrange option test"""
+            zrange=zrange)
+    def test_zrange_filter(self):
+        """Test zrange option"""
+        self.zrange_filter((130.1, 139.9), 3)
+    def test_non_int_zrange_filter(self):
+        """Test zrange option with float number
+        One test point has z right under and one other right above the min.
+        self.zrange_filter((140.5, 900), 8)
+    def test_zrange_and_class_filter(self):
+        """zrange and class_filter option combined test"""
+            zrange=(141, 900), class_filter=5)
+            reference=dict(points=4))
+    def test_zrange_and_return_filter(self):
+            zrange=(141, 900), return_filter='last')
+            reference=dict(points=2))
+    test()
