[GRASS-SVN] r74304 - grass/trunk/vector/v.univar/testsuite
svn_grass at osgeo.org
Mon Mar 25 16:25:18 PDT 2019
Author: sbl
Date: 2019-03-25 16:25:18 -0700 (Mon, 25 Mar 2019)
New Revision: 74304
grass/trunk/vector/v.univar/testsuite/v_univar_test.py
replace census with lakes map in test
Modified: grass/trunk/vector/v.univar/testsuite/v_univar_test.py
--- grass/trunk/vector/v.univar/testsuite/v_univar_test.py 2019-03-25 22:53:30 UTC (rev 74303)
+++ grass/trunk/vector/v.univar/testsuite/v_univar_test.py 2019-03-25 23:25:18 UTC (rev 74304)
@@ -15,24 +15,24 @@
class TestProfiling(TestCase):
def test_flagg(self):
- """Testing flag g with map census"""
- output_str = """n=2537
+ """Testing flag g with map lakes"""
+ output_str = """n=15279
nmissing=0
nnull=0
min=1
-max=2537
-range=2536
-sum=3.21945e+06
-mean=1269
-mean_abs=1269
-population_stddev=732.369
-population_variance=536364
-population_coeff_variation=0.577123
-sample_stddev=732.513
-sample_variance=536576
-kurtosis=-1.20142
-skewness=0"""
- v_univar = SimpleModule("v.univar", flags="g", map='census', column='cat')
+max=15279
+range=15278
+sum=1.16732e+08
+mean=7640
+mean_abs=7640
+population_stddev=4410.67
+population_variance=1.9454e+07
+population_coeff_variation=0.577312
+sample_stddev=4410.81
+sample_variance=1.94553e+07
+kurtosis=-1.20024
+skewness=-2.41826e-14"""
+ v_univar = SimpleModule("v.univar", flags="g", map='lakes', column='cat')
v_univar.run()
self.assertLooksLike(actual=v_univar.outputs.stdout.encode('utf8'),
reference=output_str)
