[GRASS-SVN] r74325 - in grass/trunk/lib/python/pygrass: raster vector
svn_grass at osgeo.org
Thu Mar 28 08:13:13 PDT 2019
Author: sbl
Date: 2019-03-28 08:13:13 -0700 (Thu, 28 Mar 2019)
New Revision: 74325
grass/trunk/lib/python/pygrass/raster/__init__.py
grass/trunk/lib/python/pygrass/vector/__init__.py
grass/trunk/lib/python/pygrass/vector/geometry.py
grass/trunk/lib/python/pygrass/vector/table.py
fix doctests
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py 2019-03-28 14:23:43 UTC (rev 74324)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py 2019-03-28 15:13:13 UTC (rev 74325)
@@ -85,9 +85,9 @@
>>> elev.hist.title = "A test map"
>>> elev.hist.write()
>>> elev.hist.title
- 'A test map'
+ u'A test map'
>>> elev.hist.keyword
- 'This is a test map'
+ u'This is a test map'
>>> attrs = list(elev.hist)
>>> attrs[0]
@@ -487,10 +487,10 @@
>>> map_b.open("r")
>>> for row in map_b:
... row
- Buffer([ 111., 121., 131., 141.], dtype=float32)
- Buffer([ 112., 122., 132., 142.], dtype=float32)
- Buffer([ 113., 123., 133., 143.], dtype=float32)
- Buffer([ 114., 124., 134., 144.], dtype=float32)
+ Buffer([111., 121., 131., 141.], dtype=float32)
+ Buffer([112., 122., 132., 142.], dtype=float32)
+ Buffer([113., 123., 133., 143.], dtype=float32)
+ Buffer([114., 124., 134., 144.], dtype=float32)
>>> map_b.close()
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2019-03-28 14:23:43 UTC (rev 74324)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2019-03-28 15:13:13 UTC (rev 74325)
@@ -363,7 +363,7 @@
>>> test_vect.number_of("holes")
0
>>> test_vect.number_of("lines")
- 21
+ 3
>>> test_vect.number_of("nodes")
15
>>> test_vect.number_of("pizza")
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2019-03-28 14:23:43 UTC (rev 74324)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2019-03-28 15:13:13 UTC (rev 74325)
@@ -374,7 +374,7 @@
>>> pnt = Point(10, 100)
>>> pnt.to_wkt()
- 'POINT (10.0000000000000000 100.0000000000000000)'
+ u'POINT (10.0000000000000000 100.0000000000000000)'
return decode(libvect.Vect_line_to_wkt(self.c_points, self.gtype, not self.is2D))
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py 2019-03-28 14:23:43 UTC (rev 74324)
+++ grass/trunk/lib/python/pygrass/vector/table.py 2019-03-28 15:13:13 UTC (rev 74325)
@@ -588,15 +588,15 @@
>>> link.layer
1
>>> link.name
- 'link0'
+ u'link0'
>>> link.table_name
- 'table_doctest_map'
+ u'table_doctest_map'
>>> link.key
- 'cat'
+ u'cat'
>>> link.database
- '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
+ u'$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
>>> link.driver
- 'sqlite'
+ u'sqlite'
>>> link
Link(1, link0, sqlite)
@@ -737,7 +737,7 @@
>>> conn = link.connection()
>>> cur = conn.cursor()
>>> link.table_name
>>> cur.execute("SELECT cat, name, value from %s" %
... link.table_name) # doctest: +ELLIPSIS
<sqlite3.Cursor object at ...>
