[GRASS-SVN] r74326 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Thu Mar 28 08:14:10 PDT 2019
Author: sbl
Date: 2019-03-28 08:14:10 -0700 (Thu, 28 Mar 2019)
New Revision: 74326
grass/trunk/lib/python/script/array.py
fix doctests
Modified: grass/trunk/lib/python/script/array.py
--- grass/trunk/lib/python/script/array.py 2019-03-28 15:13:13 UTC (rev 74325)
+++ grass/trunk/lib/python/script/array.py 2019-03-28 15:14:10 UTC (rev 74326)
@@ -23,10 +23,10 @@
>>> # Lets have a look at the array
... print(map2d_1)
-[[ 0. 1. 2. 3. 4. 5.]
- [ 1. 2. 3. 4. 5. 6.]
- [ 2. 3. 4. 5. 6. 7.]
- [ 3. 4. 5. 6. 7. 8.]]
+[[0. 1. 2. 3. 4. 5.]
+ [1. 2. 3. 4. 5. 6.]
+ [2. 3. 4. 5. 6. 7.]
+ [3. 4. 5. 6. 7. 8.]]
>>> # This will write the numpy array as GRASS raster map
... # with name map2d_1
... map2d_1.write(mapname="map2d_1", overwrite=True)
@@ -39,10 +39,10 @@
... map2d_2 %= 3
>>> # Show the result
... print(map2d_2)
-[[ 0. 1. 2. 0. 1. 2.]
- [ 1. 2. 0. 1. 2. 0.]
- [ 2. 0. 1. 2. 0. 1.]
- [ 0. 1. 2. 0. 1. 2.]]
+[[0. 1. 2. 0. 1. 2.]
+ [1. 2. 0. 1. 2. 0.]
+ [2. 0. 1. 2. 0. 1.]
+ [0. 1. 2. 0. 1. 2.]]
>>> # Write the result as new raster map with name map2d_2
... map2d_2.write(mapname="map2d_2", overwrite=True)
0
@@ -60,20 +60,20 @@
>>> # Lets have a look at the 3D array
... print(map3d_1)
-[[[ 0. 1. 2. 3. 4. 5.]
+[[[ 0. 1. 2. 3. 4. 5.]
+ [ 1. 2. 3. 4. 5. 6.]
+ [ 2. 3. 4. 5. 6. 7.]
+ [ 3. 4. 5. 6. 7. 8.]]
<BLANKLINE>
- [[ 1. 2. 3. 4. 5. 6.]
- [ 4. 5. 6. 7. 8. 9.]]
+ [[ 1. 2. 3. 4. 5. 6.]
+ [ 4. 5. 6. 7. 8. 9.]]
<BLANKLINE>
- [[ 2. 3. 4. 5. 6. 7.]
- [ 5. 6. 7. 8. 9. 10.]]]
+ [[ 2. 3. 4. 5. 6. 7.]
+ [ 5. 6. 7. 8. 9. 10.]]]
>>> # This will write the numpy array as GRASS 3D raster map
... # with name map3d_1
... map3d_1.write(mapname="map3d_1", overwrite=True)
@@ -85,20 +85,20 @@
... map3d_2 %= 3
>>> # Show the result
... print(map3d_2)
-[[[ 0. 1. 2. 0. 1. 2.]
+[[[0. 1. 2. 0. 1. 2.]
<BLANKLINE>
- [[ 1. 2. 0. 1. 2. 0.]
- [ 1. 2. 0. 1. 2. 0.]]
+ [[1. 2. 0. 1. 2. 0.]
+ [1. 2. 0. 1. 2. 0.]]
<BLANKLINE>
- [[ 2. 0. 1. 2. 0. 1.]
- [ 2. 0. 1. 2. 0. 1.]]]
+ [[2. 0. 1. 2. 0. 1.]
+ [2. 0. 1. 2. 0. 1.]]]
>>> # Write the result as new 3D raster map with name map3d_2
... map3d_2.write(mapname="map3d_2", overwrite=True)
0
