[GRASS-git] [OSGeo/grass] 39868e: g.copy: Report failed copy using an error message ...
Vaclav Petras
noreply at github.com
Tue Nov 17 14:11:16 PST 2020
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass
Commit: 39868ea5c6112047525cc2e3a80802ad6c0956be
https://github.com/OSGeo/grass/commit/39868ea5c6112047525cc2e3a80802ad6c0956be
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2020-11-17 (Tue, 17 Nov 2020)
Changed paths:
M general/g.copy/g.copy.html
M general/g.copy/main.c
M lib/manage/do_copy.c
Log Message:
g.copy: Report failed copy using an error message (#1086)
Changes in behavior:
1. Non-zero return code (EXIT_FAILURE) has now also a corresponding
error message (ERROR:) not just warning messages (from
do_copy.c).
2. Skipping an input as ineligible for copying may now result in
an error (fatal error with EXIT_FAILURE). The error newly occurs when
all inputs are skipped or, most importantly, when only one input
was provided and it was skipped.
The skipping (in main.c) is now consistently reported as skipping.
The warning messages also contain more details and the new error
messages point to them.
The M_do_copy function (do_copy.c) now starts with 'Copying' because
it is at the begining of the process instead of 'Copy' which is misleading
(is the user supposed to copy).
The user manual has now a new intro and newly describes the behavior on
error discussing the much simpler single input case separately.
Documentation mentions g.mapset -p and g.mapsets -p instead of mentioning
outdated `$MAPSET` and assuming that it is clear what mapset search path is.
Co-authored-by: Stefan Blumentrath <stefan.blumentrath at gmx.de>
