[GRASS-git] [OSGeo/grass] 465a7a: Fix valid location check, sync with other function...
Vaclav Petras
noreply at github.com
Thu Aug 5 06:47:55 PDT 2021
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass
Commit: 465a7a3a6e80d814392d55bbff5a35f7c6d527f8
https://github.com/OSGeo/grass/commit/465a7a3a6e80d814392d55bbff5a35f7c6d527f8
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2021-08-05 (Thu, 05 Aug 2021)
Changed paths:
M python/grass/grassdb/checks.py
A python/grass/grassdb/testsuite/test_checks.py
Log Message:
Fix valid location check, sync with other functions (#1777)
* This fixes the path join code in valid location check, i.e., fixes 94bcea4216cdabcd18dbe5dc4686e38d4d3800de (#1715 ).
* In the new 1-or-3 parameter interface, path to database was dropped when constructing the full path to the location.
* Creating mapsets from command line with -c now works again.
* Other validity and existence checks now use the same 1-or-3 parameter interface (path or db, loc, mapset).
* Tests added for modified functions and for couple of related ones.
* Import order fixed with isort not to have glob mixed GRASS imports as pointed out by Pylint.
* Two missing docstrings added to the is-current-x checks.
