[GRASS-git] [OSGeo/grass] feff8e: Apply Black to temporal modules (#1388)
Vaclav Petras
noreply at github.com
Sat Feb 20 19:43:09 PST 2021
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass
Commit: feff8e340f5fec1b52ce066360904f72501e76ce
https://github.com/OSGeo/grass/commit/feff8e340f5fec1b52ce066360904f72501e76ce
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2021-02-20 (Sat, 20 Feb 2021)
Changed paths:
M pyproject.toml
M temporal/.flake8
M temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
M temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
M temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
M temporal/t.create/t.create.py
M temporal/t.info/t.info.py
M temporal/t.list/t.list.py
M temporal/t.merge/t.merge.py
M temporal/t.rast.accdetect/t.rast.accdetect.py
M temporal/t.rast.accdetect/testsuite/test_simple.py
M temporal/t.rast.accumulate/t.rast.accumulate.py
M temporal/t.rast.accumulate/testsuite/test_accumulation.py
M temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
M temporal/t.rast.aggregate/t.rast.aggregate.py
M temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
M temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
M temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
M temporal/t.rast.algebra/t.rast.algebra.py
M temporal/t.rast.algebra/testsuite/test_raster_algebra.py
M temporal/t.rast.algebra/testsuite/test_raster_algebra_fails.py
M temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
M temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py
M temporal/t.rast.colors/t.rast.colors.py
M temporal/t.rast.contour/t.rast.contour.py
M temporal/t.rast.contour/testsuite/test_convert.py
M temporal/t.rast.export/t.rast.export.py
M temporal/t.rast.export/testsuite/test_rast_export.py
M temporal/t.rast.extract/t.rast.extract.py
M temporal/t.rast.extract/testsuite/test_t_rast_extract.py
M temporal/t.rast.gapfill/t.rast.gapfill.py
M temporal/t.rast.gapfill/testsuite/test_gapfill.py
M temporal/t.rast.import/t.rast.import.py
M temporal/t.rast.import/testsuite/test_temporal_rast_import.py
M temporal/t.rast.list/t.rast.list.py
M temporal/t.rast.mapcalc/t.rast.mapcalc.py
M temporal/t.rast.neighbors/t.rast.neighbors.py
M temporal/t.rast.neighbors/testsuite/test_neighbors.py
M temporal/t.rast.out.vtk/t.rast.out.vtk.py
M temporal/t.rast.series/t.rast.series.py
M temporal/t.rast.series/testsuite/test_series.py
M temporal/t.rast.to.rast3/t.rast.to.rast3.py
M temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
M temporal/t.rast.to.vect/t.rast.to.vect.py
M temporal/t.rast.to.vect/testsuite/test_to_vect.py
M temporal/t.rast.univar/t.rast.univar.py
M temporal/t.rast.univar/testsuite/test_t_rast_univar.py
M temporal/t.rast.what/t.rast.what.py
M temporal/t.rast.what/testsuite/test_what.py
M temporal/t.rast3d.algebra/t.rast3d.algebra.py
M temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py
M temporal/t.rast3d.extract/t.rast3d.extract.py
M temporal/t.rast3d.extract/testsuite/test_t_rast3d_extract.py
M temporal/t.rast3d.list/t.rast3d.list.py
M temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
M temporal/t.rast3d.univar/t.rast3d.univar.py
M temporal/t.rast3d.univar/testsuite/test_t_rast3d_univar.py
M temporal/t.register/t.register.py
M temporal/t.remove/t.remove.py
M temporal/t.rename/t.rename.py
M temporal/t.sample/t.sample.py
M temporal/t.select/t.select.py
M temporal/t.shift/t.shift.py
M temporal/t.shift/testsuite/test_shift.py
M temporal/t.snap/t.snap.py
M temporal/t.snap/testsuite/test_snap.py
M temporal/t.support/t.support.py
M temporal/t.support/testsuite/test_support_str3ds.py
M temporal/t.support/testsuite/test_support_strds.py
M temporal/t.support/testsuite/test_support_stvds.py
M temporal/t.topology/t.topology.py
M temporal/t.unregister/t.unregister.py
M temporal/t.unregister/testsuite/test_unregister.py
M temporal/t.vect.algebra/t.vect.algebra.py
M temporal/t.vect.algebra/testsuite/test_vector_algebra.py
M temporal/t.vect.db.select/t.vect.db.select.py
M temporal/t.vect.export/t.vect.export.py
M temporal/t.vect.extract/t.vect.extract.py
M temporal/t.vect.extract/testsuite/test_vect_extract.py
M temporal/t.vect.import/t.vect.import.py
M temporal/t.vect.list/t.vect.list.py
M temporal/t.vect.observe.strds/t.vect.observe.strds.py
M temporal/t.vect.univar/t.vect.univar.py
M temporal/t.vect.what.strds/t.vect.what.strds.py
Log Message:
This applies Black 20.8b1 to all temporal modules and their tests. Enable in CI.
Uses: black --target-version=py36
Add Flake8 settings for Black. Remove Flake8 whitespace ignores except line length. Add per-file-ignores.
