[GRASS-git] [OSGeo/grass] fd86f5: Apply Black to tests (#1387)
Vaclav Petras
noreply at github.com
Sat Feb 20 19:47:37 PST 2021
Branch: refs/heads/master
Home: https://github.com/OSGeo/grass
Commit: fd86f50e9a4c9ab37cf501290349790377846b59
https://github.com/OSGeo/grass/commit/fd86f50e9a4c9ab37cf501290349790377846b59
Author: Vaclav Petras <wenzeslaus at gmail.com>
Date: 2021-02-20 (Sat, 20 Feb 2021)
Changed paths:
M db/db.columns/testsuite/test_dbcolumns.py
M db/db.copy/testsuite/test_dbcopy.py
M db/db.describe/testsuite/test_dbdescribe.py
M general/g.list/testsuite/test_g_list.py
M general/g.remove/testsuite/test_g_remove.py
M general/g.rename/testsuite/test_overwrite.py
M lib/gis/testsuite/gis_lib_env_test.py
M lib/gis/testsuite/gis_lib_str_color.py
M lib/gis/testsuite/gis_lib_tokenize.py
M lib/gis/testsuite/test_parser_json.py
M lib/raster/testsuite/rast_parse_color_rule.py
M lib/raster3d/testsuite/raster3d_lib_test.py
M lib/vector/Vlib/testsuite/test_vlib_box.py
M pyproject.toml
M raster/r.basins.fill/testsuite/testrbf.py
M raster/r.contour/testsuite/test_r_contour.py
M raster/r.contour/testsuite/testrc.py
M raster/r.fill.stats/testsuite/test_r_fill_stats.py
M raster/r.geomorphon/testsuite/test_r_geom.py
M raster/r.grow.distance/testsuite/r_grow_distance_test.py
M raster/r.gwflow/testsuite/validation_7x7_grid.py
M raster/r.gwflow/testsuite/validation_excavation.py
M raster/r.horizon/testsuite/test_r_horizon.py
M raster/r.in.ascii/testsuite/test_r_in_ascii.py
M raster/r.in.gdal/testsuite/test_r_in_gdal.py
M raster/r.in.poly/testsuite/test_rinpoly.py
M raster/r.info/testsuite/test_r_info.py
M raster/r.mapcalc/testsuite/test_nmedian_bug_3296.py
M raster/r.mapcalc/testsuite/test_r3_mapcalc.py
M raster/r.mapcalc/testsuite/test_r_mapcalc.py
M raster/r.mapcalc/testsuite/test_row_above_below_bug.py
M raster/r.mode/testsuite/testrmode.py
M raster/r.neighbors/testsuite/test_r_neighbors.py
M raster/r.patch/testsuite/test_rpatch_artificial.py
M raster/r.profile/testsuite/test_profile_ncspm.py
M raster/r.random.cells/testsuite/test_random_cells.py
M raster/r.random/testsuite/test_r_random.py
M raster/r.random/testsuite/testrandom.py
M raster/r.reclass/testsuite/test_r_reclass.py
M raster/r.recode/testsuite/test_rrecode_ncspm.py
M raster/r.report/testsuite/test_r_report.py
M raster/r.series.interp/testsuite/interp_test.py
M raster/r.slope.aspect/testsuite/test_r_slope_aspect.py
M raster/r.solute.transport/example.py
M raster/r.solute.transport/seguin_verify.py
M raster/r.solute.transport/seguin_verify_well.py
M raster/r.sun/testsuite/test_rsun.py
M raster/r.terraflow/testsuite/test_r_terraflow.py
M raster/r.texture/testsuite/test_texture.py
M raster/r.tile/testsuite/test_r_tile.py
M raster/r.tile/testsuite/testrt.py
M raster/r.to.vect/testsuite/test_r_to_vect.py
M raster/r.univar/testsuite/test_r_univar.py
M raster/r.viewshed/testsuite/test_r_viewshed.py
M raster/r.watershed/testsuite/r_watershed_test.py
M raster/r.what/testsuite/test_r_what.py
M raster/r.what/testsuite/testrw.py
M raster3d/r3.flow/testsuite/r3flow_test.py
M raster3d/r3.gradient/testsuite/r3gradient_test.py
M raster3d/r3.to.rast/testsuite/test_a_b_coeff.py
M raster3d/r3.to.rast/testsuite/test_integer_rounding.py
M raster3d/r3.to.rast/testsuite/test_nulls.py
M raster3d/r3.to.rast/testsuite/test_small_data.py
M vector/v.db.select/testsuite/test_v_db_select.py
M vector/v.distance/testsuite/test_areas_points.py
M vector/v.extract/testsuite/test_v_extract.py
M vector/v.in.ascii/testsuite/test_csv.py
M vector/v.in.lidar/testsuite/decimation_test.py
M vector/v.in.lidar/testsuite/mask_test.py
M vector/v.in.lidar/testsuite/test_v_in_lidar_basic.py
M vector/v.in.lidar/testsuite/test_v_in_lidar_filter.py
M vector/v.in.pdal/testsuite/test_v_in_pdal_basic.py
M vector/v.in.pdal/testsuite/test_v_in_pdal_filter.py
M vector/v.info/testsuite/test_vinfo.py
M vector/v.net/testsuite/test_v_net.py
M vector/v.out.lidar/testsuite/test_v_out_lidar.py
M vector/v.profile/testsuite/test_v_profile.py
M vector/v.select/testsuite/test_v_select.py
M vector/v.surf.rst/testsuite/test_vsurfrst.py
M vector/v.to.3d/testsuite/test_vto3d.py
M vector/v.univar/testsuite/v_univar_test.py
M vector/v.vect.stats/testsuite/test_vect_stats.py
M vector/v.what/testsuite/test_vwhat_layers.py
M vector/v.what/testsuite/test_vwhat_ncspm.py
Log Message:
This applies Black 20.8b1 to all Python test. Enable checks in CI.
