[GRASS-git] [OSGeo/grass] a7a050: apply .clang-format (#2709)
Nicklas Larsson
noreply at github.com
Thu Dec 22 01:45:35 PST 2022
Branch: refs/heads/main
Home: https://github.com/OSGeo/grass
Commit: a7a050ce379806297f2d0969ebdcf720a82f651c
https://github.com/OSGeo/grass/commit/a7a050ce379806297f2d0969ebdcf720a82f651c
Author: Nicklas Larsson <n_larsson at yahoo.com>
Date: 2022-12-22 (Thu, 22 Dec 2022)
Changed paths:
M db/db.columns/main.c
M db/db.connect/main.c
M db/db.copy/main.c
M db/db.createdb/main.c
M db/db.databases/main.c
M db/db.describe/main.c
M db/db.describe/printtab.c
M db/db.drivers/main.c
M db/db.dropdb/main.c
M db/db.execute/main.c
M db/db.login/main.c
M db/db.select/main.c
M db/db.select/printtab.c
M db/db.tables/main.c
M db/drivers/dbf/column.c
M db/drivers/dbf/create_table.c
M db/drivers/dbf/cursor.c
M db/drivers/dbf/db.c
M db/drivers/dbf/dbdriver.h
M db/drivers/dbf/dbfexe.c
M db/drivers/dbf/describe.c
M db/drivers/dbf/driver.c
M db/drivers/dbf/execute.c
M db/drivers/dbf/fetch.c
M db/drivers/dbf/globals.h
M db/drivers/dbf/listtab.c
M db/drivers/dbf/main.c
M db/drivers/dbf/main_debug.c
M db/drivers/dbf/select.c
M db/drivers/dbf/str.c
M db/drivers/dbf/table.c
M db/drivers/mysql/create_table.c
M db/drivers/mysql/cursor.c
M db/drivers/mysql/db.c
M db/drivers/mysql/dbdriver.h
M db/drivers/mysql/dbe.c
M db/drivers/mysql/describe.c
M db/drivers/mysql/driver.c
M db/drivers/mysql/error.c
M db/drivers/mysql/execute.c
M db/drivers/mysql/fetch.c
M db/drivers/mysql/globals.h
M db/drivers/mysql/index.c
M db/drivers/mysql/listtab.c
M db/drivers/mysql/main.c
M db/drivers/mysql/parse.c
M db/drivers/mysql/replace.c
M db/drivers/mysql/select.c
M db/drivers/odbc/connect.c
M db/drivers/odbc/create_table.c
M db/drivers/odbc/cursor.c
M db/drivers/odbc/db.c
M db/drivers/odbc/dbdriver.h
M db/drivers/odbc/describe.c
M db/drivers/odbc/error.c
M db/drivers/odbc/execute.c
M db/drivers/odbc/fetch.c
M db/drivers/odbc/globals.h
M db/drivers/odbc/listdb.c
M db/drivers/odbc/listtab.c
M db/drivers/odbc/main.c
M db/drivers/odbc/odbc.h
M db/drivers/odbc/proto.h
M db/drivers/odbc/select.c
M db/drivers/odbc/table.c
M db/drivers/ogr/cursor.c
M db/drivers/ogr/db.c
M db/drivers/ogr/dbdriver.h
M db/drivers/ogr/describe.c
M db/drivers/ogr/execute.c
M db/drivers/ogr/fetch.c
M db/drivers/ogr/globals.h
M db/drivers/ogr/listtab.c
M db/drivers/ogr/main.c
M db/drivers/ogr/proto.h
M db/drivers/ogr/select.c
M db/drivers/postgres/create_table.c
M db/drivers/postgres/cursor.c
M db/drivers/postgres/db.c
M db/drivers/postgres/dbdriver.h
M db/drivers/postgres/describe.c
M db/drivers/postgres/error.c
M db/drivers/postgres/execute.c
M db/drivers/postgres/fetch.c
M db/drivers/postgres/globals.h
M db/drivers/postgres/index.c
M db/drivers/postgres/listdb.c
M db/drivers/postgres/listtab.c
M db/drivers/postgres/main.c
M db/drivers/postgres/parse.c
M db/drivers/postgres/priv.c
M db/drivers/postgres/select.c
M db/drivers/postgres/table.c
M db/drivers/sqlite/create_table.c
M db/drivers/sqlite/cursor.c
M db/drivers/sqlite/db.c
M db/drivers/sqlite/dbdriver.h
M db/drivers/sqlite/describe.c
M db/drivers/sqlite/driver.c
M db/drivers/sqlite/error.c
M db/drivers/sqlite/execute.c
M db/drivers/sqlite/fetch.c
M db/drivers/sqlite/globals.h
M db/drivers/sqlite/index.c
M db/drivers/sqlite/listdb.c
M db/drivers/sqlite/listtab.c
M db/drivers/sqlite/main.c
M db/drivers/sqlite/select.c
M db/drivers/sqlite/table.c
M misc/m.cogo/main.c
M misc/m.measure/main.c
M misc/m.nviz.image/args.c
M misc/m.nviz.image/cplane.c
M misc/m.nviz.image/local_proto.h
M misc/m.nviz.image/main.c
M misc/m.nviz.image/surface.c
M misc/m.nviz.image/vector.c
M misc/m.nviz.image/volume.c
M misc/m.nviz.script/main.c
M misc/m.transform/main.c
M temporal/t.connect/main.c
M utils/timer/main.c
M vector/v.buffer/geos.c
M vector/v.buffer/local_proto.h
M vector/v.buffer/main.c
M vector/v.build.polylines/main.c
M vector/v.build.polylines/walk.c
M vector/v.build.polylines/walk.h
M vector/v.build/main.c
M vector/v.category/main.c
M vector/v.class/main.c
M vector/v.clean/main.c
M vector/v.clean/proto.h
M vector/v.clean/prune.c
M vector/v.clean/rmdac.c
M vector/v.clean/rmline.c
M vector/v.clean/split.c
M vector/v.clean/test/topocheck.c
M vector/v.cluster/main.c
M vector/v.colors.out/main.c
M vector/v.colors.out/make_colors.c
M vector/v.colors.out/scan_cats.c
M vector/v.colors/local_proto.h
M vector/v.colors/main.c
M vector/v.colors/make_colors.c
M vector/v.colors/read_rgb.c
M vector/v.colors/scan_attr.c
M vector/v.colors/scan_cats.c
M vector/v.colors/scan_z.c
M vector/v.colors/write_rgb.c
M vector/v.db.connect/main.c
M vector/v.db.select/main.c
M vector/v.decimate/copy_tab.c
M vector/v.decimate/count_decimation.c
M vector/v.decimate/count_decimation.h
M vector/v.decimate/grid_decimation.c
M vector/v.decimate/grid_decimation.h
M vector/v.decimate/main.c
M vector/v.delaunay/data_types.h
M vector/v.delaunay/edge.c
M vector/v.delaunay/edge.h
M vector/v.delaunay/geom_primitives.h
M vector/v.delaunay/geometry.c
M vector/v.delaunay/geometry.h
M vector/v.delaunay/in_out.c
M vector/v.delaunay/main.c
M vector/v.delaunay/memory.c
M vector/v.distance/cmp.c
M vector/v.distance/distance.c
M vector/v.distance/local_proto.h
M vector/v.distance/main.c
M vector/v.distance/print.c
M vector/v.drape/local_proto.h
M vector/v.drape/main.c
M vector/v.drape/sample.c
M vector/v.edit/args.c
M vector/v.edit/close.c
M vector/v.edit/global.h
M vector/v.edit/main.c
M vector/v.edit/max_distance.c
M vector/v.edit/proto.h
M vector/v.edit/select.c
M vector/v.edit/snap.c
M vector/v.external.out/args.c
M vector/v.external.out/format.c
M vector/v.external.out/link.c
M vector/v.external.out/list.c
M vector/v.external.out/local_proto.h
M vector/v.external.out/main.c
M vector/v.external.out/status.c
M vector/v.external/args.c
M vector/v.external/list.c
M vector/v.external/local_proto.h
M vector/v.external/main.c
M vector/v.external/proj.c
M vector/v.extract/copy_tab.c
M vector/v.extract/extract.c
M vector/v.extract/local_proto.h
M vector/v.extract/main.c
M vector/v.extrude/db.c
M vector/v.extrude/extrude.c
M vector/v.extrude/local_proto.h
M vector/v.extrude/main.c
M vector/v.generalize/displacement.c
M vector/v.generalize/main.c
M vector/v.generalize/matrix.c
M vector/v.generalize/matrix.h
M vector/v.generalize/misc.c
M vector/v.generalize/misc.h
M vector/v.generalize/network.c
M vector/v.generalize/operators.h
M vector/v.generalize/point.c
M vector/v.generalize/point.h
M vector/v.generalize/pq.c
M vector/v.generalize/pq.h
M vector/v.generalize/simplification.c
M vector/v.generalize/smoothing.c
M vector/v.hull/chull.c
M vector/v.hull/globals.h
M vector/v.hull/hull.c
M vector/v.hull/hull.h
M vector/v.hull/macros.h
M vector/v.hull/main.c
M vector/v.hull/read.c
M vector/v.hull/write.c
M vector/v.in.ascii/local_proto.h
M vector/v.in.ascii/main.c
M vector/v.in.ascii/points.c
M vector/v.in.db/main.c
M vector/v.in.dwg/entity.c
M vector/v.in.dwg/global.h
M vector/v.in.dwg/main.c
M vector/v.in.dxf/add_3dface.c
M vector/v.in.dxf/add_arc.c
M vector/v.in.dxf/add_circle.c
M vector/v.in.dxf/add_line.c
M vector/v.in.dxf/add_lwpolyline.c
M vector/v.in.dxf/add_point.c
M vector/v.in.dxf/add_polyline.c
M vector/v.in.dxf/add_text.c
M vector/v.in.dxf/dxf_to_vect.c
M vector/v.in.dxf/global.h
M vector/v.in.dxf/main.c
M vector/v.in.dxf/make_arc.c
M vector/v.in.dxf/read_dxf.c
M vector/v.in.dxf/write_vect.c
M vector/v.in.lidar/attributes.c
M vector/v.in.lidar/attributes.h
M vector/v.in.lidar/count_decimation.c
M vector/v.in.lidar/count_decimation.h
M vector/v.in.lidar/filters.c
M vector/v.in.lidar/filters.h
M vector/v.in.lidar/info.c
M vector/v.in.lidar/info.h
M vector/v.in.lidar/lidar.c
M vector/v.in.lidar/lidar.h
M vector/v.in.lidar/main.c
M vector/v.in.lidar/projection.c
M vector/v.in.lidar/projection.h
M vector/v.in.lidar/vector_mask.c
M vector/v.in.lidar/vector_mask.h
M vector/v.in.ogr/clean.c
M vector/v.in.ogr/dsn.c
M vector/v.in.ogr/geom.c
M vector/v.in.ogr/global.h
M vector/v.in.ogr/main.c
M vector/v.in.ogr/pavl.c
M vector/v.in.ogr/pavl.h
M vector/v.in.ogr/proj.c
M vector/v.in.pdal/filters.c
M vector/v.in.pdal/filters.h
M vector/v.in.pdal/lidar.c
M vector/v.in.pdal/lidar.h
M vector/v.in.pdal/main.cpp
M vector/v.in.pdal/projection.c
M vector/v.in.pdal/projection.h
M vector/v.in.region/main.c
M vector/v.info/level1.c
M vector/v.info/main.c
M vector/v.info/parse.c
M vector/v.info/print.c
M vector/v.kcv/main.c
M vector/v.kernel/function.c
M vector/v.kernel/global.h
M vector/v.kernel/main.c
M vector/v.label.sa/annealing.c
M vector/v.label.sa/font.c
M vector/v.label.sa/labels.c
M vector/v.label.sa/labels.h
M vector/v.label.sa/main.c
M vector/v.label/main.c
M vector/v.lidar.correction/correction.c
M vector/v.lidar.correction/correction.h
M vector/v.lidar.correction/main.c
M vector/v.lidar.edgedetection/edgedetection.c
M vector/v.lidar.edgedetection/edgedetection.h
M vector/v.lidar.edgedetection/main.c
M vector/v.lidar.growing/ConvexHull.c
M vector/v.lidar.growing/growing.c
M vector/v.lidar.growing/growing.h
M vector/v.lidar.growing/main.c
M vector/v.lrs/lib/lrs.c
M vector/v.lrs/lib/lrs.h
M vector/v.lrs/v.lrs.create/main.c
M vector/v.lrs/v.lrs.label/main.c
M vector/v.lrs/v.lrs.segment/main.c
M vector/v.lrs/v.lrs.where/main.c
M vector/v.mkgrid/grid_structs.h
M vector/v.mkgrid/hexgrid.c
M vector/v.mkgrid/local_proto.h
M vector/v.mkgrid/main.c
M vector/v.mkgrid/rotate.c
M vector/v.mkgrid/write_grid.c
M vector/v.neighbors/main.c
M vector/v.net.alloc/alloc.c
M vector/v.net.alloc/alloc.h
M vector/v.net.alloc/main.c
M vector/v.net.allpairs/main.c
M vector/v.net.bridge/main.c
M vector/v.net.centrality/main.c
M vector/v.net.components/main.c
M vector/v.net.connectivity/main.c
M vector/v.net.distance/main.c
M vector/v.net.flow/main.c
M vector/v.net.iso/alloc.c
M vector/v.net.iso/alloc.h
M vector/v.net.iso/main.c
M vector/v.net.path/main.c
M vector/v.net.path/path.c
M vector/v.net.salesman/main.c
M vector/v.net.spanningtree/main.c
M vector/v.net.steiner/main.c
M vector/v.net.timetable/main.c
M vector/v.net.visibility/data_structures.c
M vector/v.net.visibility/data_structures.h
M vector/v.net.visibility/geometry.c
M vector/v.net.visibility/geometry.h
M vector/v.net.visibility/main.c
M vector/v.net.visibility/proto.h
M vector/v.net.visibility/rotation_tree.c
M vector/v.net.visibility/rotation_tree.h
M vector/v.net.visibility/visibility.c
M vector/v.net.visibility/visibility.h
M vector/v.net/arcs.c
M vector/v.net/args.c
M vector/v.net/connect.c
M vector/v.net/main.c
M vector/v.net/nodes.c
M vector/v.net/proto.h
M vector/v.net/report.c
M vector/v.net/turntable.c
M vector/v.normal/main.c
M vector/v.normal/scancats.c
M vector/v.out.ascii/args.c
M vector/v.out.ascii/local_proto.h
M vector/v.out.ascii/main.c
M vector/v.out.dxf/main.c
M vector/v.out.dxf/write_dxf.c
M vector/v.out.lidar/main.c
M vector/v.out.ogr/args.c
M vector/v.out.ogr/attrb.c
M vector/v.out.ogr/create.c
M vector/v.out.ogr/export_areas.c
M vector/v.out.ogr/export_lines.c
M vector/v.out.ogr/list.c
M vector/v.out.ogr/local_proto.h
M vector/v.out.ogr/main.c
M vector/v.out.postgis/args.c
M vector/v.out.postgis/create.c
M vector/v.out.postgis/local_proto.h
M vector/v.out.postgis/main.c
M vector/v.out.postgis/table.c
M vector/v.out.pov/main.c
M vector/v.out.svg/main.c
M vector/v.out.vtk/head.c
M vector/v.out.vtk/local_proto.h
M vector/v.out.vtk/main.c
M vector/v.out.vtk/writeVTK.c
M vector/v.out.vtk/writeVTK.h
M vector/v.outlier/main.c
M vector/v.outlier/outlier.c
M vector/v.outlier/outlier.h
M vector/v.overlay/area_area.c
M vector/v.overlay/line_area.c
M vector/v.overlay/local.h
M vector/v.overlay/main.c
M vector/v.overlay/util.c
M vector/v.parallel/main.c
M vector/v.patch/main.c
M vector/v.perturb/fische.c
M vector/v.perturb/main.c
M vector/v.perturb/myrng.c
M vector/v.perturb/normal00.c
M vector/v.perturb/normalen.c
M vector/v.perturb/normalrs.c
M vector/v.perturb/normalsv.c
M vector/v.perturb/zufall.c
M vector/v.perturb/zufall.h
M vector/v.perturb/zufalli.c
M vector/v.perturb/zufallrs.c
M vector/v.perturb/zufallsv.c
M vector/v.profile/local_proto.h
M vector/v.profile/main.c
M vector/v.profile/processors.c
M vector/v.proj/main.c
M vector/v.proj/setenv.c
M vector/v.qcount/count.c
M vector/v.qcount/findquads.c
M vector/v.qcount/indices.c
M vector/v.qcount/main.c
M vector/v.qcount/quaddefs.h
M vector/v.random/main.c
M vector/v.reclass/main.c
M vector/v.reclass/reclass.c
M vector/v.reclass/rules.c
M vector/v.rectify/cp.c
M vector/v.rectify/crs.h
M vector/v.rectify/crs3d.c
M vector/v.rectify/env.c
M vector/v.rectify/global.h
M vector/v.rectify/main.c
M vector/v.rectify/orthorot.c
M vector/v.rectify/target.c
M vector/v.sample/main.c
M vector/v.segment/main.c
M vector/v.select/args.c
M vector/v.select/copy_tabs.c
M vector/v.select/geos.c
M vector/v.select/main.c
M vector/v.select/overlap.c
M vector/v.select/proto.h
M vector/v.select/select.c
M vector/v.select/write.c
M vector/v.split/main.c
M vector/v.support/main.c
M vector/v.surf.bspline/bspline.h
M vector/v.surf.bspline/crosscorr.c
M vector/v.surf.bspline/main.c
M vector/v.surf.bspline/resamp.c
M vector/v.surf.idw/main.c
M vector/v.surf.idw/read_sites.c
M vector/v.surf.rst/main.c
M vector/v.surf.rst/surf.h
M vector/v.timestamp/main.c
M vector/v.to.3d/local_proto.h
M vector/v.to.3d/main.c
M vector/v.to.3d/trans2.c
M vector/v.to.3d/trans3.c
M vector/v.to.db/areas.c
M vector/v.to.db/find.c
M vector/v.to.db/global.h
M vector/v.to.db/lines.c
M vector/v.to.db/main.c
M vector/v.to.db/parse.c
M vector/v.to.db/query.c
M vector/v.to.db/report.c
M vector/v.to.db/units.c
M vector/v.to.db/update.c
M vector/v.to.points/local_proto.h
M vector/v.to.points/main.c
M vector/v.to.points/write.c
M vector/v.to.rast/dense_line.c
M vector/v.to.rast/do_areas.c
M vector/v.to.rast/do_lines.c
M vector/v.to.rast/local.h
M vector/v.to.rast/main.c
M vector/v.to.rast/raster.c
M vector/v.to.rast/support.c
M vector/v.to.rast/vect2rast.c
M vector/v.to.rast3/main.c
M vector/v.transform/local_proto.h
M vector/v.transform/main.c
M vector/v.transform/trans.h
M vector/v.transform/trans_digit.c
M vector/v.type/main.c
M vector/v.univar/main.c
M vector/v.vect.stats/main.c
M vector/v.vol.rst/dataoct.c
M vector/v.vol.rst/dataoct.h
M vector/v.vol.rst/main.c
M vector/v.vol.rst/oct.c
M vector/v.vol.rst/oct.h
M vector/v.vol.rst/points.h
M vector/v.vol.rst/surf.h
M vector/v.vol.rst/user1.c
M vector/v.vol.rst/user2.c
M vector/v.vol.rst/user3.c
M vector/v.vol.rst/user4.c
M vector/v.vol.rst/userextern.h
M vector/v.vol.rst/userglobs.h
M vector/v.vol.rst/vector.c
M vector/v.voronoi/clean_topo.c
M vector/v.voronoi/defs.h
M vector/v.voronoi/main.c
M vector/v.voronoi/skeleton.c
M vector/v.voronoi/sw_defs.h
M vector/v.voronoi/sw_edgelist.c
M vector/v.voronoi/sw_geometry.c
M vector/v.voronoi/sw_heap.c
M vector/v.voronoi/sw_main.c
M vector/v.voronoi/sw_voronoi.c
M vector/v.voronoi/vo_extend.c
M vector/v.voronoi/vo_write.c
M vector/v.what.rast/local_proto.h
M vector/v.what.rast/main.c
M vector/v.what.rast3/local_proto.h
M vector/v.what.rast3/main.c
M vector/v.what/main.c
M vector/v.what/what.c
M vector/v.what/what.h
M visualization/ximgview/color.c
M visualization/ximgview/main.c
Log Message:
