[GRASS-git] [OSGeo/grass] 8de925: apply .clang-format (#2710)
Nicklas Larsson noreply at github.com
Thu Dec 22 01:46:21 PST 2022
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 8de925f87be22a5c943f2969a2872a288d72f2f7
      https://github.com/OSGeo/grass/commit/8de925f87be22a5c943f2969a2872a288d72f2f7
  Author: Nicklas Larsson <n_larsson at yahoo.com>
  Date:   2022-12-22 (Thu, 22 Dec 2022)
  Changed paths:
    M display/d.barscale/draw_scale.c
    M display/d.barscale/main.c
    M display/d.barscale/options.h
    M display/d.colorlist/main.c
    M display/d.colortable/main.c
    M display/d.erase/main.c
    M display/d.extract/extract.c
    M display/d.extract/main.c
    M display/d.font/main.c
    M display/d.fontlist/main.c
    M display/d.geodesic/main.c
    M display/d.geodesic/plot.c
    M display/d.graph/do_graph.c
    M display/d.graph/graphics.c
    M display/d.graph/main.c
    M display/d.graph/options.h
    M display/d.grid/fiducial.c
    M display/d.grid/main.c
    M display/d.grid/plot.c
    M display/d.grid/plotborder.c
    M display/d.his/his.c
    M display/d.his/main.c
    M display/d.histogram/bar.c
    M display/d.histogram/bar.h
    M display/d.histogram/dhist.h
    M display/d.histogram/draw_slice.c
    M display/d.histogram/get_stats.c
    M display/d.histogram/main.c
    M display/d.histogram/options.h
    M display/d.histogram/pie.c
    M display/d.histogram/pie.h
    M display/d.info/main.c
    M display/d.labels/color.c
    M display/d.labels/do_labels.c
    M display/d.labels/main.c
    M display/d.legend.vect/draw.c
    M display/d.legend.vect/local_proto.h
    M display/d.legend.vect/main.c
    M display/d.legend/draw.c
    M display/d.legend/get_stats.c
    M display/d.legend/histogram.c
    M display/d.legend/local_proto.h
    M display/d.legend/main.c
    M display/d.linegraph/linegraph.h
    M display/d.linegraph/main.c
    M display/d.mon/list.c
    M display/d.mon/main.c
    M display/d.mon/proto.h
    M display/d.mon/start.c
    M display/d.mon/stop.c
    M display/d.northarrow/draw_n_arrow.c
    M display/d.northarrow/main.c
    M display/d.northarrow/options.h
    M display/d.path/main.c
    M display/d.path/proto.h
    M display/d.path/select.c
    M display/d.profile/main.c
    M display/d.rast.arrow/main.c
    M display/d.rast.num/main.c
    M display/d.rast/display.c
    M display/d.rast/main.c
    M display/d.rast/mask.c
    M display/d.rast/mask.h
    M display/d.rgb/main.c
    M display/d.rhumbline/main.c
    M display/d.rhumbline/plot.c
    M display/d.text/main.c
    M display/d.title/fancy.c
    M display/d.title/main.c
    M display/d.title/normal.c
    M display/d.title/options.h
    M display/d.vect.chart/bar.c
    M display/d.vect.chart/global.h
    M display/d.vect.chart/main.c
    M display/d.vect.chart/pie.c
    M display/d.vect.chart/plot.c
    M display/d.vect.thematic/area.c
    M display/d.vect.thematic/display.c
    M display/d.vect.thematic/legend.c
    M display/d.vect.thematic/local_proto.h
    M display/d.vect.thematic/main.c
    M display/d.vect.thematic/plot.h
    M display/d.vect.thematic/plot1.c
    M display/d.vect/area.c
    M display/d.vect/attr.c
    M display/d.vect/dir.c
    M display/d.vect/label.c
    M display/d.vect/legend.c
    M display/d.vect/lines.c
    M display/d.vect/local_proto.h
    M display/d.vect/main.c
    M display/d.vect/opt.c
    M display/d.vect/plot.h
    M display/d.vect/shape.c
    M display/d.vect/topo.c
    M display/d.vect/vert.c
    M display/d.vect/zcoor.c
    M display/d.where/main.c
    M display/d.where/where.c
    M general/g.access/exp_perms.c
    M general/g.access/main.c
    M general/g.cairocomp/main.c
    M general/g.copy/main.c
    M general/g.dirseps/main.c
    M general/g.filename/main.c
    M general/g.findetc/main.c
    M general/g.findfile/main.c
    M general/g.gisenv/main.c
    M general/g.gui/main.c
    M general/g.list/global.h
    M general/g.list/list.c
    M general/g.list/main.c
    M general/g.mapset/main.c
    M general/g.mapsets/get_maps.c
    M general/g.mapsets/main.c
    M general/g.message/main.c
    M general/g.mkfontcap/freetype_fonts.c
    M general/g.mkfontcap/main.c
    M general/g.mkfontcap/stroke_fonts.c
    M general/g.parser/global.h
    M general/g.parser/main.c
    M general/g.parser/parse.c
    M general/g.parser/revoke.c
    M general/g.parser/rules.c
    M general/g.parser/standard_option.c
    M general/g.parser/translate.c
    M general/g.pnmcomp/main.c
    M general/g.ppmtopng/main.c
    M general/g.proj/create.c
    M general/g.proj/datumtrans.c
    M general/g.proj/input.c
    M general/g.proj/list_codes.c
    M general/g.proj/main.c
    M general/g.proj/output.c
    M general/g.region/main.c
    M general/g.region/printwindow.c
    M general/g.remove/check_reclass.c
    M general/g.remove/construct_pattern.c
    M general/g.remove/main.c
    M general/g.rename/main.c
    M general/g.setproj/get_datum.c
    M general/g.setproj/get_deg.c
    M general/g.setproj/get_num.c
    M general/g.setproj/get_stp.c
    M general/g.setproj/local_proto.h
    M general/g.setproj/main.c
    M general/g.setproj/proj.c
    M general/g.tempfile/main.c
    M general/g.version/local_proto.h
    M general/g.version/main.c
    M ps/ps.map/border.h
    M ps/ps.map/catval.c
    M ps/ps.map/chk_scale.c
    M ps/ps.map/clr.h
    M ps/ps.map/colortable.h
    M ps/ps.map/comment.c
    M ps/ps.map/comment.h
    M ps/ps.map/decorate.h
    M ps/ps.map/distance.c
    M ps/ps.map/distance.h
    M ps/ps.map/do_geogrid.c
    M ps/ps.map/do_grid.c
    M ps/ps.map/do_header.c
    M ps/ps.map/do_labels.c
    M ps/ps.map/do_masking.c
    M ps/ps.map/do_plt.c
    M ps/ps.map/do_psfiles.c
    M ps/ps.map/do_scalebar.c
    M ps/ps.map/do_vectors.c
    M ps/ps.map/eps.c
    M ps/ps.map/error.c
    M ps/ps.map/fit_map.c
    M ps/ps.map/get_font.c
    M ps/ps.map/get_scalebar.c
    M ps/ps.map/getgrid.c
    M ps/ps.map/gprims.c
    M ps/ps.map/group.h
    M ps/ps.map/header.h
    M ps/ps.map/input.c
    M ps/ps.map/key_data.c
    M ps/ps.map/labels.h
    M ps/ps.map/local_proto.h
    M ps/ps.map/main.c
    M ps/ps.map/makeprocs.c
    M ps/ps.map/map_info.c
    M ps/ps.map/map_info.h
    M ps/ps.map/map_setup.c
    M ps/ps.map/mtextbox.c
    M ps/ps.map/outl_io.c
    M ps/ps.map/paper.h
    M ps/ps.map/parse_list.c
    M ps/ps.map/ps_clrtbl.c
    M ps/ps.map/ps_colors.c
    M ps/ps.map/ps_fclrtbl.c
    M ps/ps.map/ps_header.c
    M ps/ps.map/ps_info.h
    M ps/ps.map/ps_map.c
    M ps/ps.map/ps_outline.c
    M ps/ps.map/ps_raster.c
    M ps/ps.map/ps_vareas.c
    M ps/ps.map/ps_vlegend.c
    M ps/ps.map/ps_vlines.c
    M ps/ps.map/ps_vpoints.c
    M ps/ps.map/r_border.c
    M ps/ps.map/r_cell.c
    M ps/ps.map/r_colortable.c
    M ps/ps.map/r_group.c
    M ps/ps.map/r_header.c
    M ps/ps.map/r_info.c
    M ps/ps.map/r_instructions.c
    M ps/ps.map/r_labels.c
    M ps/ps.map/r_paper.c
    M ps/ps.map/r_plt.c
    M ps/ps.map/r_rgb.c
    M ps/ps.map/r_text.c
    M ps/ps.map/r_vareas.c
    M ps/ps.map/r_vlegend.c
    M ps/ps.map/r_vlines.c
    M ps/ps.map/r_vpoints.c
    M ps/ps.map/r_wind.c
    M ps/ps.map/read_cfg.c
    M ps/ps.map/scale.c
    M ps/ps.map/scan_gis.c
    M ps/ps.map/scan_misc.c
    M ps/ps.map/scan_ref.c
    M ps/ps.map/session.c
    M ps/ps.map/show_scale.c
    M ps/ps.map/symbol.c
    M ps/ps.map/textbox.c
    M ps/ps.map/vect.c
    M ps/ps.map/vector.c
    M ps/ps.map/vector.h
    M ps/ps.map/yesno.c
  Log Message:
