[GRASS-git] [OSGeo/grass] 4144ba: CQ: replace 'sprintf()` in raster and raster3d dir...
Nicklas Larsson noreply at github.com
Thu May 8 11:58:27 PDT 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: 4144ba81fa125e1549fc52e1cf5feb4fa004be8b
      https://github.com/OSGeo/grass/commit/4144ba81fa125e1549fc52e1cf5feb4fa004be8b
  Author: Nicklas Larsson <n_larsson at yahoo.com>
  Date:   2025-05-08 (Thu, 08 May 2025)
  Changed paths:
    M raster/r.buffer/support.c
    M raster/r.buildvrt/link.c
    M raster/r.category/main.c
    M raster/r.clump/main.c
    M raster/r.coin/format.c
    M raster/r.coin/make_coin.c
    M raster/r.coin/print_coin.c
    M raster/r.coin/print_hdr.c
    M raster/r.colors/rules.c
    M raster/r.composite/main.c
    M raster/r.contour/main.c
    M raster/r.cross/cats.c
    M raster/r.cross/main.c
    M raster/r.describe/dumplist.c
    M raster/r.distance/report.c
    M raster/r.external/link.c
    M raster/r.flow/flow_io.c
    M raster/r.flow/main.c
    M raster/r.in.bin/main.c
    M raster/r.in.gdal/main.c
    M raster/r.in.lidar/main.c
    M raster/r.in.png/main.c
    M raster/r.in.xyz/main.c
    M raster/r.info/main.c
    M raster/r.info/reclas_txt.c
    M raster/r.kappa/mask.c
    M raster/r.kappa/print_header.c
    M raster/r.kappa/stats.c
    M raster/r.li/r.li.daemon/daemon.c
    M raster/r.mapcalc/expression.c
    M raster/r.mapcalc/map.c
    M raster/r.mfilter/main.c
    M raster/r.mode/main.c
    M raster/r.neighbors/main.c
    M raster/r.out.ascii/formspecific.c
    M raster/r.out.bin/main.c
    M raster/r.out.gdal/export_band.c
    M raster/r.out.mat/main.c
    M raster/r.out.png/main.c
    M raster/r.out.ppm3/main.c
    M raster/r.out.vrml/put_grid.c
    M raster/r.out.vrml/put_view.c
    M raster/r.param.scale/close_down.c
    M raster/r.param.scale/interface.c
    M raster/r.profile/main.c
    M raster/r.quant/read_rules.c
    M raster/r.random.surface/init.c
    M raster/r.random.surface/save.c
    M raster/r.random/random.c
    M raster/r.random/support.c
    M raster/r.recode/read_rules.c
    M raster/r.relief/main.c
    M raster/r.report/format.c
    M raster/r.report/global.h
    M raster/r.report/header.c
    M raster/r.report/maskinfo.c
    M raster/r.report/prt_report.c
    M raster/r.report/prt_unit.c
    M raster/r.report/stats.c
    M raster/r.resamp.bspline/main.c
    M raster/r.resamp.filter/main.c
    M raster/r.resamp.interp/main.c
    M raster/r.resamp.stats/main.c
    M raster/r.rescale.eq/main.c
    M raster/r.rescale/main.c
    M raster/r.sim/simlib/output.c
    M raster/r.slope.aspect/main.c
    M raster/r.spread/display.c
    M raster/r.statistics/o_average.c
    M raster/r.statistics/o_sum.c
    M raster/r.statistics/run_cmd.c
    M raster/r.stats.quantile/main.c
    M raster/r.stats.zonal/main.c
    M raster/r.stats/main.c
    M raster/r.stats/raw_stats.c
    M raster/r.stats/stats.c
    M raster/r.stream.extract/close.c
    M raster/r.surf.fractal/write_rast.c
    M raster/r.surf.random/main.c
    M raster/r.texture/main.c
    M raster/r.tile/main.c
    M raster/r.to.vect/areas_io.c
    M raster/r.to.vect/main.c
    M raster/r.to.vect/util.c
    M raster/r.topmodel/topmodel.c
    M raster/r.transect/main.c
    M raster/r.transect/parse_line.c
    M raster/r.univar/stats.c
    M raster/r.volume/main.c
    M raster/r.what/main.c
    M raster3d/r3.flow/flowline.c
    M raster3d/r3.flow/main.c
    M raster3d/r3.info/main.c
    M raster3d/r3.mkdspf/main.c
    M raster3d/r3.mkdspf/r3_find.c
  Log Message:
  CQ: replace 'sprintf()` in raster and raster3d directories (#5570)
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
