[GRASS-git] [OSGeo/grass] b356c7: CQ: replace 'sprintf()` in vector directory (#5569)
    Nicklas Larsson
    noreply at github.com
    Fri May  9 05:34:02 PDT 2025
  Branch: refs/heads/main
  Home:   https://github.com/OSGeo/grass
  Commit: b356c7e108fcbeca77474c8e83ebec8f1e7b3e4a
      https://github.com/OSGeo/grass/commit/b356c7e108fcbeca77474c8e83ebec8f1e7b3e4a
  Author: Nicklas Larsson <n_larsson at yahoo.com>
  Date:   2025-05-09 (Fri, 09 May 2025)
  Changed paths:
    M vector/v.colors/write_rgb.c
    M vector/v.db.select/main.c
    M vector/v.distance/main.c
    M vector/v.external.out/list.c
    M vector/v.external.out/status.c
    M vector/v.external/dsn.c
    M vector/v.external/list.c
    M vector/v.external/main.c
    M vector/v.extrude/db.c
    M vector/v.in.ascii/main.c
    M vector/v.in.ascii/points.c
    M vector/v.in.db/main.c
    M vector/v.in.dxf/write_vect.c
    M vector/v.in.lidar/attributes.c
    M vector/v.in.lidar/main.c
    M vector/v.in.ogr/dsn.c
    M vector/v.in.ogr/main.c
    M vector/v.info/local_proto.h
    M vector/v.info/print.c
    M vector/v.kcv/main.c
    M vector/v.label.sa/font.c
    M vector/v.label.sa/labels.c
    M vector/v.label/main.c
    M vector/v.lidar.correction/correction.c
    M vector/v.lidar.correction/main.c
    M vector/v.lidar.edgedetection/edgedetection.c
    M vector/v.lidar.edgedetection/main.c
    M vector/v.lidar.growing/main.c
    M vector/v.lrs/lib/lrs.c
    M vector/v.lrs/v.lrs.create/main.c
    M vector/v.lrs/v.lrs.label/main.c
    M vector/v.mkgrid/main.c
    M vector/v.net.alloc/main.c
    M vector/v.net.allpairs/main.c
    M vector/v.net.centrality/main.c
    M vector/v.net.components/main.c
    M vector/v.net.distance/main.c
    M vector/v.net.flow/main.c
    M vector/v.net.iso/main.c
    M vector/v.net.path/path.c
    M vector/v.net.timetable/main.c
    M vector/v.net/main.c
    M vector/v.net/turntable.c
    M vector/v.out.dxf/main.c
    M vector/v.out.lidar/main.c
    M vector/v.out.ogr/attrb.c
    M vector/v.out.ogr/dsn.c
    M vector/v.out.ogr/export_areas_fast.c
    M vector/v.out.ogr/export_lines_fast.c
    M vector/v.out.ogr/list.c
    M vector/v.out.ogr/main.c
    M vector/v.out.postgis/create.c
    M vector/v.out.postgis/main.c
    M vector/v.out.svg/main.c
    M vector/v.out.vtk/writeVTK.c
    M vector/v.outlier/main.c
    M vector/v.outlier/outlier.c
    M vector/v.overlay/area_area.c
    M vector/v.overlay/line_area.c
    M vector/v.overlay/main.c
    M vector/v.patch/main.c
    M vector/v.profile/main.c
    M vector/v.proj/main.c
    M vector/v.reclass/main.c
    M vector/v.rectify/target.c
    M vector/v.sample/main.c
    M vector/v.support/main.c
    M vector/v.surf.bspline/main.c
    M vector/v.surf.rst/main.c
    M vector/v.to.3d/trans3.c
    M vector/v.to.db/main.c
    M vector/v.to.db/query.c
    M vector/v.to.db/report.c
    M vector/v.to.db/update.c
    M vector/v.to.points/main.c
    M vector/v.to.points/write.c
    M vector/v.to.rast/support.c
    M vector/v.transform/main.c
    M vector/v.vect.stats/main.c
    M vector/v.vol.rst/main.c
    M vector/v.vol.rst/vector.c
    M vector/v.what.rast/main.c
    M vector/v.what/what.c
  Log Message:
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass/settings/notifications
