[GRASS-git] [OSGeo/grass-addons] d21bb7: r.stream: Fix segment calculation forcing swap mod...
Bhuvan Somisetty
noreply at github.com
Tue Sep 15 13:38:50 PDT 2026
Branch: refs/heads/grass8
Home: https://github.com/OSGeo/grass-addons
Commit: d21bb79684b048bdaf43397eba47a2f61957e05d
https://github.com/OSGeo/grass-addons/commit/d21bb79684b048bdaf43397eba47a2f61957e05d
Author: Bhuvan Somisetty <somisettybhuvan5 at gmail.com>
Date: 2026-09-15 (Tue, 15 Sep 2026)
Changed paths:
M src/raster/r.stream.basins/main.c
M src/raster/r.stream.channel/main.c
M src/raster/r.stream.distance/main.c
M src/raster/r.stream.order/main.c
M src/raster/r.stream.segment/main.c
M src/raster/r.stream.stats/main.c
Log Message:
r.stream: Fix segment calculation forcing swap mode (#1838)
In r.stream.basins, r.stream.channel, r.stream.distance, r.stream.order,
r.stream.segment, and r.stream.stats, the calculation of
number_of_segs_total incorrectly added the remainder (nrows % SROWS)
rather than 1 for partial segments.
When nrows or ncols were not exact multiples of 128 (SROWS/SCOLS), this
inflated the segment count estimate, causing modules to falsely conclude
that the raster exceeded the memory limit and forcing disk-swapping
mode even for small maps fitting entirely in RAM.
Fix the formula to use standard ceiling division across all 6 tools.
Fixes #1837
Signed-off-by: bhuvan-somisetty <somisettybhuvan5 at gmail.com>
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
