[GRASS-git] [OSGeo/grass-addons] 211669: v.photo.geometry: recovers acquisition geometry fr...
Corey White noreply at github.com
Tue Sep 15 19:51:35 PDT 2026
  Branch: refs/heads/grass8
  Home:   https://github.com/OSGeo/grass-addons
  Commit: 21166930e27f62495bba9de4239385a02d80cd6c
      https://github.com/OSGeo/grass-addons/commit/21166930e27f62495bba9de4239385a02d80cd6c
  Author: Corey White <smortopahri at gmail.com>
  Date:   2026-09-15 (Tue, 15 Sep 2026)
  Changed paths:
    A src/vector/v.photo.geometry/CMakeLists.txt
    A src/vector/v.photo.geometry/Makefile
    A src/vector/v.photo.geometry/requirements.txt
    A src/vector/v.photo.geometry/tests/conftest.py
    A src/vector/v.photo.geometry/tests/data/cap_frames.json
    A src/vector/v.photo.geometry/tests/data/seed.jpg
    A src/vector/v.photo.geometry/tests/v_photo_geometry_test.py
    A src/vector/v.photo.geometry/v.photo.geometry.html
    A src/vector/v.photo.geometry/v.photo.geometry.md
    A src/vector/v.photo.geometry/v.photo.geometry.py
    A src/vector/v.photo.geometry/v_photo_geometry.png
    A src/vector/v.photo.geometry/v_photo_geometry_density.png
  Log Message:
  v.photo.geometry: recovers acquisition geometry from a directory of aerial photos whose flight metadata is incomplete (#1832)
* Add tool renamed from v.flightplan
* Clean up old code and stale dependencies
* Read image metadata with ExifTool
* Derive sensor size from metadata
* Group images by camera body
* Split flight tracks at time gaps
* Write footprint areas and camera station maps
* Add terrain-corrected footprints
* Add estimated 3D flight path output
* Add overlap statistics output
* Add documentation
* Coerce orientation tag values to float
* Add overlap density raster output
* Add manual figures
* Handle missing metadata without crashing
* Require a projected metric CRS
* Polish parser interface and messages
* Batch elevation sampling
* Fix output writing and document dependencies
* Fix flat footprint rotation and DEM NULL handling
* Apply review conventions and document caveats
To unsubscribe from these emails, change your notification settings at https://github.com/OSGeo/grass-addons/settings/notifications
