Help: grass port to HP700 series?
Tim Martin; FSO; Soil Sciences
martin at cs.ualberta.ca
Thu Apr 2 19:08:52 EST 1992
Barry,
> We have an HP 730 that is running GRASS 4.0. We had virtually no problem with
> the installation. You need to specify where the XDRIVER libraries are. I
> love the speed of the HP. We were running on a MASSCOMP prior to this. We also
> support the Altek Digitizer and a TEK4697 inkjet on the HP.
> I would highly recommend the HP.
Many thanks. One good recommendation like this is probably all that was
needed anymore to finalize the hardware choice. From the incoming mail
list, I suspect yours will not be the only recommendation, either!
I'm glad I came across this mail group.
Tim.
