Problem with installation on SGI's
David Chatterton
davidc at bruce.cs.monash.edu.au
Tue Apr 21 18:53:04 EDT 1992
I am having some probelms installing Grass on SG Personal Iris's running
Version 3.3.2 of IRIX.
I am unable to access the databases. I have set up the directories as:
/u/cipag0/grass
_______________|_______________
src bin sgi data src/related etc...
_______|_______
spearfish global
PERMANENT PERMANENT
_______| _______|
Is this correct for these setup variables:
DEFAULT_DATABASE = /u/cipag0/grass/data
DEFAULT_LOCATION = spearfish
Thank You
David Chatterton
