Solaris 2.0 and GRASS
Darrell McCauley
mccauley at ecn.purdue.edu
Fri Aug 7 04:53:26 EDT 1992
The only thing that I can think of is the XDRIVER, which may
complain about mismatched load library versions, but perhaps
someone with more Solaris experience could answer better (we're
still at 4.1.1).
BTW, if you have any say in the matter, I would recommend
waiting for 2.1. There seems to be a lot of negative chatter
about 2.0.
> I recently installed GRASS 4.0 on a Sun 4 Sparcstation running
> Sun OS 4.1. Now, that system is to be upgraded to the Solaris 2.0
> operating system. Can anyone tell me what if any consequences this
> will have on my GRASS software? In particular, will I need to
> re-compile and/or change any scripts? Will it work at all? If
> I need to recompile, will the makefiles that came with Grass
> need to be modified? How about the drivers?
