Trouble with v.in.arc
David Stigberg stigberg at zorro.cecer.army.mil
Mon Feb 3 10:17:57 EST 1992
> From lists-owner at amber.cecer.army.mil  Sun Feb  2 17:24:44 1992
> Received: from amber.cecer.army.mil by zorro.cecer.army.mil (4.1/SMI-4.1)
> 	id AA15124; Sun, 2 Feb 92 17:24:44 CST
> Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
> 	id AA27263; Sun, 2 Feb 92 17:24:40 CST
> 	id AA15121; Sun, 2 Feb 92 17:24:39 CST
> Received: from snuff.csd.scarolina.edu ([129.252.42.7]) by amber.cecer.army.mil (4.1/SMI-4.1)
> 	id AA27257; Sun, 2 Feb 92 17:24:37 CST
> Return-Path: <sharp at snuff.csd.scarolina.edu>
> Received: by snuff.csd.scarolina.edu (csd.grandpoobah.011092); Sun, 2 Feb 92 18:24:06 EST
> Date: Sun, 2 Feb 92 18:24:06 EST
> From: Harry Sharp <sharp at snuff.csd.scarolina.edu>
> Message-Id: <9202022324.AA27366 at snuff.csd.scarolina.edu>
> Reply-To: grassp-list at amber.cecer.army.mil
> Precedence: Bulk
> Subject: Trouble with v.in.arc
> Greetings!
> 	This is my first posting to this list, so please excuse any
> breaches of Netiquette.
> 	I am trying to use the v.in.arc function (program?) to read
> a file in ARC/INFO GENERATE format.  The function cannot seem to open
> the file for reading, no matter where I am in the directory structure
> and regardless of the protections on the file.
> 	Needless to say, this is quite frustrating when I can see the
> file, vi it, and see no problem with it.  I also am trying to evaluate
> GRASS for a seminar report which is due in a few days.
> 	Any help is appreciated.  Even that of the, "Well, dummy, it's
> right there in the manual" sort.
> Harry Sharp
The solution to this problem is indeed in the manual, but it must be
obscurely placed because you are by no means the first user to have missed
it:
The ascii files created with the ARC/INFO ungenerate command must be
placed in a directory called "arc" in your current mapset ($LOCATION/arc)
before conversion with v.in.arc.
(Cf. GRASS 4.0 User's Reference Manual, p. 379, 3rd paragraph
under "Description".)
David Stigberg
US Army Construction Engineering Research Lab
Spatial Analysis & Systems Team
217-352-6511 x631
