request for help getting postscript files out of grass4.0
John E. Parks
john at tang.uark.edu
Fri Feb 21 00:47:53 EST 1992
Regarding...
> Just a side note: if your image is better printed in landscape mode, you can
> rotate the ppm file 90 degrees before running ppmtops instead of sending
> commands to the printer. An easy way to rotate the ppm is to insert
> pnmflip -rotate90 | into the pipe stream between xwdtopnm and ppmtops as
> described in (1), or to run pnmflip -r90 paint.ppm before running ppmtops
> as described in (2). The ppm software works very well, from my experience.
Just another side note: Theres yet another one to use... pnmrotate 90.
Like Chris said, just insert it "into the pipe stream between xwdtopnm
and ppmtops". I too think the "ppm software works very well..."
__ __
/ ) / / ) Research Specialist
/ / _ /_ _ /__/ Ctr for Advanced Spatial Technologies
(__/_(_)_/ /_/ )_ / _ National Ctr for Resource Innovations
/ 12 Ozark Hall, Univ. of Arkansas
/ Fayetteville, AR 72701
John E. Parks phone: (501) 575-6159
[john at tang.uark.edu] Internet or: (501) 575-4575
